I need help with my dynalink router i changed the ssid and made a wep key
Hi i need help with my dynalink dywrt54 see i changed the wep key to 64bit acl11 or something like tat and made mi ssid xbox360 rulz and now it says when i connect to it limited or no connectivity my passwords right but now my ip adrease is screwed and i cant play xbox360 can anyone help me plz!!!!
  • 37 Answers
If you changed your WEP encryption then you've changed your WEP key. 64 bit WEP encrytion uses a 10 charater hexadecimal key and 128 bit uses a 26 charter hex key. You can not switch between the 2 configurations and keep the same key.., although some wireless adapter utility programs will generate a new key for you from the same "passphrase". Most likely your key has changed which would give you that problem. If all else fails, set your router back to defaults (open).. and make sure everything connects... then apply your key and be sure all computers and devices use the same key
Posted on Feb 22, 2008
Where to change the DNS settings in Dynalink RTA1025W wireless router?
Logon to the router
2.select the connection type(PPPOE)
4.Save settings
5.Configure wireless setting(SSID,Wep)
Configure pc with the same SSID and WEP
uplug the ethernet cable and check if your are able to connect wireless
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Feb 13, 2013 | Computers & Internet
I've set up the password security for my Dynalink wireless router but now i cant even use the wireless internet pls help
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
May 01, 2011 | Computers & Internet
I was trying to manually the router up as wireless.
If you want to connect to the router wirelessly you need to know the SSID or the Name of the Router (Nework Name) and the Network Key or Wep Key. The Default Wep Key is the 10 digit key located on the bottom sticker of the router. It is near the Bar Code. You can also personalize the Network Key by simly accessing the router. I've listed the steps on how to access the router incase the Network Key on the sticker is not working.
  • Open a Web browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.
  • Click the Home Networking tab at the top of the 2Wire Home page.
  • Click on Wireless Settings. then click EDIT SETTINGS located on the right panel.
  • Here you will be able to fine the setting for your wireless connection
  • You can change the SSID, Wireless Channel, Wireless Security, and Network Key
  • Connect to your SSID by clicking on START then click on Connect To, Select your SSID then it will ask you for your Network Key. Type the Network Key then hit Connect
Rate me if this helps so i can help others
Thanks for using Fixya.
Jan 31, 2011 | 2wire 2700HG-B Router (2700HGB)
Hi i would like the wep key to my router please..
Hello
OK, firstly, your WEP code the a personal security code of the router, which secures your network.
This code is usually on the back, or bottom of the router. If you have personalised the router, you will need to log into the router and change the SSID name of the router. After you have changed the SSID of the router, you will be able to change the WEP code.
Please do not hesitate to let me know if you need any further assistance.
Kind regards
Lock123
Dec 09, 2010 | Netopia 2247NWG-VGx Wireless Router...
Once I have enabled WEP, how do I set up the
Access the setup page of the router by typing 192.168.2.1 in the address bar of your browser.
Leave the password blank.
On the setup page of the router, go to Wireless. Take note of your SSID. You may also change the name of your SSID so that you can easily identify your network.
Then go to Security under Wireless.
Select 64-bit WEP. Type a passphrase then click the generate button.
Take note of the passphrase and wep key.
Then click Apply Changes.
On your wireless computer, you should be able to detect your SSID in the available networks.
It will ask you for the network key, type the wep key. On some computers, simply typing the passphrase works.
I hope this helps!
May 15, 2010 | Belkin (F5D5231-4) Router
I dont know how to change the SSID Name and WEP Key.
You have to change it in the printer settings, not in the router! Otherwise you'll lose connectivity in all the other computers that use this router.
The SSID is the name you gave to your wireless network, and the WEP key is the password you set for your wireless connection.
Oct 28, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
What is a ssid and a wep key. I am dumb.
SSID is the wireless networks name you want to access.
WEP is a special hexadecimal key to secure your network means if you want to connect a wireless network you will have to put this key.
It will be provided by the admin
Aug 12, 2009 | Office Equipment & Supplies
Repeater function
you make a device into ap mode you can get it
Jun 09, 2008 | SMC EZ Connect g SMCWEBT-G
Wlan key for netopia 2247NWG-VGX WIRELESS ROUTER
Hi there!
I believe the WLAN key can be found at your router's set-up page or web ui. Do you know how to access it? If Not, then try to access this link and hopefully this will help you to find it..
http://www.netopia.com/support/hardware/technotes/NQG_112.html
May 04, 2008 | Netopia 2247NWG-VGx Wireless Router...
Setup asistant will not work with Belkin wireless router & computer
Try the manual method.connect router to pc with ethernet cable
1.logon to 192.168.0.1
2.Connection type ; PPPOE
3.type in your username@ISp and pass
4.Save settings
uplug the ethernet cable and check if your are able t connect wireless
if you still have issue use this guide
Cheers !!!
Feb 23, 2008 | Belkin (F5D7230-4) Router (587009)
Computers & Internet Logo
602 people viewed this question
Alun Cox
David Payne
David Payne
