Question about Sharp 32U-F510 32" TV
Screen is "shrunk in"
The sides of the picture are "sunken in" . see this picture to get what i mean :
How can i adjust this? is there a pot on the board i can adjust? or ...?
email me at:
  • 493dart Feb 19, 2008
    so check all the 1 - 10 uf caps ?
    can you walk me thru check the checking of the horizontal section ?
  • 149 Answers
Hi there, you have a horizontal section prob., a defective capacitor with low microfarad like 1 to 10 mfd, or resistor, it maybe a pic cousion prob. at the horizontal sec., do some check up and testing.
Posted on Feb 18, 2008
Flatscreen tv picture has shrunk to the upper left side of the screen
The TV is in Picture-in-picture mode. The small picture is the last active source. The bigger area is the current source connection, but there's no signal.
Read the manual about how to operate the Picture in Picture feature.
Sep 05, 2014 | Proscan 32LB30QD 32 in. LCD TV
Sony Wega Trinitron TV image has shrunk?
Check its main power regulator section circuit for any loose solder terminals. Low power regulator voltage output is the problem to your TV.
Nov 19, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Panasonic p50u20b - picture shrunk into top right hand corner of screen
seems you have found the PiP (Picture in Picture) if you still have the orignal remote press the pip button or the cancel button
Dec 28, 2011 | Panasonic Televison & Video
Tv picture is shrunk to the middle of the screen and turns off
if you mean line across middle no vertical deflection prob circuit prob. need tech.
Dec 13, 2008 | Zenith C27A24T 27" TV
Av-32f476 picture shrinkage
I had a Crummy Westinghouse TV that had a problem like this. JVC's are typically better built then a Westinghouse. My first educated guess - sounds like it's a voltage issue, most likely on the high voltage. Probably a capacitor on the power supply side of the motherboard or the capacitor in the flyback transformer. Just and educated guess.
Jun 23, 2008 | JVC AV32F476 32" TV
The picture has shrunk - maybe 720P vs 480P?
make sure your hd cable connection from your cable box is going to an hd connection to your tv.[via hdmi, dvi,or componant.] if you have a different hook up such as rca out or coax out, these are not hd connections and you are probably streching out the picture.look at the rear of the tv & cable box and see how the connections are.the hd hook up to the hd input should make the picture the right size only if it's set on the hd input channel.hook up the dvd player to a aux/line in or video/source input and try changing the picture size. you may have to play around with it till you get it the way you want.
hope this helps.
Feb 06, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
When you say small do you mean shrunk up top and bottom as well as from side to side. You definitely have a deflection problem either horizontal or vertical.If the picture just shrunk top and bottom you have a vertical deflection problem. Do you have the service manual for your model? If not let me know and I will email you one. Describe the shrinking issue a little more and I should be able to give you some guidance.
Feb 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
Picture fault
What is picture like if you change screen size to 4-3  is this picture size ok & fault only shows in the wide screen formats.
Oct 10, 2007 | Televison & Video
Picture needs to be shrunk down
Is there auto adjust option? did you tru it?
Feb 12, 2007 | Hitachi 53FDX01B 53" Rear Projection...
Sharp 32U-F510 32" TV Logo
106 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
