Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA HD52W56 I had this RCA HD52W56 with no picture but the chirping noise come out of the back when I turn on. I think it's the flyback. What do I do? Any help really appreciated, Thanks
  • 1 more comment
  • andy9999 Feb 18, 2008
    Is there any reset button for the picture tube?
    what would be the best solution for this problem? I got sound but no picture only pitching noise coming out the back. Can I test the hv splitter with multimeter to see if I get any power from the flyback?
  • Anonymous Apr 13, 2008
    i have a rca home entertainment model P46921. we were wacthing the tv and then it went dark. i unplugged it. left it off for a day, plugged it back in , and all i get is a chiping noise. please help
  • RCA Master
  • 5,138 Answers
If you know how to solder - solder around FBT pins this should return your picture.also chk FL231 in front of flyback 400ma .chk pins 3&4 of flyback, LL008,LL201 for poor connections.ThankYou for using FixYa. Have a Nice Day.
Posted on Feb 17, 2008
  • ladywinn
    ladywinn Feb 18, 2008
    There is no reset button on any tvs, Not the new ones i havent seen reset buttons since 1980, you also have 3 tubes red, green, ,blue.
60 in RCA rear projection making a chirping noise no picture no sound
Chirping is almost always caused by the HOT transistor and Flyback transformer. You can get the Flyback with HOT repair kit for your model from www.tvrepairworld.com they are listed under the RCA Repair kits.
Feb 16, 2012 | RCA P60921 60" Rear Projection Television
My RCA 52 blinking power light, no picutre
Flyback transfromer is defective and needs to be replaced.
Oct 12, 2009 | RCA HD52W56 52" Rear Projection HDTV
52 in. rca high def. rear proj. making high pitch noise
the set probably has lots of bad solder connection on the flyback and in the horizontal deflection circuit.
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA F32650 no picture
Sounds like the flyback. Mine did the same. I am in the process of trying to fix it. Try techlore.com for more help.
Jun 24, 2008 | RCA 32F531T 32" TV
No picture no sound
First check to see if you have any voltage at test points with a digital meter.
You may need a repair manual for this.
Since you hear some noise your main fuse is ok.
Try checking this tp voltages first.
BE CAREFUL, wear gloves
Feb 15, 2008 | RCA HD52W56 52" Rear Projection HDTV
No picture or sound - TV makes chirping noise
The chirping sound is the power supply coming up then breaking down because there is a short somwhere in the high voltage. The most common fail in this area is the horizontal output is shorted ( 237470 ) but what cause this short could be simple cold solder joints or the High voltage transformer ( 239111 ) If you have noway to "ring" the flyback change both parts
Feb 13, 2008 | RCA Scenium D40W20 40" Rear Projection...
My RCA TV turned itself off and started making chirping noise
You have poor solder connections these sets are famous for this! Solder Flyback transfomer pinns this should fix it.
Oct 07, 2007 | RCA D52W19 52" Rear Projection Television
POPPING NOISE
mine did the same thing on a cable line and then i put rca cable on it and it never did it again
Oct 06, 2007 | RCA HD52W56 52" Rear Projection HDTV
My RCA F32650 doesn't have a picture
Replace IHVT aka flyback xformer--part#257805 or Asti 2078.
Dec 29, 2006 | RCA F32650 32" TV
POWER PROBLEMS????????
If the set trys to turn on and makes noise three times then you hit the switch again and it will try to come on again churping three times , its a shorted horizontal output transistor and a bad flyback transformer. And Im sorry to tell you the transformer is no longer available according to RCA. Its a shame. I just threw out a 56" and a 32 " set that needed a flyback and could not get them.. Well good luck ps please rate this thread.
Oct 19, 2006 | RCA P52835LV 52 in. Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
98 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
