Question about Harman Kardon AVR 630 Receiver
No surround sound
I have Klipsch speakers; one front, one subwolfer, four RX4s. I also have a 43 inch Pioneer Plasma TV. The Klipsch surround sound worked great, but now the only sound comes from the TV. I have checked all of the connections. Help Please!
    Genius:
  • 3,422 Answers
As you already checked the speakers, the HK manual says to check if the audio analog chain is fine. That means selecting 6/8 direct channels as source and apply a sound source for each channel. You can use a CD and test each pair of the 6/8 inputs at a time or use the output from a PC sound card with a test generator software (some excellent free software available as from NCH swift). Adjust the volume and listen. I guess you will obtain sound from the right front channel.
If you have sound in all speakers at the end of the test it means all audio channels are fine end to end.
The good news according to HK manual is that you eliminated 90% of the component of the system. The bad news is the problem is in the DSP section. There are no instructions or tests for the DSP part so you will have to go to the service center.
Goodluck..
Posted on Feb 17, 2008
  • Priya darshan Feb 17, 2008
    I think the problem is the C657 capacitor, located on the DSP PCB. You can either replace it yourself, or just hand
    the info out at your local repair centre.
  • 749 Answers
Check the wiring while it is ON, there might be a loose wiring... also check the power of the amplifier... then check the TV setting for the activation of the surround system...
Post me the results... hope this Fixya the problem...
I have a Pioneer VSX 823 - K, and when I hook up my Klipsch HG-12 300 watt subwoofer to it, the receiver is prone to overheating or just shutting off with too much bass. Is there a fix to this?
This is receiver thermal going in protect issue and has no bearing to your sub, The sub has its own power amp and not supplied by the receiver. Thermal module may be bad. See a tech.
Mar 06, 2014 | Pioneer VSX-823-K
I have no sound coming from surround speakers and sub.
Some surround modes switch speakers on or off as required. It's possible that the inputs you are using have settings that remember your previous settings, ie: no sub and surround speakers. Check the inputs and also make certain that whatever is connected to them is putting out Dolby signals.
May 04, 2017 | Pioneer VSX1020K Receiver
Buzzing noise
It could be feedback from your speakers... Make sure your power cord is grounded and if you have a sub or surround sound don't set the ac power adapter near them.
Mar 15, 2012 | Pioneer PureVision PDP-4300 43 in. Plasma...
Reciever only allows 2 channels(speakers) at a time.
If the amplifier is not receiving a surround sound signal, you will get nothing from the rear speakers and probably nothing from the front centre. Play a dvd in dolby surround and it will work.
Apr 14, 2017 | Pioneer VSX-918V Receiver
Creating a surround sound system
Hi and welcome to FixYa,
Offhand should work more than OK. Even if the 520 is only pushing 75watts per channel, you have 2 X for the front KSB-2.1 (left & right) plus another 75 for the Polk Audio center in addition to 250watts built-in amp of the Velodyne CT-150. What would be better is another pair of KSB-2.1 or comparable for the surround (another 2 X 75 and widening the separation).
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 16, 2008 | Harman Kardon AVR 520 Receiver
Surround sound
I need to details from you.What other components have you connect together?
solutiondoct
Sep 06, 2008 | Pioneer PureVision PDP-4340HD 43 in....
No sound
maybe in your cable box
Mar 30, 2008 | Pioneer PDP-4360HD 43 in. Plasma...
PIONEER PLASMA NOT TURNING ON
common problem power supply need replacement
Oct 25, 2007 | SVA-USA HD4208TIII-VR 42 in. Plasma...
Media Receiver
There should be fans inside this unit too. open the top cover and see where the noise is comming from. I am sure you will find it. Good Luck
Mar 21, 2007 | Pioneer PureVision PDP-4340HD 43 in....
Harman Kardon AVR 630 Receiver Logo
179 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
