Question about Brother XL-3030 Electronic Sewing Machine
Cannot come out of "Bobbin Winding selected" mode
I had not used my machine for some time now.
Now the machine stays in "bobbin winding selected" mode. When I run the machine with with switch moved to "Bobbin" image side it works propertly only bobbin spins. If I move switch to the needle image side both bobbin and needle moves. On display it contines to say "Bobbin winding selected"!!
The previous setting was for zig-zag!! I am stuck with this setting. Please help
--GS
  • goodshepherd Feb 26, 2008
    Hi BB,
    I found a manual over the net. It did not help.
    I did exactly that "Open the machine and play around".
    To my own surprise I figured that the bobbin which should have moved to non winding state had not moved and something was holding it up. I don't know what was holding it up. What was I gonna loose anyway? Right, I gave it a hard push in every direction I could, like trying to open a number lock combination. It worked!!!! Well every thing works fine, almost everything.
    All I lost after this sheer muscle power is almost nothing, everytime I change the switch from bobbin to needle I will have to slide the bobbin holder manually to unwinding position. Hey! I can do that without having to open the casing.
  • Brother Master
  • 1,388 Answers
If this were a Janome, it would indicate that a sensor for the bobbin winder needs adjusting, so the safest way forward is to seek the advice of your local Brother dealer, or contact Brother in your home country for details of nearest agent.
Sorry to say,........sometimes these things really do need to be seen to by trained technicians with access to diagnostic equipment and workshop manuals, they cannot be done via email, and if you just open the machine and play around it will end up at a workshop anyway.
Apologies to be the bearer of such news....every day I give thanks that I am not a veterinarian.
Posted on Feb 24, 2008
  • Hassy
    Hassy Feb 26, 2008
    Well congratulations, I think you got lucky........I would never advise anyone to force anything, sewing machine or world superpower........hope you have not broken a spring that may come back to haunt.
    So far as manuals are concerned, there are several for each machine,
    the Instructions or User Guide for the owner to learn the stitch capabilities and how to use their new machine,
    a Parts List with an exploded view of each nut, bolt and armature etc,
    and then the one that is for Service Technicians, the Workshop or Service Manual, a wealth of tech info on tolerances and settings .......... it was the latter to which I referred, sorry if this caused confusion.
The shuttle won't stay in place when I put the bobbin in it and try to sew.
Use a new different bobbin...plastic bobbins are notorious for melting and then don't work. Also, take your time winding the bobbin...a nice even wind will center the bobbin. Speed demons cause the bobbin to be unevenly wound and off center. Good luck!
Jan 23, 2017 | Sewing Machines
Bobbin winder is engaged and shows up on screen correctly, but sewing mode is still engaged and bobbin winding keeps stopping.
check the drive knob on the end of the machine
it should be loose when winding a bobbin
if it is tight or seized then that will drive the needle
Sep 20, 2015 | Janome Sewing Machines
I have trouble winding the bobbin. For some reason it starts winding it below the bobbin.
Verify that you are threading it properly for bobbin winding. Perhaps the bobbin winder height needs to be adjusted. If you continue to have problems (which I frequently have with some of my machines), I simply use a pencil or a skewer to raise the thread as it is winding on the bobbin.
Sep 15, 2015 | Sewing Machines
Why does display read "WINDING BOBBIN" and won't clear?
This video may help:
Winding an Elna bobbin
Perhaps the bobbin winding mechanism has not been released. (She unsnaps the bobbin when finished winding.)
Aug 31, 2015 | Elna Quilter's Dream 6003Q
My bobbin winds unevenly, there is always more thread at the bottom of it than there is at the top. Neither switching to the original pfaff bobbin nor either spool position works.
I always use my finger to guide the thread as the bobbin is winding,the bobbin shouldn't be moving around in the metalcase probably needs tightened.
Aug 29, 2015 | PfaFF Sewing Machines
The bobbin winder keeps winding
Please take your machine out of bobbin winding mode.
Sep 02, 2012 | Husqvarna Sewing Machines
Bobbin winder will not wind
The bobbin winder will not activate to turn the bobbin or the thread will not wind onto the bobbin spool?
Sewing machines vary in the method used for bobbin winding.
You can find threading and bobbin winding guides at sewusa.com.
If the winder is broken, you can get it repaired or check into getting a Sidewinder Bobbin Winder as an auxiliary for winding the bobbins, which would be less expensive than the repair.
Mar 13, 2010 | Kenmore Sewing Machines
Bobbin Winding message appears when machine is turned on
Is the bobbin winder holder clicked over to the right like you are trying to wind a bobbin? If so, and you are not trying to wind a new bobbin, click it over to the left.
Mar 09, 2009 | Kenmore 19233 Computerized Sewing Machine
Elna 6003Q Sewing Machine won't snap out of bobbin winding mode
I had the same problem and fixed it myself. Remove the portion of the housing that coincides with the bobbin winder. You will need to remove two screws to do this--one is just to the upper left of the bobbin winder itself, and one is hidden under the handle on the left side of the machine (lift the handle, and look on the machine on the left side.) It takes some coaxing to remove the housing, but it can be done--be gentle. If you need to, remove the housing on the left side of the machine that covers the needle assembly. This will make it a bit easier, but still, be gentle.)
After removing the housing, you will see a black metal piece with a elongated slot and a screw adjacent to the bobbin winder mechanism. Unscrew the screw a turn or two, and slide the piece to the other side. Tighten gently. Turn your machine on, and move your bobbin winder back and forth and watch the screen change from bobbin winding to the main straight stitch screen. Now, do a brief Dance of Joy. I hope this helps.
Dec 26, 2008 | Elna Quilter's Dream 6003Q
Elna Primula 410 Bobbin Winding Question
Wind the Bobbin
For the usual jobs, it is the best to use a medium sized thread.
2. Disengage the flywheel by unscrewing the coupling knob as far as it will go.
3. Place the bobbin on the bobbin winder, and push the bobbin winder to the right.
4. Pull out one of the spool pins and place the spool of thread on it.
5. Pass the thread through the bobbin winder tension discs, as indicated.
6. Wind the end of the thread around the bobbin by hand, in the direction indicated.
7. Wind the bobbin, at a medium speed by pressing lightly with a finger on the spool so as to stretch the thread better and thus fill the bobbin to a maximum. The full bobbin stops automatically.
8. Re-engage the flywheel by tightening the coupling knob.
9. Cut the thread and remove the bobbin from the bobbin winder by pushing the latter to the left.
Jul 29, 2008 | Elna Heirloom Edition 6005
Sewing Machines Logo
168 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
