Question about Epson Stylus CX9400 Photo Printer
Excess ink use
The priner uses to much ink
  • 1 more comment
  • lkm77 Feb 27, 2008
    printing mulitple copies
  • zaschke Jun 04, 2008
    The CX9400FAX prints well, But when I change an Inkjet cartridge it takes 3 times to clean the Nozzle head. The Inkjet Cartidge will allow approximately 5 nozzle cleaning. This include the color as well.
    Now the nozzle is block can it be clean or the nozzle be repleace?
  • Anonymous Mar 22, 2009
    Do not buy this printer
    Genius:
  • 1,447 Answers
Contact epson regarding this so that they can give you appropriate resolution, if it uses too much ink chances are you are having a hardware issue with the product
Posted on Apr 04, 2008
How do put ink in a priner when its finished please
RTM - Read The Manual
Get online and got to www.google.com Inthe google search box type: "HP Support" (without the quotes andput your manufacturer name before Support). Look for downloads anddrivers. Enter your model number and operating system whenrequested. Look for Manuals and documents.
Apr 23, 2012 | HP Scanjet G2710 Flatbed Scanner
Can't print both red lights brinking
Hold down the power to shut off. It is possible the Ink level has come down. Before you shut down Look in the properrties of the priinter in the PC for the ink level status. If low use the maintenance key to hold down in changing the INK cartridges.
If not remove the printer and uninstall the printer software, the install back and connect the printer to be detected and installed.
Now the priner must work correctly.
Aug 29, 2010 | Epson Stylus C66 Inkjet Printer
Epson stylus c64 does not print in colour only black and cyan, no magenta or yellow but the ink levels are going very quickly on all. Where are they going?
I find by leaving the printer on stand -by it not use as much ink dont swich your priner off, because every time you swich in on it will star cleaning the heads on your printer and that will use lots of your ink up
Jan 23, 2010 | Epson Stylus C64 InkJet Printer
Hp office jet 4215xi how to check ink level
HI
you may get the ink levels in several ways,
1) printing a test page.
2)if you got HP solution Center with the software cd of the printer ans it is installed in the computer,you can easily check the ink levels there.
3)sometimes ink levels option is available in the priner drivers in the printers and faxes in the control panel.
4)right clik the printer icon and then goto properties and then you will find tabs to check the ink levels,it might be in the service this device under the maintenance tab.
Feel free to contact me if there's any query.
Aug 03, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Printer is smudging ink/transfering onto innapproriate pages
take the ink cartridges out; clean them with a q-tip and rubbing alcohol, clean each cartridge; let it dry and then run a test page
May 04, 2009 | Xerox Phaser 6130 Laser Printer
Can't change ink on dell 810. what do I do first? I don't know how to change ink in dell 810,I couldn't see how to take old one out as well and how to put new one please
Lift the priner unit lid on the printer llift he print cartridge lid,
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
Press down on the ink cartridge lever to raise the ink cartridge lid.
Remove the old ink cartridge.
Dispose of the old cartridge properly.
If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
Insert the new ink cartridge.
Snap the lid closed.
Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed. Let me know if you have any questions.
Apr 14, 2009 | Dell 810 All-In-One InkJet Printer
Machine is ok before their was a power interruption,
E04 => E04 Ink Overflow
If the Overflow sensor detects excessive ink in the Squeegee • If the sensor detects excessive Overflow ink in the Squeegee
unit.
Remove excess ink from the Drum.
You must clean the cylinder, clean the ink (sensor ) and remove the excess ink on one side and / or along the sides of the cylinder.
Dec 19, 2008 | Riso RZ220 Duplicator
Epson Stylus CX6400 All-In-One InkJet
try doing 4 head cleans and then leave the printer powered up over night. Don't print or anything else after the head cleans until the morning then do one more head clean (this soaks the print head in ink overnight and then the final head clean should clear any obstruction. If the printer still refuses to print in colour, you could try replacing the cartridges anyway as they can be faulty. The only problem is thaty sometimes it's cheaper to buy a new priner. (how silly is that!) By the way, are you using compats or epson original ink carts?
Nov 03, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Epson Stylus CX9400 Photo Printer Logo
44 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
