Question about Linksys Wireless-G WRT54G Router
I cannot get my new computer to recognize the linksys router I have Model No:WRT54G
I have A new hp and it will not connect to the internet. I have the software installed in the desktop pc in the next room . The modem and router are all connected . The other desktop is running out of port 1 already and has internet access. I need help getting the other pc to accomplish internet access. Thank You, Leigh
    Brigadier General:
  • 6,966 Answers
Try to manually configure the new HP (2nd desktop). Go to your networking properties and use:
IP Address - 192.168.1.13
Subnet Mask - 255.255.255.0
Default Gateway - 192.168.1.1
Additionally, it may be to your advantage to set the Internet Explorer and/or Firefox to Auto detect proxy settings.
Incidentally, if you are using WEP or WPA or MAC security filter on your network, you need to enter the same key (code) in the new HP.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 17, 2008
Do a search for linksys easylink advisor. it will guide you through setting up your second computer.
Have dsl connection, works fine. when linksys wrt54g router is correctly installed, no internet connection! ran diagnostic, all is fine, but no internet connection found-can't seem to upload new firmware...
Turn the DSL modem off.
Turn the Linksys router off.
Turn your computer off.
Turn the DSL modem on.
Wait for its lamps to settle-down to a consistent pattern.
Turn the Linksys router on.
Turn your computer on.
Wait for it to settle-down.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
You should get output somewhat like: Default Gateway .... 192.168.123.456
if you have a connection between your router and your computer.
If you have that connection, you should be able to upload new firmware from your computer to the router.
Feb 20, 2011 | Linksys Wireless-G WRT54G Router
I have a Linksys WRT54G which I have hooked up to my older Dell computer successfully. The signal is excellentfor this one, called "Bob" for clarity. I am trying to hook up to "Bob"...
Sounds like you may be experiencing excessive interference in the WIFI space. Try setting the linksys router to use a different wireless frequency. (normally the available ones are 1 - 11).
Jan 11, 2011 | Linksys Wireless-G WRT54G Router
Internet cable is not recognized or is not bieing found in the pl
Have you tried logging into the Router and changing the settings. You might still have and IP address inside that will not work for you . Look for WAN setting..
May 12, 2010 | Linksys Wireless-G WRT54G Router
No internet connection...
Check your cable-connections:
AC power to the router.
Cable-modem <----> WAN-port on the router.
or
DSL-modem <----> WAN-port on the router.
LAN-port on the router <----> Ethernet port on your computer.
Windows 7 should show that you have obtained an IP-address,
starting with '192.168.' that was supplied by the router.
Note that some ISPs (Internet Service Providers) will require
that you tell them the MAC (Media Acccess Control) address
of the _ROUTER_ before the router will be able to connect,
through the ISP's services, to the Internet. Contact your ISP.
Jan 09, 2010 | Linksys Wireless-G WRT54G Router
Linksys WRT54G Wireless Router Issue Allows 1 Computer at a time
Your router my not be DCHP enabled or it might not be assigning the IP addresses either.
I would do a reset and start all over with your security settings and see if that works. Worst case scenario you could always turn security off when your parents or others are there.
Link HERE for more Linksys information
pls rate 4 stars
Dec 01, 2009 | Linksys Wireless-G WRT54G Router
No internet connection to main computer when router connected
If you are getting lights on the Internet LED. Go to the router's setup page 192.168.1.1 and put in your username and your password if you are on DSL. For cable connection try to reset your router by resetting the router
Jun 04, 2009 | Linksys Wireless-G WRT54G Router
Need to connect my old Linksys modem to a new Motorola SBV5121 cable modem.
THE MAIN LINE GOES INTO THE WAN PORT FROM THE MODEM PROVIDED FROM YOUR MOTOROLA .....THEN THE 4 PORTS ARE TO CONNECT THE COMPUTER ....HAVE FUN
Jun 02, 2009 | Linksys Wireless-G WRT54G Router
My linksys wrt54g v8 will not recognize the internet
Try to do a hard reset on the router. Hold down the button on the back of the router for 10 seconds. This will clear all of the settings out of its memory. Then try to connect again. If this doesnt work power down both your router and your cable modem. Let them sit for a minute and then plug in the modem and wait 30 seconds. THen plug in the Wireless router. The issue should resolve itself.
Gary
Jan 24, 2009 | Linksys Wireless-G WRT54G Router
My local area network will not recognize my new laptop
You will find that the laptop has it;s firewall turned on. Temporarily disable it (assuming that your router firewall is enabled) and it will work.
Dec 11, 2008 | Linksys Wireless-G WRT54G Router
The Computer doesn't recognize the Router (And Yes. the wireless switch is turned on)
DON'T use the software.
Are you trying to connect by way of ethernet cable or wireless?
Either way you do it, you do NOT need that crap software. 90% of the time, that software interferes with everything. Up to AND INCLUDING preventing your system from connecting to the router.
Before you can get any help with this, you will need to give us more information about your setup.
NOTE: We CAN NOT POSSIBLY figure out all of the variables if you do not give them to us. So don't go marking my post as "Thanks for trying" just because your problem is not solved in the first post.
Instead, if you want answers, you're going to have to be more specific.
I see a Linksys WRT54G wireless router. Is there a version number on there?
Example: WRT54G v3 (Mine.)
You're also going to have to tell us more about your computer. Is it Windows XP? Service Pack 1/2? Windows Vista? Linux even? (Give model numbers if it's a pre-built system from an OEM manufacturer such as HP, Dell, etc.)
Then there's the internet connection. Cable internet? DSL? Satellite? Give us MODEL NUMBERS of the equipment they have issued to you for your internet connection.
Then tell us how you have things connected. Wireless? Ethernet cable? What is connected to what?
See what I mean?
FULL details bring quicker resolution of your problem. I will be monitoring this post as you seem capable of providing this information to us. When I see more complete information, I will help you further from there.
Thanks. :)
Cyryl
Nov 21, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
120 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
