Question about HP OfficeJet 6110 All-In-One InkJet Printer
Original jam message
Hi! i get an original jam message on the display as soon as i turn it on. i checked it all over there is no paper but the message is still on. if you have any tips on how to fix it please respond!
  • happyjoyous Feb 19, 2008
    I have the same message - Paper Jam - and tried this fix recommendation from HP.  But, didn't work.  My printer makes a clicking noise and the printer cartridge sled seems stuck.  Any suggestions?
I am having same problem with my HP 6110 ALL IN ONE .....anybody can help please.
Posted on Sep 27, 2008
  • 31 Answers
A semi-full reset returns the user settings to the factory defaults.
It also deletes the following information:
* Language and country settings on some models
* Fax logs
* Fax headers
* Fax speed dial information
To perform a semi-full reset first unplug the power cord, then press and hold the "#" and 6 buttons on the front panel keypad while plugging in the power cord.
Posted on Feb 17, 2008
My HP Laserject 5100 Printer has the Paper Jam Problem. After that, I check printer. But i haven't seen any paper jam. When i print out, nothing show on paper and show the paper jam.. How to fix?
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Jul 04, 2011 | HP LaserJet 5100 Printer
I keep getting a carriage jam error message. There doesn't appear to be a jam, but I am unable to clear the message and print anything. Also the display screen reads original loaded. No idea what this...
Check the location of the ink carriage. If a piece of paper gets wadded up under this or something else is obstucting it you will see this error.
The original loaded message comes up when a sheet of paper is in the scanner tray.
Apr 01, 2011 | HP Officejet 7210 All-In-One InkJet...
My hp 7400 displays a message carriage jam
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
Sep 20, 2010 | Office Equipment & Supplies
Hello, I have a Brother Fax 560 (Plain Paper Fax). I am having difficulty receiving faxes. It is not transmitting on the receiving end. What is the problem?
Hi Despite the increase in texting, email, Facebook and Twitter, we still hang on to our fax machines. They are perfect for sending copies of original documents despite document jams, buying ink or special paper, maintaining a phone line--we love 'em. Basic problems like paper misfeeds can be troubleshooted through the use of some basic steps.
Check the Message
  • Check the messages on the display of your Brother fax machinemag-glass_10x10.gif. The messages will be pretty self-explanatory such as "Insert Doc, Again" or "Please Supply Paper." "Insert Doc. Again" means that that the documents weren't placed on the feeder correctly; just follow the instructions and try again. A message like "Please Supply Paper" will simply mean you need to replenish the paper. "Memory Overflow" is probably the most cryptic. It just means that the memory capacity was exceeded and it has stopped recording. Press "Enter" to register the documents in memory and to complete the operation.
  • Misfeeds
  • Clearing an original's misfeed by pushing down on the release lever to open the front panel. Remove the failed original and close the panel. To clear recording paper that's gotten jammed in the paperfeed, open the turn guide and remove the paper. To clear paper from the transport unit, which is in the top, open the cover, remove the drum and toner. Lift the guide and remove the paper by pulling upwards. Paper can get stuck in what is called the Fixing Unit. Open the top cover. Again, remove the drum and toner. Open the Fixing Unit cover and remove the paper by pulling it back.
  • Aug 02, 2010 | Brother IntelliFAX 560 Plain Paper Fax
    I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
    If paper is jammed, a Paper jam message will appear on the control panel display.
    Follow these steps to clear the jam:
    1. Gently pull any jammed paper out of the output tray or sheet feeder.
    2. If the paper is stuck inside, turn off the Epson Stylus CX.
    3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
      alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
    If paper jams inside the Automatic Document Feeder, clear the jam as follows:
    1. Open the Automatic Document Feeder cover and remove any jammed paper.
    2. If necessary, lift the document cover and remove any paper that has jammed inside.
    3. Press OK to clear any messages on the display screen.
    Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
    Stylus CX9400 Photo Printer: paper jammed inside printer...
    May 18, 2010 | Epson Stylus CX9400 Photo Printer
    Kodak All-in-one Printer has Paper Jam problem
    Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
    Sep 15, 2009 | Kodak ESP 5 Printer
    HOW DO I REMOVE JAMMED PAPER
    Please turn the printer Off and then ON , till you see the error message of " Paper Jam" check all the flags on paper path, specially on Fuser Assembly.
    Turn printer OFF, pull all trays out gently,
    Disconnect cables to network or PC. turn printer ON,
    check the message gets repeated - paper Jam,
    Conclusion : There is some bit and piece of paper activating flags,
    take all toners out gently and transfer Drum, look into printer, and
    lift the paper path under the toners, push the door a little bit and unscrew the paper path and can see a piece of paper on right side..
    Pull the paper out and screw bach. put every thing back in their original status.
    Now the printer will work and there will not be any papers..
    Jul 31, 2009 | HP Color LaserJet 2600n Printer
    Hi my fax displays the message CHECK 5100
    my fax Canon JX201 displays the message CHECK 5100
    Jun 26, 2009 | Canon FAX-JX200
    Display ... ''clear paper jam''
    First clear the possible paper jam using a air blower on the rollers and sensors most possible cause is the paper dust which block the sensors. then do a power cycle by unplugging the cable and leave it turned off for 5 mins and then reconnect, it should take care of the issue.
    May 04, 2009 | Canon Office Equipment & Supplies
    HP OfficeJet 6110 All-In-One InkJet Printer Logo
    580 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
