Question about Sony VGN-U50 Tablet PC
Reformat the vgn-u50 hard drive
Need to reformat my vgn-u50 hard drive ... need procedure
Sylvania-9-inch-portable-dvd-player- how to bypass login
That is a problem when the computer has been setup for another individual. The only way to get around this problem is a complete replacement of the operating system from scratch.
If you purchased the computer from a reliable store, I would go there and have them reinstall Windows.
If that is not an option; you must purchase a new copy of Windows 10 (2017-18 Version) usually the Pro version. Make certain you get the Latest Windows and NOT an Old version that needs updates.
Personally, I reformat my hard drives to eliminate pervious data lingering on the hard drive. But you can run the new Install over the old if you need to do so. Once you have the NEW Windows installed, you will be directed to answer questions relating to you and that data is associated with your computer, as was the situation when you got this computer from the store.
Jan 12, 2018 | Tablets & eReaders
I need to get a free service manual for this tablet can you help
User manuals are quite easy to acquire free from the manufacturer. Service manuals are generally not available. Google the particular thing you need to do (Ex: brand/model replace hard drive. If there is a repair issue you will need to Google the symptoms, then the procedure for fixing, and finally will need the knowledge/skill/tools to follow the procedure.
May 09, 2016 | Tablets & eReaders
What files am I suppose to copy from my computer?
If you are going to reformat the hard drive then just copy any files that you put on the PC that you want to keep like Word docs, etc. When you reformat the hard drive, the files that came with the PC with be put back on. If you installed any software on the PC then you need the .exe file that installed it, i.e. a CD that has any software on it.
Oct 09, 2013 | Nextbook Premium Series Next7P12
Message missing operating system
This sounds like the main partition on your harddrive was corrupt. You will need to reformat the system.
Using the Recovery Partition:
1. Press [F9] during bootup.
2. Press [Enter] to select Windows Setup [EMS Enabled].
3. Select the language you want to recover and click
Next.
4. Read the ASUS Preload Wizard messages and click
Next.
5. Select a partition option and click
Next. Partition options:
Recover Windows to first partition only.
This option deletes only the first partition and allows you to keep other
partitions, and to create a new system partition as drive "C".
Recover Windows to entire HD.
This option deletes all partitions from your hard disk drive and creates
Recover Windows to entire HD with two partitionThis option deletes all partitions from your hard drive and creates two
new partitions "C" (25%) and "D" (75%).
6. Follow the onscreen instructions to complete the recovery
process.
Make sure to burn off your recovery DVDs as soon as you get you rsystem back up and running so that you have them in an emergency.
Feb 28, 2013 | ASUS X53U-RH11 New
We bought the portege tablet version used and would like to completely wipe it and start fresh. I don't see a way to do that. Please help!
If the hard drive is still intact, press F8 at boot up and run the restore programme. That will reformat the drive and put it back as it was when shipped. If that is not available, place an OS disc in the DVD drive and boot from there choosing "fresh install" to format the drive and start again.
Hope that helps.
Feb 02, 2011 | Toshiba Portege M205-S810 Tablet PC
Bought used toughbook on ebay, no hard drive or OS. using my old hard drive from broken one. get to bios screen, but will not boot up into windows. I'm guessing some drivers may be jacking me up, how do I...
reformat the had drive and install a fresh copy of OS from the compact disc.... once the installation is complete, boot up the computer again... if it works, then every thing is perfect....you can go ahead and install the drivers for your devices in the compter...
please clarify if you have any further troubles in installing the OS in your computer...
May 07, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Need to reformat and add software via usb
Copy containts of CD on to thumb drive or external hard drive thru another computer first.
Dec 11, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
80gigs partition then reformatted and displays only 31gigs
If there are files on the drive that you need to recover, then do not format it. It sounds as though the computer that you put the drive into has an issue where the bios perhaps does recognize the drive correctly. Perhaps that can be corrected by updating the bios in the computer, and trying the drive again. Or you may want to put it back into the original computer, back up the files to other media, and then put the drive in the computer and re-partition.
What does the FDISK - "DISPLAY PARTITION INFORMATION" utility report? Do you have a copy of FDISK? If the partitoins in FDISK add up correctly, then it could just be that the data is corrupt, and windows is just unable to read. If that's the case, you should try a recovery application to restore your data..
Nov 15, 2009 | Dell Tablets & eReaders
I would like to reformat my notebook, but I do not have any of my original disks toshiba portege m200
Get yourself an windows (xp etc) & disk install it,
download all the drivers HERE
put them on a "USB flash drive" or burn to CD..
and load all the drivers after you installed windows.
be as good as new.
is this the information you needed?..
if so pls rate :)
Apr 13, 2009 | Toshiba PORTEGE M200 TABLET PC
Gateway Tablet, BSOD unmountable_boot_volume
you have to go to gateway and download the driver for the SATA controller then save it to floppy or cd then hit F6 durning install then it will ask you for the driver. This Tablet will not see a non-gateway cd if you have the one that came with the tablet then you are good, but if not you will need to do this for the current drive or if yo upgrade to newer drive. Hope this get you started, I had this same problem and I thought it was my motherboard was bad because it would not see the hard drive during installation. This fixed my issue with the drive not being seen during installation of the OS.
Mar 28, 2008 | Tablets & eReaders
Sony VGN-U50 Tablet PC Logo
95 people viewed this question
Top Sony Tablets & eReaders Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Sony Tablet and eReader Expert? Answer questions, earn points and help others
