Question about Acer AL1916W 19" LCD Monitor
Monitor Flashes Gray, Then nothing
I came home to a black screen yesterday. I turned the monitor off and back on, it flashes grey a few times, but never gives me the picture.
the green light stays on like it has a signal, but there is no picture ( and yes the computer is working fine) I am using an old CRT monitor in the meantime.
Is it toast?
  • vhariprakash Feb 21, 2008
    Hi ,
    Yesterday I purchased 15'' LCD TFT monitor from Acer.
    First time when i started my computer (p4 intel) i got a yellowish faded screen.
    Then i tried to change the resolution to set it to 1280x800 but after not finding this value i tried to set it to some nearest one .
    But this didnt helped me.
    Then the moment i tried to connect to internet and and download some plugin... just a try ...but nothing worked .
    suddenly the screen become flash grey .
    Now when i restarted the system , I can listen the sound only but no vedio.
    I tyried to do Auto reset but still no help.
    still i have a grey flash screen with only audio.
    Please help.
    Thanks
    vhariprakash@gmail.com
It is an LCD i forgot to mention that
Posted on Feb 17, 2008
    Problem Solver:
  • 22 Answers
Try to decrease the screen resolution. try to 640 x 480 then raise to 800 x 600. for old CRT monitor maybe have a problem with 1024 x 768. if decrease not work, then you might have a hardware problem, you need to purchase a new one. try the test first. maybe you can test with your monitor of your friends first :-), if work, you need to purchase a new one.
  • Susanto Wijaya
    Susanto Wijaya Feb 18, 2008
    LCD i think better than CRT, then the problem is in your old vga card. your old vga card cannot display the high resolution. Try to decrease it. consider to upgrade the VGA Card if you now have a new LCD Monitor. Anyway try to decrease first the resolution. maybe 800 x 600 or perhaps 640 x 480.
Monitor flashes different colors
Monitor has been successfully broken with fall.
Aug 31, 2017 | Samsung P2370HD 23 in. TV
Monitor works for a few minutes, then flashes gray
Replace the bad capacitors in the power supply. They are usually visually detectable (tops bulged). The ones that usually good bad in that model are 1000mfd. 16v.
Dec 08, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
Monitor flashes blue light and takes a long time to come on
Disconnect monitor cable from back of the computer and see if u have a error msg on the screen > if u find a error msg like " NO VIDEO SIGNAL"> then ur monitor is fine or else ur monitor is BAD
Oct 20, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
HP vs17x flat screen monitor won't come on, blue light flashes.
Try taking on the back of the monitor and pulling the power plug all the way out of it for about five minutes and then plug it back in and restart the computer see if it solved it thanks
May 27, 2009 | HP vs17c 17" LCD Monitor
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
Monitor flashes on when I turn computer on, then screen black
Your monitor power supply or inverter board have gone bad. Its not your computer video card
Apr 17, 2008 | Westinghouse LCM-19v1 Monitor
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
"Desact.monitor"
my monitor says desact monitor and I dont know what it means.
Feb 12, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
Monitor repeatedly flashes Acer logo and computer display in cycles
We had the same problem with the 17" we bought in Aug. Sent it back for repair. Acer sent it back without fixing the problem. Started doing it again in Nov. This time I called a supervisor and they sent me a new monitor. Well yesterday it started doing the same thing. You can fix it temp buy unplugging it and holding down the on-off switch for 30 seconds. Please let me know if you have a better fix.
Dec 13, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL1916W 19" LCD Monitor Logo
229 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
