Question about Dell Dimension 4700 PC Desktop
Can not Boot from OnBoard SATA Hard drive.....it keeping looping...
  • 31 Answers
Turn on (or restart) your computer.
When F2 = Setup, F12 = Boot Menu appears in the upper-right corner of the screen, press <F12>.
The Boot Device Menu appears, listing all available boot devices. Each device has a number next to it.
At the bottom of the menu, enter the number of the device that is to be used for the current boot only.
If this works and you want to change the setting permanently do the following:
When F2 = Setup, F12 = Boot Menu appears in the upper-right corner of the screen, press <F2>.
Use the arrow keys to highlight the Boot Sequence menu option and press <Enter> to access the menu.
NOTE: Write down your current boot sequence in case you want to restore it.
Press the up- and down-arrow keys to move through the list of devices.
Press the spacebar to enable or disable a device (enabled devices have a checkmark).
Press plus (+) or minus (–) to move a selected device up or down the list.
Posted on Feb 17, 2008
I added a second sata hard drive to the the computer and now the computer does not see, either one. When I try to boot it says no boot device available. When I look in the bios version a11, under boot...
Is it booting from Second HDD without installing the first HDD. If it booting then shutdown the system and now install the first HDD. If it boots then good and if not then the SATA port on the board have damaged need to repair that.
Oct 09, 2013 | Computers & Internet
Help, my dell xps is now giving me the following message: onboard IDE hard drive not present, onboard UBS floppy not present, and ADD-IN hard drive not present. I'm also getting the message of drive...
It means that these devices are not getting detected by your computer. Try to re-insert all the cables..and then set your Boot options through system Bios.
Mar 27, 2013 | Computers & Internet
I have a Hitachi internal hard drive that i would like to use as an external hard drive to boot from my e-sata port, i have a Toshiba portege and i curently use two hard drives to boot from, one for work...
yes you need power to the external hard drive whether ide or sata possibly depending on your hard drives power supply
12V+5V AC sata Adapter Power Supply HDD HARD DISK DRIVE
hope it helps
Mar 27, 2012 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
Hp nx6110, stays in a boot-up loop
Hi, If you are sure that it's not overheating, then it could be the hard drive.
A boot up loop is an indication that the boot up sector on the hard drive is corrupt and broken. The hard drive tries to find this boot sector to boot up your computer but it can't. It keeps trying to find it again and again and again and keeps looping. Hank
Jul 23, 2010 | HP Compaq Motherboard
I bought a new hard drive for my acer 5100 and it
The different model of hard drive should not make a difference. As long as you are using the same type....IDE or SATA...you should be fine.
If you installed the new drive and now the computer keeps rebooting....you probably need to tell the computer to boot from the CD first and not the Hard Drive. When you first turn on the laptop, boot into BIOS by hitting the DELETE or F2 key....it is normally the Delete key.
This will boot into BIOS where you can find the BOOT OPTION menu and select the CD as the first boot device. This will allow the computer to boot from the Windows CD you should already have in your cd drive.
If this does not help.... I would take the new hard drive out and boot the computer without any drive installed. If you are still in a reboot loop, the problem is not with the hard drive and more than likely an issue with the RAM. To rule out the RAM, take one stick out and see if that makes a difference...repeat with the second stick....
Hope this helps
Jun 04, 2010 | Acer Aspire 5100 Notebook
Hello, I have a Dell XPS 400 system that has a bad hard drive. So I went out and bought a new SATA drive, and it's not detecting it upon boot. When I go to the boot menu on F12, it says something about...
Was the original drive also a SATA? If not, then you would need to enter the bios setup and enable the onboard SATA channels. If the bios had gotten defaulted, as from a dead CMOS battery etc. it could have also caused your original SATA drive to be inaccessible.
Nov 24, 2009 | Dell Dimension XPS 400 PC Desktop
I have a SATA M Hard drive and I would lke to add two ATA HDrives
As long as there is an empty IDE port you can. You will probably have to go into the bios settings after you hook the other drives up & set the boot menu to boot from the SATA drive 1st.
Dec 31, 2008 | ASUS K8V-SE Deluxe Motherboard
PC won't boot if SATA drive connected, drive works fine if plugged afterward
Try Hirens Boot CD. It has a lot of programs on it to detect format etc.
I think your hard drive has a missing or corrupt MBR and it needs to be replaced.
When I have had a hard dive not recognized I hve used Super Fdisk to format and reset hard drive.
On the boot disk
Nov 03, 2008 | ASUS K8N-E Deluxe nVidia nForce3 250...
Won't boot off of the external drive
when u power on your system start tapping F2 key
you wil get system setup screen
it will be somthing like this
Boot Sequence The computer attempts to boot from the sequence of devices specified in this list.
Default Setting:
  • Onboard or USB floppy drive
  • Onboard SATA hard disk drive
  • Onboard IDE hard disk drive
  • Any add-in hard disk drives that are detected (listed in the order that they are detected with USB device usually being detected last)
  • Onboard or USB CD-ROM drive
  • Any other bootable add-in devices that are detected (listed in the order that they are detected with Onboard Network Controller usually being detected first)
Apr 12, 2008 | Dell Latitude X200 Notebook
Dell Dimension 4700 PC Desktop Logo
1,427 people viewed this question
Alun Cox
