Question about Whirlpool GEW9250 Electric Dryer
Noisy "rubbing" sound...
My Duet dryer works perfectly but there is a rubbing/clanking sound that drives me to distraction when it's tumbling. It almost sounds like something metal is tumbling along with it. It makes the same sound if it run it empty.
  • clwseattle Feb 17, 2008
    The noisy has been getting steadier... more. When it tumbles it also sounds like a car wheel that is not guite round... a slight thump on every rotation... I'll have my husband give it a good oil. It's about 2 years old though so I wonder if it would need it this soon....
  • Gary Davd
    Gary Davd May 11, 2010
    how mech. inclined are u?? if i send you the repair manual to break it down would that help??
  • 770 Answers
  • Sounds like You have a flat spot on the support roller They will need to be replaced If you want to get the drum out let me know there are two rollers on the back that support the drum I suggest while you have it open to replace both
Posted on Feb 17, 2008
  • 958 Answers
It may need a good lubrication job. look for all rolling parts metal or plastics and give a good dose of WD-40 and observe. ba particular to the bushing of the drive motor, the roller and the center bearing that hold the drum.
Our Ceiling fan is making noises when it's on.
hey Amy, Some brands of ceiling fans are notorious for being noisy,, What type of noise is the most important (or to be concerned about)... a clanking, binging, any high pitched repetitive sounds can usually be traced to an off-balanced" fan with something inside moving.. Now, if the sound is a constant, grinding, rubbing type sound, it needs to be investigated.. ceiling fans are not complicated.. its just an electric motor that drives 4 or 5 blades.... and has a light switch. If its grinding, the bearings are probably going bad.. They are not hard to replace if you have mechanical aptitude.. Go to the manufacturer's website.. they should have a trouble shooting guide,, check it out,, and also have a place for you to order parts..
Jun 25, 2017 | Dryers
Why is my tumble dryer making a loud banging noise when on its a white knight model CL3A
Most of the time a tumble dryer will work like a dream but, as with all appliances, occasionally there will be technical problems.
If your tumble dryer is making a banging, whining (or other strange noise) it's best to diagnose and sort out the problem. It could be the result of a number of things, but what you certainly don't want to do is ignore it.
Here are the most common reasons for your tumble dryer making odd noises.
Coins and keys
One of the most common reasons for a banging, rattling or clanking is keys or coins left in pockets - so always check them before you put any clothes in the tumble dryer. More often than not you won't hear anything until the dryer cycle is in full spin.
Uneven surfaces
If the dryer is vibrating or shaking during spinning, check to make sure the dryer's sitting on a level surface. If it's fitted with height adjusters on the front legs, adjust them accordingly to ensure the machine is level as this will often reduce or eliminate the banging sound.
Drum bearings
If the tumble dryer is noisy when its turning and the whole appliance is shaking and rumbling, it could be indicative of a problem with the drum bearings, which help the wheels turn freely and easily.
The drum
If the banging noise is continuous when the drum is turning then it might be problem with the drum itself. If the noise is a metallic one, it could be the result of the drum scraping on something inside the machine. You could always check the drum visually for any marks or dents.
Motor bearings
If the tumble dryer is emitting a high-pitched screaming or whining noise it could be a sign that the motor bearings are wearing out.
Tension pulley wheels
If there's a squeaking noise coming from the dryer it could be the result of wear on the tension pulley wheels. This occurs more frequently on older models...or try this link..
Common Tumble Dryer Problems
Dec 09, 2016 | Dryers
When the dryer tumbles, it makes a loud noise. What could it be? How do I fix it?
Go to Sears and purchase a new belt & idler pulley wheel for yours. The bearing in the pulley has dried up bearing causing this noise. The belt will be stretched and replacing it the same time will save a future headache
Dec 27, 2010 | Dryers
The dryer works perfectly but is very noisy can we have the technical diagram for the white knight gas tumble dryer please
The problem is likely the rear drum rollers. Here is a link that should help http://appliancehelponline.com/dryerrollervideo.html
You can also enter your model # there for diagrams and illustrations of your specific model.
Sep 16, 2010 | Crosley CDG6000 Gas Dryer
Tumble dryer is very noisy
i had the same problem.it ended up being the bearing that holds the drum in place.it had worn that bad that the drum was rubbing the bottom of the dryer.the bearing is located on the back of the dryer if the bearing is worn there will be like black dust around the area.this does stain so be carefull
Feb 19, 2010 | Miele Dryers
Alarm sound while drying
It sounds like you have it on the "wrinkle free cycle". (I can't remember what the cycle is actually called with out looking it up.) It will tumble your cloths and then alarms to tell you to take them out before they wrinkle. If you don't take them out, it will tumble them again and alarm again, etc.
Apr 13, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer makes a squeaking noise
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
thanks and please do not forget to accept the solution
Apr 03, 2009 | Frigidaire FEX831CS Top Load Stacked...
Whirlpool dryer drum making noise
window.google_render_ad();There are many places & parts that could be causing your Whirlpool dryer to be noisy. To find out what is causing the noises, you need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to pinpoint where in the dryer the noises is coming from. Once you have an idea of the area, you will need to disconnect the dryer from the wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your dryer is noisy.
The drum baffles:
The drum baffles are use to tumble the clothes inside of the drum, in other words, the baffles job is to separate the pieces of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot, the drum baffles holding screws will become loose. Loose drum baffles will cause noises. All you need to do, is to open the top panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the front and two on the rear. The job of the drum support rollers is to keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start to make squeaking noises and the roller bearing will start to wear out until the bearing on the roller is gone. When the bearing on the roller is gone, the noise will change from squeaking to a clanking noise.
The blower wheel:
The blower wheel is use to circulate the air inside of the dryer drum. The most common Whirlpool blower noises are cause by something falling inside of the blower housing and hitting the blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on the belt. There are two types of idler pulleys, the pulley with the wheel and the pulley with the teflon slide. A bad idler pulley could cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to run kind of noisy. When the motor starts making noises, the solution to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These belts work very hard making the drum tumble. When the belt stretch just 1/2 inch more that it supposed to, the belt will start slipping and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become noisy in your dryer. When your dryer starts making noises, make sure to check it out before it gets worse.
Feb 09, 2009 | Whirlpool LER4634J Electric Dryer
Noisy dryer
hi there,
the rattling and squeeling noise usually comes from the drum shocks. they do wear out due to use. i would recomend replacing them.
Oct 11, 2008 | Kenmore Dryers
My noisy hoover tumble dryer...help please!
possibly bearings gone on drum shaft
Mar 20, 2008 | Dryers
Whirlpool GEW9250 Electric Dryer Logo
135 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
