Question about Microsoft Xbox 360 Console
Xbox 360 Our kids tried to use today sound is working but no picture took off projector and tried on tv still not working . tried cable at freinds house and worked on his xbox.
  • Cowboy13 Feb 17, 2008
    the picture will not come up, but still have sound. Started out a week ago with only yellow and blue in the picture so I bought a new cable. Worked for a couple of days now no picture at all.
  • Anonymous Dec 17, 2008
    iplugged it in on my Tv and no picture, no sound, no nothing i made sure it was the right channel and i plugged it in on every port, after that not being succcesful i plugged it on a different TV and guess what? still not working
  • 152 Answers
Things to try -
1. Try using a different video port on the TV.
2. Try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
Posted on Feb 17, 2008
No picture or sound with brand new xbox friend's xboxs worked ok
Look like ur Xbox 360 AV RCA cables is not making contact to the input board very well.Take some rubing achahol cleans the all those input holes,take the RCA AV connections make couples twises to the red,yellow and white,will help.Make contact with ur input board it should work.
Apr 28, 2010 | Zenith SY2551S TV
My xbox 360 won't sow the picture but i have sound
try it in another tv with av cable
if u are using hdmi cable try changing the existing cable
if it works in another tv , go changing the setting in the displaysettings and video settiing
Mar 05, 2010 | Microsoft Xbox 360 Console
Xbox 360 working thru HDMI working fine. Now no sound & weird pic
it is prolly an internal problem. have to tried connecting the componet cables?
Mar 03, 2010 | Microsoft Xbox 360 Console
We have sound but no picture on the xbox 360
The first thing to try is to remove the external hard-drive from your Xbox and see if the picture comes back. If that doesn't work you may have the video resolution of the Xbox set too high for your TV to display. Try reducing the Xbox resolution and see if you can get a picture. There is a switch at the end of the cable where it plugs into the Xbox that says TV and HDTV. Try setting it to TV. If you know someone with another Xbox 360 that you can borrow you can use it to debug your problem. If their Xbox works on your TV try swapping out the cables. You can see if your Xbox works with their cables and if their Xbox works with your cables. You should be able to narrow your problem down to either the Xbox, the cables, or the TV setup.
Jun 06, 2009 | Microsoft Xbox 360 Console
No image on xbox
Whenever you need help with Xbox 360 or Xbox 360 accessories problems, check out Xbox Customer Support
The answer is quite long, so here's a link.
And if that doesn't help, try contacting Microsoft directly.
Hope this helps!
May 08, 2009 | Microsoft Xbox 360 Console
No signal from xbox to tv
Try resetting resolution and then tweakin sound setting in menu.
Look Here: http://cocaman.ch/wp/2006/12/reset-xbox360-resolution/
Jan 10, 2009 | Microsoft Xbox 360 Console
New XBOX 360 no picture / sound
ok your lucky, you just need to by a new av cable.. or if that dosnt work you need to get the av caple connection fixed (only about $25)
thanks, Domo
Dec 23, 2008 | Microsoft Xbox 360 Console
No display signal thru tv
any sound from the system?
Nov 09, 2008 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Xbox 360 Elite compatible with 62' Mitsubishi HDTV?
I have it and it works great! For all TVs, the TV have to be on fixed settings on standard, dot-by-dot mapping, noise reduction off. The camera's exposure the same for both side-by-side shots. Just set it on standard and it should work...
Jun 05, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
