Question about Nintendo Game Boy Advance Console
I am trying to get my ps3 linked up to my wireless router. but i dunno what all i need to do to do that and if i need any wires or connections.
  • 61 Answers
Really need more info, but for a start you need either a compatible wireless (USB?} device, or a CAT5 cable from the PS3 to the router.
I could probably help more with more background info like brands of involved devices if that doesn't solve your problem.
Posted on Feb 17, 2008
    Problem Solver:
  • 13 Answers
Happy
If you open this guide up to Page 24 it is has everything you need to know about setting up the PS to your wireless network.
Link to Guide: Click Here
Hope this helps
I have this router set up with a wired connection to a windows pc with windows 7 and using the wireless to connect a laptop and a ps3. when the wired pc is off the ps3 connects just fine, but when it is...
It sounds like you may have manually assigned the same static(constant) IP address to both the wired PC and the PS3. Check both the settings in the router, the PS3 and the wired PC to make sure that an IP address is assigned to both.
Feb 03, 2011 | D-Link DIR-615 Wireless Router
Slow download with PS3
Turn on "Interface Robustness" in the wireless options. Also disable UPnP in both PS3 and your router.
Try to be as close to the access point as possible.
Oct 12, 2008 | Sony Playstation 3 (PS3) Console
I want to get the wireless connection to my ps3. How do i do this?
First you will need to check the wireless settings of the router.
What settings do you need to check ?
SSID ( network name )
wireless channel
wireless security type
If secured then network key or password.
To check these settings you will need to open the router set up page. This is the page where you will fin all the settings of the router.
Once you get all the settings of the router, you can try to connect to the wireless network on your PS3.
You will need to go to network settings on PS3. Go to Internet connection settings , wireless connection.
There you will find the option to connect to the network.
Click here for step by step instructions
Feb 25, 2010 | D-Link Xtreme N DIR-655 Wireless Router
PS3 and Netgear WGR614 V7 Router
Basically the PS3 wireless settings needs to be configures with the Netgear wireless router settings.
To test if the modem is connects to the Internet, connect a computer into the modem, if it works then the modem is configured correctly. If it doesn't work, then contact your ISP and get them to test your modem connection.
For details on how to configure the PS3 click on the WEB link :-
wii.php">http://fixhomenetwork.com/xbox-play-station-wii.php
Dec 20, 2009 | NetGear WGR614 Wireless Router
HOW DO I CONNECT DIR165 TO PS3 I HAVE ENTERED THE LAN AND ALL THE OTHER ADDRESSES BUT IT WONT CONNECT
The D-link Router should work with its "factory" settings,
with most ISPs (Internet Service Providers), if you connect your
cable-modem or ADSL-modem to the 'WAN' or 'INTERNET' port on the router, and if you use an Ethernet cable to connect from one of the 4 'LAN' ports to the network-port on your desktop/notebook computer.
Once you have established a "wired" connection, and you can surf the Internet, follow the instructions in the manual that came with the D-Link to run the "Wireless Setup Wizard" to configure the "wireless" part of the router.
Add those "wireless" settings into your PS3.
Dec 05, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
How to hook up router to PS3
Are you trying to connect the PS3 to the wireless network.
First make sure that you have all the wireless settings of the router like the SSID , security key , etc ...
If you don't know the wireless settings then you will need to access the router set up page.
once you get all the settings then you will need to connect the PS3 to the network.
Click Here for step by step solution
Nov 10, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Why won't my ps3 connect to my wireless router? An IP address is needed which it will not find, only on wired connection will it connect!?
Disconnect the LAN cable from the PS3.
The PS3 needs to be configured as follows :-
Select Network Settings - Easy - Wireless - Scan, select your wireless router, select your SSID, if it isn't displayed the type it in, select security settings, enter your router's encryption settings
Your router will issue an IP address to the PS3 and you will able to access the Internet wirelessly.
Jul 26, 2009 | Computers & Internet
Cant connect ps3 wireless to dlink router
The router should assign an IP address to your PS3 if it isn't manually configured. If you are connecting wirelessly make sure your security setting on your PS3 match your router. If the problem persists disable wireless security on your router and then try to connect with the PS3 with security disabled as well. Sometimes consoles have trouble connecting with WEP or WPA security encryption.
Jan 06, 2009 | D-Link AirPlus DI-524 Wireless Router
Can I have a wired and wireless connection from the same router?
Hello..the quick answer is yes, this router allows wired and wireless connections at the same time, and it is easy to connect wirelessly (in theory...).
The PS3 will need to be configured to connect to your router, though. There is a guide to achieving this here:
If the wireless signal on the router has been secured, the settings used will be needed to set up the PS3.
If not, you may wish to secure the wireless connection, which is not too difficult - just a few steps, which I or someone else can help with if you wish.
Hope this helps, but please come back to Fixya if anything is not clear or you need further information.
Jan 01, 2009 | NetGear DG834G Router
Just hooked up ps3 wirless , gaming is slow
if your PS3 is closer than 20 feet from your router, then its unlikely to be your signal strength.  However, Wireless connections tend to "poll" their connected hardware. What I mean by taht is.... The router sends out a signal, just to check and make sure all the peripherals are still there.  I dunno about PS3 yet, cos I havent tried to game online, but I am an avid PC online gamer, my pc is within 5 feet of my router and Ive switched back to LAN cable to play.  I was experiencing periodic "lag"... due to that polling effect.  Try using the LAN cable and see if that makes a difference ( I dont know how many Ethernet RJ45 connections a Netgear has, ... if it only has one, you may need to connect a "switch" )
Oct 28, 2007 | Sony Playstation 3 (PS3) Console
Nintendo Game Boy Advance Console Logo
23 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
