Question about Breville Die Cast 800ESXL Espresso Machine
Just got a new espresso maker and run into a porblem: the machine turns on, however, the espresso mode on it malfunctions: the water gashes out over the edges and down the handle of the filter holder even when the filter is empty. The handle itself does not secure tightly when inserted and turned to the Lock position, leaving just enough room for the water to come over the edges and not down the filter opening. It seems that the machine may be missing a part in the Brew Head that would seal the filter holder. Any thoughts?
Thank you.
    Problem Solver:
  • 7 Answers
BrevilleUSA.com has a silicon seal (steam ring) to replace faulty or worn ones. There is no shipping charge, and they are $4 each. To replace the steam ring you'll need to remove the stainless spray disk on the brew head with a phillips screwdriver (one screw) and pull off the old ring (pay attention to the direction and placement of the stainless disk).  Takes about 2 minutes to do.
Part # .800ESXL/192
Also, on mine I noticed that the filter holder was ground down at the factory a bit too much on one side, which causes a slight leak down one side (coffee, not water).  You might check the holder (with the filter removed) for imperfections that could lead to your leak. Good luck.
Posted on Feb 22, 2008
Replace pump breville 800esxl
How to replace the thermostat in the breville 800esxl machine
Nov 07, 2013 | Breville Die Cast 800ESXL Espresso Machine
Brand new breville 800esxl espresso machine will not pump one drop of water - makes all the appropriate noises - shut it down - waited for it to cool - still no water
Hi I bought a Breville today and had the same problem. I found the following suggestion and tried it. After 5 goes my machine worked - yippee - hope you have success too. Info below noavatar.png c280sportguy
  • Rank: Apprentice
  • Rating: 100%, 11 Votes
I got through to the tech support at Breville and they helped me fix this problem. What they had me do was:
1)Fill the water tank all the way up
2)Turn the power on and wait until the heating light turns off.
3)without coffee in the head turn the machine to espresso mode and let it pump for a minute.
4)after a minute turn to standby for a couple seconds then turn it to steam mode for a minute.
5) after this minute is up turn it back to standby for a couple of seconds and then back to espresso mode.
6) the technician said to do this seven times, but mine started working after three or so. The tech said the fixes about 80 to 90 percent of machines with this problem.
Good Luck!
Sep 14, 2011 | Breville Die Cast 800ESXL Espresso Machine
Die Cast 800ESXL Espresso Machine: Breville 800 EXL espresso machine pump not working...
I have the same problem. I used my machine for one day to test it when I had it brought into Vietnam then packed it while our house was being built.
Now it won't pump water or produce steam.
To add insult to injury Breville advice "They don't give service manuals to the public"
May 17, 2010 | Breville Die Cast 800ESXL Espresso Machine
Breville Die Cast 800ESXL Espresso Machine: Problem... Watery espresso. My machine worked great for a year, then all the sudden, the espresso is watery and the basket where the grinds are is full of water...
Personnaly, when I use the big filter, the grinds are dry after the extraction, but for the small filter, it's all soggy. If you look at the documentation, ( http://kitchen.manualsonline.com/manuals/mfg/breville/breville_coffeemaker_product_list.html) they say wet coffee grind after extraction is normal.
But did you change the coffee brand ? Or the grinding level ? How do you grind your coffee ? I had big troubbles once with a commercial grinder at my grocery store, it's when I decided to buy my own Breville grinder.
Good luck,
JF
Oct 16, 2009 | Breville Die Cast 800ESXL Espresso Machine
Water tank vibrates loose
Try some of the expanding foam insulation in a can. Don't use too much as it expands considerably.
Sep 18, 2009 | Breville Die Cast 800ESXL Espresso Machine
In standby mode water tank continued to completely
Try backwashing the machine with espresso machine soap. There might be something keeping the brew solenoid discharge open.
May 17, 2009 | Breville Die Cast 800ESXL Espresso Machine
Need to know the correct tamper size for a Breville 800ESXL ??
I found this one on ebay:
http://cgi.ebay.com/TERRYS-ESPRESSO-COFFEE-TAMPER-50-55mm-DUAL-SIDES_W0QQitemZ330319118719QQihZ014QQcategoryZ20671QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
the 50mm side works perfect for the Breville 800ESXL and the material matches the machine. It takes up less space than the original spoon/tamper combination and sits nicely on the warming surface when not in use.
Mar 29, 2009 | Breville Die Cast 800ESXL Espresso Machine
Chrome on steam wand wearing off
Posted by compliance12@embarqmail.com
I have a Breville Die Cast 800ESXL and due to wrong cleaning process, I have to buy the steam wand. I tryed to find them in Breville.com but they does not have this part available for sale. Where can I buy this Steam Wand for my Breville Die Cast 800ESXL.
PLease let me know ASAP, at compliance12@embarqmail.com
Thanks
Oct 12, 2008 | Breville Die Cast 800ESXL Espresso Machine
Breville Die Cast 800ESXL Espresso Machine Logo
1,085 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
