Question about Pyle (PLVW1045R) 10.4 in. Car Monitor
Brand new 19" fold down pyle lcd monitor
The monitor is up and i hooked up the wiring i have the map lights working the rca outout is working i put it to the my other monitor and the picture is working there fine also there is a small blue light on at bottom of the unit behind the buttons kind of behind the i.r window 4 remote but it doesnt power the screen on at all nothing almost like there is a on off switch that not there have good power tried several grounds please if anything you know what to do thank you
    Champion:
    Scholar:
  • 216 Answers
Atdlee@netzero.com
Posted on Feb 25, 2008
Can a monitor be hooked up with my laptop
Yes, but i ur laptop must have a VGA 9-pin, or a VGA 15-pin output, so just put the wire in that output, and into your monitor, and it should work
Dec 22, 2011 | Proview PL913S 19" Flat Panel LCD Monitor
Hooked the damn thing up power my subs wonderfully for that evening, and all day today, got in this evening and nothing, checked the amp and red light, ok, fine, checked the manual, says the light protects...
probably something corssed in your speaker wiring. be sure that you did not exceed the ohmage capabilities of the amp, and that no speaker wires are crossed, or shorting out on the frame. if you have too many speakers hooked up, that can reduce the ohmage, and your not supposed to go below 2 ohms -per channel, or 4 ohms bridged mono.
Mar 13, 2011 | Pyle PLA2200 Car Audio Amplifier
Pyle Academy 2300 watt amp not working =(
wrap a striped speaker wire around the back of the rca out put on your cd player and for the record that aint a 2300 watt amp its like a 300 watt amp
Mar 30, 2010 | Pyle PLAM2300 Car Amp
RX-V465 output HDMI 1 will work but HDMI 2-4 won't, also when I hook up Wii via rca to receiver only get sound no picture.
This receiver has only one HDMI output, but 4 HDMI inputs. If some inputs don't work, try connecting the equipment (DVD for example) to HDMI input which works with other equipment....
For the RCA (composite) video input - it won't work, because this receiver don't have any video processing circuit.
So HDMI input video goes to HDMI outout connector.
Composite (RCA) video input goes to Composite outout and no other video output.
S-video input goes only to s-video output.
Dec 20, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
Will not play on new RCA LCD TV tried different
Try hooking up your sony handycam to a different monitor or tv to make sure it is putting out a good video signal using an S-Video cable. Then once you know your cords are good and you have a good video signal, hook it back up to the RCA LCD unit. If it is still not working make sure that the RCA LCD is set to receive the Hi8 signal via the S-Video cable. There may be a switch or menu setting on your RCA LCD to accept the Hi8 signal or also refered to as S- Video.
I hoped that helped and good luck!
Nov 16, 2009 | Sony Handycam CCD-TRV68 Camcorder
Need info
yes and no. wou will need a vga to RCA video adaptor, then you will need to get something to play the sound through. after thats sorted out it should work. I use my monitor to play my xbox360 using external speakers
Jan 27, 2009 | Gateway FPD1975W 19" LCD Monitor
Sceptre x9g nagaV
you cannot connect your vga monitor to your rca vcr its not compatible unless you have a vga to rca converter
Nov 03, 2008 | Sceptre X9G-NagaIV 19" LCD Monitor
PC flat screen monitor to DVD player hook-up
It appears that the monitor was designed to work with the display circuits and software driver on a Personal Computer. There is no circuitry in the display to handle the out put of DVD player. A smart TV has the circuitry. the display does not.
Nov 26, 2017 | Princeton Digital VL1916 19" LCD Monitor
Rca vcr
there a a bunch of different ways. 1) if you don't have a cable box hooked up to this tv,plug the main cable wire into the vcr input then the vcr outout to the tv.2) if you do have a cable box, plug the main cable into the cable box input, then the output to the vcr input, then the vcr output to the tv. put both the tv & vcr on channel 3 for this connection. [ you must have the vcr on channel 3 to record from the cable box!] 3) if you have aux line/video or source inputs on the back of your tv,you can hook up rca cables [ red, white,& yellow ] from the rca outputs on the vcr to the tv inputs.
hope this helps
wg
Feb 04, 2008 | RCA VR637HF VHS VCR
Pyle (PLVW1045R) 10.4 in. Car Monitor Logo
540 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
