Question about Cameras
Defective mode function switch
Switch doesn't work most of the time when you change from video to still or picture mode. most of the time it stays on video mode. you have to play around with it to get it to function in still mode.
shirley
Possibly the contact points are damaged. plz check with the help of a electronics repairman.
Posted on Feb 17, 2008
My pantech all of a sudden has the wrong date and time on it how do I correct it ?
Go to settings then cliq on time and date settings, then set it to the normal time then cliq OK. Thank you for using Fixya.
Aug 28, 2011 | Pantech Cell Phones
On spin cycle drum going round but not spinning so clothes stay wet
Hi, if it doesn't spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jun 20, 2011 | AEG Lavamat 74640 Front Load Washer
My computer screen becomes blank after it asks whether I'd like to stet windows normally or go into safe mode etc... Why is this?
find a good WORKING CRT [Cathode Ray Tube] monator, plug it into the VGA out. there should be a key (almost always bottom left hand corner with [FN] in a different color, usually GREEN or BLUE, look for pix [picture] of small screen on row of keyboard ( # 1 thru 0 ) and press and hold FN key with touch of # key of picture (pix) of screen. If the picture switches to EXTERNAL and stays on, then you could have a defective laptop screen. If the screen on the external CRT turns like you said then turns black, you could have a defective video output. get back to me and let me know what hattens.
Don't be afraid to REBOOT even after you have changed INTERNAL to EXTERNAL. If you have to try to switch while you have the time while you see the screen on internal laptop
Nov 20, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Does not chnage back from from Photo mode to Video Mode
If you have been using this camera for a long time, most likely the function switch ( the one you turn to change from photo to video mode) contacts are worn out. you have to take this one to a repair shop to change the function switch.
Regards,
Luwangula
Oct 30, 2008 | Panasonic NV-GS180EF-S Mini DV Digital...
No playback on DCR-TRV103
In playback mode the lCD displays the battery time, hi8 symbol and the tape counter. all the functions work the tape will play, rewind, fast forward. The screen stays blank on playback and the tape counter stays at 0:00:00 eventhough I can see the tape turning. I also hooke the camera to my tv and I got no picture.
Dec 23, 2007 | Sony Handycam DCR-TRV103 Digital Camcorder
Camer scrolls through modes all on its own! sony DSC W100 digital camera
very good poss that camera needs mode dial switch assembly.Especially if unit was subject to liquids near the mode dial .part # 147966811 for silver and 147966821 for black model..First reset camera by pushing reset switch should be around batt compartment and or memory stick area.
Dec 03, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
My A75's not functioning
Hey your change over switch is faulty you nee dto replace it. Sangita
Jul 08, 2007 | Canon PowerShot A75 Digital Camera
Problems with 2 Port KVM Switch with Built-In KVM Cables
The monitor is not detecting the video signal from your computer. Assuming both of your computer video cards have been tested and really work I would try the following: Try switching the cable sets that connect the PCs to the switch. If the problem follows the cable set then it?s likely the cause. If not then try switching the cables that plug into the switch so that PC#1 is now connected to the port where PC#2 originally was and vice versa. Again if the problem stays at the same position then I would suspect a defective switchbox. If it doesn?t then you probably have an issue with one of your PCs video cards. I know this is two months late but perhaps but hope this helps you or someone else researching a similar problem.
Apr 23, 2007 | IOGear MiniView GCS62 2-port KVM Switch
JVC HR-S3901 S-VHS / Switching from TV to VCR no longer works . . .
Ifyou do not see the VCR/TV button switch on the front panel, then its a problem most likly with the firmware in the microprocessor. If you do see the VCR/TV indicator switching in or on the front panel display, most likly a defective RF modulator/switcher or RF antenna pack. You may still be able to get one from like MCM or tritronics or PTS corp can rebuild it for you. I have seen this type of break down many times with VCR's as we used to do hundreds of VCR repairs a day as we did factory service for several companies in the NY/NJ area. Good Luck Please do not forget to rate this thread.
Dec 10, 2006 | JVC HR-S3901 S-VHS VCR
Can't take pictures or videos
The lens block appears to be defective. If you need this pl.let us know further.
Aug 07, 2006 | Sony Cyber-Shot DSC-S40 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
