Question about Samsung SlimFit TX-S2783 TV
Samsung slimfit TXS2783X/XAA
I recently dropped my tv when moving into my new place. It worked for two days after i dropped it so i thought i was lucky but then two days after the accident it won't work. I go to turn it on and i hear it turn on but then after about 5 seconds it will shut off. If i have the tv plugged in the red light on the bottom will stay on like normal but once you push the on button on it will sound like it's coming on but then it just illuminates a horizonal line that starts in the center of the screen then moved up and then back to the center then turns off by itself without giving me an image. The Tv is 13 months old and of course barely out of warrenty. I am fairly handy myself and am a service tech for applaince repair but don't know anything about tv's. Does somebody have an idea of what it could be? Maybe some simple checks, i couldn't find any loose wires inside the cavity and see know burnt marks on the boards or connections. Thanks to anybody that can possibly help in advance.
model TXS2783
Lou
  • ibzbro Feb 23, 2008
    please help me!
The horizontal line across the center like that tells me that you have lost your vertical IC chip and possible some capacitors and resistors around it. You will have to take it into a service repair shop in order to get it looked at but it will probably be cheaper to just buy a new one.
Posted on Feb 29, 2008
Samsung 20'' slimfit tube sdtv
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 07, 2013 | Samsung Ultra SlimFit 20" Digital TV
Missing manual
Here is a link to the users manual for your television.
Samsung TXT2793HX XAA Manual
Good luck.
Semper Fi,
Z
Feb 20, 2018 | Samsung Televison & Video
I have a HDTV Samsung TV, Model #TXS3082WHX/XAA and I would to connect my desktop to the TV. Do you know what cables are needed?
Look for a monitor cable with 15 pin RGB plugs on each end, that will transmit the video portion of the signal so you will need an audio cable with 3.5mm plug on each end also, there are RGB cables that have the audio cable together as one big cable.
Good Luck !
Feb 09, 2010 | Samsung SlimFit TX-S3082WH 30" TV
Samsung TX-T2782 Slimfit TV, power turns on, but no video, audio still working.
Resolder the video board that have the long neck CRT(tv tube)have holes connected to the board.
Nov 23, 2009 | Samsung SlimFit TX-T2782 HDTV
My samsung slim fit tv has a horizontal line which
hum bar. possibly related to power supply filtering. sometimes reversing the power plug will help. check cable connections for tight fit.
Sep 20, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Samsung slimfit keeps turning off
When the TV is on, how about the back light(you can check that on your TV's back side)
If the back light on -- need to replace Main Board.
no back light -- need to replace Power Board
Feb 19, 2009 | Samsung SlimFit TX-S2783 TV
Samsung SlimFit TX-S3082WH Blurring on Left and Right Sides
your picture tubes is going bad. i've had 5 yes 5 of these tv's replaced by samsung/bestbuy. i've kept buying the PSP (product Service plan) now my most recent tv is doing the same. samsung no longer makes the picture tube for this model. i've already called them. it was a nice tv. i've gotten about 6 months out of each model. I'm moving on the LCD, nice rca 32 inch HDtv model at walmart for less than 500.00.
Dec 28, 2008 | Samsung SlimFit TX-S3082WH 30" TV
Dark pic on Samsung HLR5677WX/XAA
I have a samsung hls4676sx/xaa its has hundreds of white dots some are blinking how do I fix it
Jan 09, 2008 | Samsung DLP HL-P5663W 56" TV
Wierd sound when I switch on the TV
Your TV may something arcing inside of it. Maybe a loose connection. Since it is probably under warranty you should get in touch with the dealer where you purchased it. Perhaps you can get the whole TV replaced. Stargazer
Feb 20, 2007 | Samsung SlimFit TX-S2783 TV
Samsung SlimFit TX-S2783 TV Logo
909 people viewed this question
Jerry Greenberg
Jerry Greenberg
