Question about Compaq Presario X1000 Notebook
How to clear and restore?
I think I have a virus and need to clear everything off my laptop and restore it to the original settings. How do I do this?
    Problem Solver:
  • 10 Answers
If its a virus infected from a USB then you have to only restore your settings by start>Allprograms>Accessories>systemtools>systemrestore.
Then restore your system to earlier time on which the system was not infected
Posted on Feb 17, 2008
    Sergeant:
  • 406 Answers
Just use your recovery cd it will restore to original state.
[ If you have a data on your hdd you will loose it]. After restoring install antivirus and update it regularly.
Best Regards
  • 31 Answers
Your notebook should have came with a set of recovery CDs. If so you can recover your PC with the following steps:
  1. If the PC works, back up all data files that you want to save onto removable media, such as a DVD. Remove the backup DVD you have made.
  2. Press the Eject button on the disc drive, and wait for the tray to open. Insert Recovery DVD disc #1 and close the tray.
  3. Turn off the PC.
    • If the notebook works: Click Start on the taskbar, click Turn Off Computer , and then click Turn Off . Or
    • Press and hold the On button approximately 5 seconds until it turns off.
  4. Disconnect all devices.
  5. Press the On button.
  6. Recovery starts; wait for the onscreen instructions to display, and then follow those instructions.
    • For standard recovery, press R . Select Next to proceed with the System Recovery. Select Yes to start the recovery. Insert the remaining recovery discs when directed. Or
    • For full System Recovery, press F . Select Yes to perform a full System Recovery. Insert the remaining discs when directed.
  7. When the recovery program finishes, the drive tray ejects. Remove the disc.
  8. Click Restart.
  9. After it restarts, a series of startup screens appears. To proceed with the initial Microsoft Windows setup, complete the setup screens that appear.
  10. Complete the startup, finish the registration process, and wait until you see the desktop.
  11. When you have access to the Windows desktop, connect to the Internet as soon as possible to update the DEC software as follows:
  1. Update the system virus definitions .
  2. Get the latest critical system updates using Microsoft's Windows Update .
  3. Update the HP software on the system .
If you don't have any CDs you could try the F10 key to see if you have the contents of the CDs hidden on your hard drive. It is the same steps as above except instead of inserting a CD you would use the following as step 2:
When the Compaq logo appears, press the F10 key on the keyboard. (You have only a few seconds to press the F10 key before the normal startup process continues.)
If you this doesn't work and you are certain you don't have your recovery CDs you can get a new set directly from Compaq from the following site:
https://warp2.external.hp.com/driver/dr_country_select.asp?Product=438985-001&lang=en&cc=us
Restore factory default
Check to see if there is a system restore setup for a previous date, this will allow you to roll-back the changes made. You can find this under the control panel.
If you want to restore back to the original windows settings, you need to reinstall windows from DVD or CD, these are backups made when you first got the laptop.
Aug 08, 2014 | Lenovo ThinkPad SL500 Notebook
I have a toshiba satellite L645D how can I format it to the factory settings like it just came out of the box.
When your Toshiba Satellite laptop goes on the fritz, there are several instances where the best solution is to delete everything and start over. If your system frequently crashes or you can't remove a specific virus, you may want to restore the laptop back to original factory settings. While the easiest way to restore the system is to use the operating system restore disc, it is possible to restore the system without it. Each Satellite laptop also includes a hard drive recovery utility that lets you restore the operating system without the restore disc.
1.Take account of any files or programs you still want to use after the Toshiba laptop is restored back to its factory settings. Transfer the files to a backup location, such as a USB flash drive or external hard drive.
2.Restart the Toshiba Satellite laptop's operating system. Wait for the Toshiba logo to appear on the screen.
3.Press the key that brings up the hard drive disk utility menu. Depending on the specific model of your Toshiba Satellite laptop, the key will either be "0," "F1," or "F8."
4.Press "1" or click "Restore Original Factory Image." Click "Yes." Select "Next" to begin the restoration process.
5.Restart the Toshiba laptop computer when the restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
6.Transfer the backup copies of the data you saved earlier back to the Toshiba's hard drive. Re-install any programs you need, such as your software firewall or anti-virus tool.
I hope you find it very helpful. Thanks.
Sep 09, 2011 | Toshiba Computers & Internet
Cant restore to factory settings tried 0,f1 and f8 none work
1. Take account of any files or programs you still want to use after the Toshiba laptop is restored back to its factory settings. Transfer the files to a backup location, such as a USB flash drive or external hard drive.
2. Restart the Toshiba Satellite laptop's operating system. Wait for the Toshiba logo to appear on the screen.
3. Press the key that brings up the hard drive disk utility menu. Depending on the specific model of your Toshiba Satellite laptop, the key will either be "0," "F1," or "F8."
4. Press "1" or click "Restore Original Factory Image." Click "Yes." Select "Next" to begin the restoration process.
5. Restart the Toshiba laptop computer when the restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
6. Transfer the backup copies of the data you saved earlier back to the Toshiba's hard drive. Re-install any programs you need, such as your software firewall or anti-virus tool.
I hope you find it very helpful. Thank you for using fixya.com
Aug 16, 2011 | Toshiba Satellite Pro L300 Notebook
Selling my Toshiba laptop and I want to restore it to default/factory settings. When this was bought did not come with a disc.
Aug 16, 2011 | Computers & Internet
Computer keeps saying that a recent hardware or software change might be the cause tried everything
Set your notebook to be restored to an earlier date with the installed software.
So choose to open the control panel , click on BACKUP/RESTORE , open the settings and choose the set up date and click to restore.
If there is no response after the restoration , then you will need to reinstall the OS.
Clear your PC of any virus /malwares with a virus scan.
Dec 24, 2010 | HP Mini 1000 Netbook
My laptop can't start Windows. The auto fix is not working and it says I don't have a prior restore point. I'm thinking I will need a new laptop, but figured I'd try posting this first.
> I think that I will need a new laptop.
No!
All you need to do is to "backup" your files (E-mail, contacts, music, picture) to some external device, e.g., USB memory-stick or CD/DVD-writer.
Then, reinstall Windows, using the original set of "System Restore" CD/DVD disks,
install an anti-virus, run Windows Update several files, and reload your files.
Or, any computer-store will do the above, and charge you $50 to $100.
Definitely *NOT* (yet) the time to purchase a new computer!
Dec 05, 2010 | Microsoft Windows? Vista Home Basic...
My compaq pc start & freeze when hp sign come on
Hi. I think the problem on this one is with your operating system, try scanning your computer with your anti virus software and restart your computer. Also you should uncheck some softwares that is on your starup programs so that it would not load every software on your computer everytime your computer startsup. If this trouble shooting step doesnt work you can use your recovery cd to restore your system back to its original settings, just like the first time you got it, but you have to backup every important files that you have on your computer to an external storage device, because when you perform a recovery it will delete everything on your computer to restore it on the original factory settings. I would also suggest that you call HP tech support dept for further assistance in case you need it. Hope this helps
Jun 03, 2010 | Compaq Presario Notebook
Given E-Machine 366I2. Will not take new hard Drive
Shouldnt think it was the cables since you got as far as you have. Could be a problem on the drive and you might want to do a low level format to make sure. Drive type should not matter. Western Digital has a low level format utility on there site. wd.com
my other thought is that for some restores you have to have the exact components present that originally came with the machine. so, unplug everything but keyboard, mouse and video. put back to original amount of memory.
use a windows disk to do restore from scratch instead of restore disk. good luck.
Jan 02, 2010 | Computers & Internet
I have an Acer laptop to work on that has numerous viruses on it and I was wondering if Acer D2D recovery will remove them?
system restore vs system recovery:
a system restore will restore the system to a set point in time. this will not remove viruses.
a system recovery will reinstall windows to its original factory state by utilizing a recovery partition. this will remove viruses. however, it will also remove any data and software that has been installed on the system.
back up if needed but keep in mind that you could potentially be backing up viruses. especially if the user wants to back up music that was gotten from a peer to peer site such as limewire. this downloads are typically ripe with infections so do so at your own risk.
it is not possible to back up software.
Dec 10, 2009 | Computers & Internet
Windows will not finish loading in any mode and ends with bsod.
You need to re-install the original discs that came with your laptop in order to restore it to the original factory settings, also i recommend going to CNET.com and getting the AVAST anti-virus program, it is free and as long as you use it for personal use, and it is the best anti-virus program on the market, it was also the only anti-virus on the market that was ready for the worm that was set too release on april 1st.........check it out.............hope this helps
May 25, 2009 | Toshiba Satellite M45-S165 Notebook
Compaq Presario X1000 Notebook Logo
185 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
