Question about Dell Inspiron 2200 Notebook
Battery Life Bought a new battery from ebay for laptop but although showing 100% when running just battery the depletes after about 5minutes - is it a dud?
    Sergeant:
  • 406 Answers
Recharge the battery and use it three to four times. If the same thing continues then its conclusion that you have to replace the battery.
Best Rrgards
Rafique
Posted on Feb 17, 2008
Power schemes battery
Chances are that your battery doesn't / wouldn't hold a charge anymore. The laptop runs off battery power. When it is plugged in, the AC power "goes right through the battery", to support the laptop's operations. When the power cord is unplugged, and the battery doesn't hold a charge, the laptop will shut down, as your battery is (too) low to continue supporting the laptop's operations.
The easiest way around this problem is to get a new battery for the laptop.
If your battery is (quite) new (and a Lithium battery), you may wish to see if you can "revive" the battery's "life" ... first by depleting the battery (completely), then charging it (until it shows it is full, plus a couple more hours), and repeating this process a few times. If you're lucky, the battery will slowly/gradually start to hold some charge, but, don't expect it to be very long.
The (preferred) way to use re-chargeable batteries is to charge it fully, unplug it from the external power source, use it until it is depleted, then plug in the external power source to charge it up (fully) again .... and NOT to keep it on a power source all the time.
Oct 26, 2013 | Lenovo G500 59373039 Intel Core i5-3230M...
Tip
Laptop battery life tip
Extend your battery life on your laptop, do not leave it plugged in and charging all of the time. When a laptop is constantly charging, it will deplete the cells on the battery. Two ways to combat this, charge your laptop fully and remove the battery while it is plugged in, or you can run your laptop on battery power a few times a week until the battery dies.
on Dec 12, 2009 | Computers & Internet
Battery will not charge
li-Ion batteries have a bad habit: whenever fully depleted, they lose a few cells, to the extent that they might not be able to hold a full charge if enough cells are damaged. In other words, repeatedly using a laptop (or any other Li-Ion powered device) to battery depletion can shorten the battery's life significantly. You might want to keep the batteries fully charged whenever possible and avoid fully depleting them too often.
There is also the habit of "re-setting" the batteries by using the "fully deplete-fully charge" procedure. It only applies to niMH or NiCD batteries ( and is used to erase the "memory effect" ) but is damaging to Li-Ion batteries for the reason mentioned above.
so if your battery can not full charge,this mean you need change a new battery for your laptop
http://www.aulaptopbattery.com.au
Oct 05, 2012 | Computers & Internet
My acer aspire 5738g get full charged and run only 5 minutes after plug off.
Time to buy and replace the battery. The life of a battery is approximately 2 years with numerous recharges it depletes the life. Often better to run it mainly on AC rather than to charge it and use the battery.
Jul 21, 2010 | Acer Aspire 5500 5570-2609 Laptop
Battery drain/charge problems - Sirius Stiletto 100
An ohm meter across the contacts of the switch, with the battery removed, will show you if it has shorted. If you get a full scale defection on the meter, just like touching the test probes together, in the off position you will have a short.
Apr 07, 2017 | Sirius Satellite Radio Receiver
When my computer is on battery, it lasts less than 10 minutes. I unplug it and its start with almost 100% battery life and it depletes almost right away.
The battery has depleted cells. I hate that it is bad but try a battery with more cells, it will last longer. Seems the cheaper our laptops get, the weaker the battery life.
Aug 31, 2009 | Acer Aspire 5610-4648 Notebook
Laptop battery wot charge to 100%
Please help us help you.....
1. Brand of laptop
2. Model of laptop
Alot of laptop batteries decrease in charge value throughout use. If your laptop is an HP it has a battery restore program with the orginal software sent with your HP laptop. It takes an overnight commitment to let the program run but it usally restores the life of the laptop battery. Another solution would to be buy a new one off ebay.
Jul 01, 2008 | Computers & Internet
Wont turn off
When a Gogear or or other mp3 player gets low on battery life they begin to act up. What has happen is you battery life has been depleted. Even after charging the battery, it will not be able to act normal. I have had this happen too. The only thing you can do is call Phillips to see if there is some kind of warrenty still left or you can have them fix it or try to fix it yourself. The batter is somewhat expensive, $40. I ended up just selling it on eBay explaining the battery problem and someone bought it. Then I used that money and bought a functional one for only a little more. It really is the best way to do it unless you have an extra battery around and know how to fix it. Unlike the iPod, there are not a million knock off batteries out there for the Goegear so you are basically stuck with the options I gave you, sorry.
Oct 29, 2007 | Philips GoGear HDD6330 MP3 Player
Dell Inspiron 2200 Notebook Logo
44 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
