Question about Honeywell HZ519 Baseboard Heater
Heater I don't know how to work it
Just fixed one, you will need a T-15tr driver, which is a security torx screw remover. Open back cover behind controls, check for
any lose wires. Heating element wire had become disconnected on the one I repaired. P.S. you will need an extension for the bit if it is just the bit, and not a screw driver.
Posted on Mar 07, 2008
My space heater stopped working and i don't know where to start it might have something to do with a faulty outlet. Thank you
If you have power at the plug then the heater element or timer is burned out. Take your multimeter and in the ohms position check the male ends of the plug for continuity make sure the timer is in the on possition .
Mar 03, 2013 | Heating & Cooling
I have a mastertemp pentair heater. No error codes. Pool heater works fine-- spa heater button will not light or operate. Any sugestions?
Since I don't know exactly what model you have I can only suggest you call the Pentair technical support at 800-693-0971 andthey should be able to help you figure this issue out.
I hope this helps.
Sep 11, 2011 | Pentair Mastertemp Pool & Spa Heater Dual...
Capacitor needed
I don't know what capacitor you need but if it is part of the Sta Rite heater then I would call Sta Rite technical support at 888-782-7483 and they could likely help you come to a resolution.
Please let me know how this works out. Thank you.
Sep 02, 2011 | Sta Rite SR400LP Max E Therm Pool Spa...
I have a 1991 40 gl and it fell through the floor which is like 2 ft off the ground. turned the water off and replaced the pipes it has its own lever type power supply with the screw in fuses 30 amp (2) of...
You have 2 problems with several possible causes:
You have 10-year-old electric water heater that was reinstalled after falling down, and doesn't heat the water.
And you have no hot or cold water pressure, and no pipes are leaking.
1) First problem is lack of water pressure throughout house.
Turn on outdoor spigot nearest to water meter.
This spigot will tell you if problem is inside the house or between the house and meter.
If spigot runs full force, then you probably have clogged pipe where water heater connects to main cold line, or the main shut off valve got clogged with sediment that broke off inside the pipe when you were working on water heater.
Open and close shut off valve to see if that helps. Then disassemble pipes and track back the problem. Put pressure gauge on water heater drain valve to watch pressure drop when turning on indoor faucet.
Read following information:
http://waterheatertimer.org/Low-hot-water-pressure.html
Water heater doesn't work:
Test across wires at top of heater to see if you are getting correct voltage:
If tank is receiving correct voltage, then no hot water puts suspicion on upper element or upper thermostat, or both.
Open following link for electric water heater troubleshoot steps:
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Jul 30, 2011 | RELIANCE ELECTRIC WATER HEATER
I have a whirlpool water heater mod. Fg1f4034t3nv. Igniter will not work'.instructions missing. Have all lines. Etc disconected how do I get assembly out?
I don't know because I can't see it, and I don't have manual.
But I can give you resources:
Call Whirlpool:
(877) 817-6750
Whirlpool is usually Craftmaster which is American which is AO Smith.
http://www.hotwater.com/water-heaters/residential/conventional/gas/
Age of water heater shows on serial number: first two digits should be year, second two digits should be week.
The market is always changing.
Find manufacturer using label on side of tank, find manual with parts diagram, and order burner parts. Whirlppol site does not have manuals.
http://waterheatertimer.org/Water-heater-manufacturers.html
It might be cheaper to install a new water heater yourself from box store for $330.00
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Absolutely feel obligated to upvote the help.
Or take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 05, 2011 | Whirlpool Water Heaters
I have a heater brand pro com but this don t work
You Have a bad thermocouple.
Follow blue word manual for your manual.
It part 24_1.
Please hit accept, this is how we get paid.
If you need more information Please post back
Nov 27, 2008 | Procom ML300HGA Heater
Led flashes all the time heater won't start
some how the hot and neutral became reversed,i don;t know if it happened when a breaker sparked in the box or what . i reversed the hot and neutral at the input of furnance abd it is working at this time.
thanks for your help
Nov 24, 2008 | Goodman GMS90703BXA Heater
Honeywell HZ519 Baseboard Heater Logo
315 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
