Fast Fans nothing else
Turn on power fans kick on high but nothing else happens emachine T3410
  • big cheese1 May 30, 2008
    Did the power supply fix your problem? I am having the same problem now. bj
If your system won't even beep when powered on, your most likely problem is a bad power supply. You can get a new power supply fairly cheap - a good one is here http://www.newegg.com/Product/Product.aspx?Item=N82E16817153023
If you install a new power supply and the symptoms don't change, your motherboard is probably shot.
Posted on Feb 17, 2008
Compressor and fans do not turn on until rev engine
I passed this question the first time I read it, so I will take a stab at it now.
The fans don't come on until the compressor has pumped the freon pressure up to say 150 or 200 psi. And the compressor clutch has to have voltage to engage the clutch.
I wonder if the clutch is going and needs 14 volts instead of 12 to engage ? Or the relay that powers the clutch ?
Speeding up the engine would increase voltage from the alternator.
This is assuming the serpentine belt is tight and everything else is working correctly.
I think I would swap the relay with another and put a meter on that circuit to the ac clutch to see what it takes to engage it.
Jul 24, 2012 | 1992 Buick Regal
What kind of cpu fan do i need if my fan is not working on my emachines T3410
Fans are made for a socket, and you have a socket 754, you can get any fan for this socket, when you go to buy one, you will see they are sold by socket.
Feb 04, 2010 | E-Machines T3410 (RBT3410) PC Desktop
Yellow Light
Emachines are bad for having failed power supplies and motherboards. Test your power supply, watch this video.
http://www.metacafe.com/watch/729606/how_to_test_your_computers_power_supply_psu/
Aug 03, 2009 | E-Machines eMachines Desktop PC
Emachine T6426 PC..I push power button and fans come on and there is a yellow light where the blue one is suppose to be..Nothing else happens??????
Hello there:
If all of the fans come on, check to see if the fan is blowing on the power supply if it is not than you are going to have to replace the power supply. please keep me informed cause there is more that we can do if needed ok.
best regards mike
Here's a wierd cooling fan issue
Thats not too weird as the car would kick on the fans at full speed when it detects a problem with the sensor. Your ECU is not reading the sensor properly and needs to be checked by Ford. I hope this helps you.
Jun 21, 2009 | 1999 Ford Taurus
No boot, New PS, Green light on MB lights, No Fans running
Bottom line: Either your power supply or (hopefully not) the mother board has gone bad.
Replace power supply (remove old one), take to local independent computer shop, ask them for new unit. Should be around $50.00. - no more. After reinstall, if still no fans, boot, etc. Replace motherboard or buy a new machine. MB's installed probably will run you around $250.00-ish.
Good luck.
gurutim
Mar 21, 2009 | E-Machines eMachines Desktop PC
Dead emachine t3104
In most cases this means that your motherboard is fried, but if you can get your hands on another power supply, try plugging it into your board just to be sure.
Feb 19, 2009 | E-Machines eMachines Desktop PC
Emachines doesn't start
Thank you for choosing Fixya.com
It could be a number of things but what i believe its going to be is the motherboard. The motherboard is not getting the power probally because the connections are bad. Are you getting any beep codes? or is it just powering up the fan? If it gives a beep code respond with that but i would almost bet its the motherboard.
Feb 16, 2009 | E-Machines T3410 (RBT3410) PC Desktop
Emachine problems
Hi..
Since your computer is working but no display at all. Hope this steps would be helpful in your problem.
1. Turn on your computer, If the problem works again and no display.
2.Turn off your computer by pressing long your power botton until the fan stops properly.
3. Unplug you computer 220volts power chord at the back of your computer.
4. Reconnect again the 220volts power chord after 1 minute.
by. arnold@supportsave.com
Jun 04, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
307 people viewed this question
David Payne
David Payne
