Windows XP - Where is
When attempting to load LG driver(s) using the CD software that came with my new LG 1953T-BF 19" LCD monitor, it instructs as follows:
Click "START", then select "SETTINGS", then click "CONTROL PANEL", then double click "DISPLAY".
In Windows XP, after clicking on green "START" on bottom left of screen, nowhere do I see "SETTINGS" on the pop-up menu. What do I have to change?
  • 31 Answers
It sounds like the instructions are for the classic start menu and you are running in the regular XP more.
There are two ways to work with this. The easist is to just skip the settings step and just select "Control Panel" and go from there.
The other option is to set your Start menu to the classic mode. You can do this by Right-clicking on the Start button and selecting properties. From there you should see two options; Start menu and Classic Start menu. Select Classic Start and then click on OK. The next time you open up the start menu it will look different, but you should have the Settings option back this way.
Posted on Feb 17, 2008
  • 983 Answers
In windows xp it is some what different
after clicking START you will directly get there CONTROL PANEL click on that then go to display in that(make to WINDOWS CLASSIC in left pane of this control panel then it will easy for you to find the display)
that all you will get the display settings then adjust it...
you can also go to display settings as follows:
1. right any where on desktop except on icon & except on start menu
2. now goto properties...
3. in properties select the tab SETTINGS...
4.this is the display properties what you will get by going to control panel... i means it the same which you will get from control panel
    Brigadier General:
  • 6,966 Answers
Hi Grumpa43,
None, on some install versions of XP, the Settings has been removed. If there is no Settings, just proceed to Control Panel.
Alternately, you can also go to the Display Properties by doing a right click on any clear area of your desktop and left click on the "Properties"
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Need monitor driver for LG Flatron L1752T. Thank you
You can download the driver from the following site:
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=L1752T-BF&initialTab=drivers&targetPage=support-product-profile
It is under the drivers and software tab.
Please leave feedback if this was helpful. Thanks.
Mar 18, 2011 | LG L1752T-BF 17" Flat Panel LCD Monitor
How do i dismantle L192WS LG monitor ? please help
We have a full disassembly and repair guide for this model monitor posted on our site at:
http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/
I hope this helps, if so please rate our solution.
BuddyMc
Jan 01, 2011 | LG L196WTQ-BF 19" Monitor
My lg flatron l1953s does not power up. the power cable is not broken or cut. it sents power but my screen doesn't power up
check the connection to the pc.If the VGA connector is not connected to the pc the monitor is not power on.Better check the VGA cable connection and fix it.
Oct 04, 2010 | LG MNTR |LCD 19' 5MS L1953S-BF RT 19 inch...
My driver cd has been damaged where can i find replacement drivers
here.. click this file to start downloading this file
LG L1930B 19" LCD Monitor Driver
Save the file, unzip and install.
Much appreciated if you rate this help..thanks..
May 25, 2010 | LG L1930B 19" LCD Monitor
Stretched monitor? I have a 19 inch LG and it looks stretched. Please help.
Hello Rbeaudoin, Hi! the stretch thing is caused due to improper computer configuration, you need to load the VGA device driver for your PC. A properly setup device driver for your VGA will produce a resolution properly for your monitor.
explanation, you see, without the device driver, windows assumes several resolutions, most of the time, this does not match the monitor resolution, so the device driver when loaded, talks to your monitor, and identifies it, then sends the proper resolution info to the VGA and windows, so that windows can create an option for that resolution. using this proper resolution the monitor can display the video properly.
Mar 11, 2010 | LG Flatron L1750S 17" LCD Monitor
Why does my LG flatron 1953T LCD monitor (19') goes white
Because the fuse on scaler PCB is blown. Open the monitor, open metal cover, disconnect all cables coming between display and boards, take the chassis off the display.
On back side of display you will see metal cover, mounted with tiny screws, take them off. Unscrew the board also and carefully tilt it up. Observe tiny chip fuse (referenced F1 or FU1 or something with "F") somewhere nearby the connector, ring it, replace it with solder drop.
Take everything back together.
Sep 11, 2009 | LG Flatron L1750S 17" LCD Monitor
Drive not instlled
When you bought you monitor there should be a drver CD for the monitor. If you have the CD, pu it in the CD_rom and then if you;re using Windows XP it will automatically open for drive installation. The PC will automatically detect a new hardware and will ask for the driver.The installation wizard will open and you just follow the instruction. Remember the drive is in the CD-rom. Choose CD-rom for drive location.
Nov 18, 2008 | LG Flatron L1750S 17" LCD Monitor
Cannot Find Drivers for Asus VW193T 19" LCD Monitor
there are no drivers for this monitor. you need to update or upgrade your video card.
Oct 31, 2008 | ASUS VW193T Monitor
Problem on video playing
well what software are you playing it with?
Jul 10, 2017 | LG L1752T-BF 17" Flat Panel LCD Monitor
Can not load f1903 software on microsoft xp system
This has nothing to do with your monitor. Windows has default drivers that will be installed for that.
The problem will be your video card drivers are not installed.
Get the right drivers for your card, install them and you should be away.
Mar 29, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
Computers & Internet Logo
Alun Cox
David Payne
David Payne
