SOURCE: hard drive password locked
hi there,
please go to this site for instructions
http://www.thepaperclipguide.6x.to/
SOURCE: Hard Drive Password protected
It's 50/50. With some hard drives you can reload the system, with some you can't. If it's one that won't allow you then you will need to replace the hard drive. One little trick you might try if the hard drive won't allow you to reload is place the hard drive on the speaker magnet in your car overnight. Open the trunk, and you should see the magnet at the base of the speaker, just stick the hard drive directly to it, and leave it. A speaker magnet is strong enough to scramble a hard drive. This doesn't always work, but it has worked a couple of times for me with hard drives I've picked up at auction that were password protected.
SOURCE: Dell Inspiron 600m: No Boot Device. I'm a computer
Have you tried resetting the BIOS defaults? In doing so, it will force IDE re-detection and often resolve vague boot issues.
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
During the boot up process you will see on the screen press a certain key to enter set up
Press either delete or f2 during the boot up process to enter BIOS scroll down to set user password you can change or remove your password from there
hope this helps
