LOOK FOR BLOWN WINDOW CIRCUIT BREAKER.YOU HAVE A SHORT IN WINDOW SWITCH OR BAD WINDOW ELECTRIC MOTOR.YOUR HEAT PROBLEM IS A STOPPED UP HEATER CORES.THE STOP LEAK STOP ITS HEAT.THE STOP LEAK HAS STOPPED OR PLUGGED YOUR HEATER CORE SO COOLANT CANT PASS THROUGH IT.YOU GOING HAVE TO FIX RADIATOR LEAK AND REPLACE HEATER CORE TO GET HEAT AGAIN.
I had the exact same problem. After I had tested all the relays, fuses, window switches and window motor. I found the wiring harness between the drivers door and the door jam to have one broken wire! (Blue with black stripe) is the power source too the window lock rocker switch that controls all the windows and more! It was a easy repair with a in-line wire crimp.
