Question about Smeg SUK92MFX5 Dual Fuel (Electric and Gas) Kitchen Range
Suk92mfx5 main oven problem?
During cooking using the fan setting the cooker blew the main RCD and cooker RCD trip in the consumer unit. after resetting the trips the fan still ran but there was no heat being delivered. has the fan element blown or is there a thermal cut out or fuse that requires changing or resetting.please help
  • muzza7 Feb 26, 2008
    changed the fan element as suggested, simple to do. fantastic service. A+++++++++++
  • Sid C May 30, 2008
    Have had to fit 2 previous elements to my cooker. On both occasions I have done it by pulling the wiresthrough. This time, however , ! wire became detached so I had to remove the rear panel.
    Now I have 1 light blue on one side of element and red / white on other prong.
    Now I have white and blue wire hanging loose. Does it connect to light blue or the white and red?
    At moment fan comes on but element does not heat up.
    Grateful thanks for any help.
    Simon Cowdry.
SMEG A42
during cooking the cooker blew the main RCD and cooker RCD trip in the consumer unit. After resetting the trips the oven still delivered some heat but was unresponsive to the temperature control. The Auxilliary oven oven/Grill still works fine. Any suggestions? Could it be the thermostat?
Thanks
Posted on May 28, 2008
  • 49 Answers
The fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Posted on Feb 19, 2008
Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Sep 05, 2012 | Ovens
Blows mains fuse
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Aug 26, 2012 | Smeg SE210X/1 Stainless Steel Electric...
U1442 main oven not heating
If you are sure there is 220v going to unit, it most likely is element or click / control. If you have a ohms meter, you can test the element
Sep 07, 2017 | Neff U1721 Double circotherm Electric Oven
I have a stoves cooker which was working fine until we upgraded to the seventeeth edition consumer unit and rcds. Now I have a negative earth fault.Rcd trips out, circuit is fine up to the cooker. Any...
The clue will be when the rcd trips out. If everything is switched off on the cooker with the exception of the clock when you power it up and then it trips out, it could be in the wiring to the oven from the control switch and or the wiring in the oven. The only way you are going to find this is to take the oven out of the housing and test the wiring, isolating components until you find the problem.
Jul 31, 2011 | Stoves 720EF Electric Double Oven
Smeg se280x has just gone dead in middle of cooking .the digets have gone and is blank the oven fan @ light still work but that is it regards paul ?
Jul 18, 2011 | Smeg SE280X Stainless Steel Electric...
Siemens oven tripping RCD
We need wiring diagram for HB905 Siemens double oven, to start with it kept tripping, element ok. Now we have no heat coming from the main oven.
May 02, 2009 | Siemens Ovens
Fan but no heat
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on Facebook please
Mar 14, 2009 | Smeg SE280X Stainless Steel Electric...
Smeg oven suk92mfx5
ring element has burnt out.
Feb 16, 2008 | Ovens
Cooker keeps tripping the electricity supply.
If the main oven is electric, disconnect the heater element and try, if no trip operqates. then replace element.
Nov 22, 2007 | Belling CookCenter 151 Dual Fuel (Electric...
Open Questions:
See all Smeg SUK92MFX5 Dual Fuel (Electric and Gas) Questions
Smeg SUK92MFX5 Dual Fuel (Electric and Gas) Kitchen Range Logo
1,209 people viewed this question
Top Smeg Kitchen Ranges Experts
Carmen Mikulic
Joseph Mueller
Joseph Mueller
Your Consultant
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
