Question about Xerox WorkCentre XD100 All-In-One Laser Printer
Xerox xd120f error code
I have an error code flashes E than 2.
I have followed all steps from xerox website and can not clear it or get this to work.
Xerox service tells me that the no longer support this machine.
I hate to have to go out and buy a new machine as I only just bought new Ink cartridge a couple months ago.
  • scott809 Feb 17, 2008
    I took everything apart a second time and found the problem looks like one of the white sticks for the access door wasn't attached. Go figure. Thanks for your quick replys! will
    Master:
    Sergeant:
  • 462 Answers
Hello sir
Posted on Feb 17, 2008
  • 2 more comments
  • Mohamed Ismail
    Mohamed Ismail Feb 17, 2008
    Please mention your complete details of your machine.
  • Mohamed Ismail
    Did you try the basic steps to rectify. Basic steps like removing all the papers while turning on, checking for jammed papers, sometimes even removing the ink and turning it on for a few seconds then putting back the ink cartridge..!!!
    Waiting for your reply...!!!
  • Mohamed Ismail
    As to the E2 codes that is a "watchdog" timer error and can mean anything but I would be willing to bet the cartridge caused it...!!!
  • Mohamed Ismail
    Thats great, thanks...!!!
Xerox Phaser 8560MFP/N System error 09,038.46:950
Hi mary_ballling:
Here is you problem.
9,035.4x through 9, 038: Fault codes associated when ink count flags are stuck
after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41, where x= 5
for cyan, 6 for magenta, 7 for yellow, and 8 for black.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Are the ink sticks all Xerox ink? Go to Step 2.
Run clearISCfault test to clear the error.
2 1. Manually verify that the ink stick is able to
advance in the ink loader chute.
Go to Step 3.
Remove any blockage and/or replace the ink stick.Run
3 1. Run the appropriate Ink Melt [1, 2, 3, 4]
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
2. Did the test pass?
Replace the printhead.
Replace the ink loader assembly. Run
Hope this helps
Jul 31, 2009 | Xerox Phaser 8560MFP Laser Printer
Hi melogek:
Here is your problem.
1 1.
Step 2.
Advise customer. Run clearISCfault test to clear the
error.
Go to
Step 3.Remove any blockage and/ or replace the ink stick.Run clearISCfault
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
Replace
the
printhead.
Replace the inkloader assembly. Run clear ISCfault test to clear the
error.
Hope this helps
Jul 09, 2009 | Xerox Phaser 8560DN Laser Printer
Xerox XC 1045 has a flashing H 4 error.
elem_1_spacer.gif Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Jul 01, 2009 | Xerox Office Equipment & Supplies
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Won't copy
You have either dirty or worn out feed tires. Try taking a cleaner like fantastic, formula 409 etc and clean them well.
If you need , google a business called " the parts drop". Give them a call and talk to Britt or Joe. They will have those at a fair price.
I don't work there, but have not found a better Xerox parts dealer anywhere.
Jan 13, 2009 | Xerox WorkCentre XD120F Laser Printer
Error message shows e2 but there isn't a paper jam anymore
Hello sir; try to turn off the power and turn on, if still don't work, you have to check the sensor it located where the paper got jam,
Jan 10, 2009 | Xerox WorkCentre XD120f Copier
Xerox Phaser 8500N Printer Error 09,037.45:9085
Hi Signrite: This should help out. It looks like you are having a problem with yellow.If you are using a third party ink (non Xerox) then you may be having a printhead.
1 1.
Step 2.
Advise
customer. Run
clearISCfault
test to clear the
error.
Go to
Step 3.
Remove any
blockage and/
or replace the
ink stick.Run
clearISCfault
test to clear the
error.
Heater
test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
Replace
the
printhead.
Replace the ink
loader
assembly. Run
clearISCfault
test to clear the
error
Nov 24, 2008 | Xerox Phaser 8500N Printer
I am getting an error message "H-4" on my copier. Xerox says that they do not service these anymore. ???
Well if you depend on Xerox service, then you have a problem. They are getting out of the service business. But there are tons of Xerox dealer service and independand service that service that product. But you do NOT need a service call. Do this reset and it will correct your problem. This WILL work.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps several times
Oct 21, 2008 | Xerox WorkCentre XD120f Copier
Xerox xd100
See this thread, someone with a similar problem to you:
http://www.fixyourownprinter.com/forums/laser/24105
I'll summarize the solution:
The "software" H4 problem is quite common that Xerox has a resolution on its website
Solution: Perform a Fault Reset 14
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Feb 08, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox workcentre xd120f laser b/w printer
You can download the manual on the following link. How to clear the flashing "P" is on page 14. http://download.support.xerox.com/pub/docs/XD155df/userdocs/any-os/en/newxd.pdf
Aug 04, 2007 | Xerox WorkCentre XD120F Laser Printer
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
130 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
