Question about Car Audio & Video
Finding a code for a theftlock radio?
I am replacing a stock radio in a 99 olds alero.
The new radio has a theftlock code on it. How do I retrieve it? other than going to the dealership?
Is it accessable from the radio?
  • Anonymous Jan 19, 2009
    current awnsure is wrong, you have to get a phone number and call the manufacturer, then you have to give them some numbers off your radio and they give you new numbes to put into your radio, then your radio is un-theflocked
  • burksky May 18, 2009
    i replaced my radio with one from a chevy malibu no it is locked what do i need to do
    Problem Solver:
  • 16 Answers
Most of the time on newer cars the radio unlock code is on a sticker that is attached to the side of the glove box and the trunk lid. If you are replacing with a used radio from another vehicle you are going to have problems if you don't have access to the other vehicle. you will then have to call the manufacturer of the radio and do what the other guy said in answer #2
Posted on Feb 15, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
No, the radio won't tell you. If you are putting in another stock radio from an original vehicle it could be difficult as the VIN# of the vehicle usually lets the car manufacturer find the code. See if you can find a serial number on the unit somewhere and call the maker of the unit, they will have the listed pin code
Posted on Feb 18, 2008
I have a 2000 oldsmobile alero and I can't get sound out of my rear speakers good speakers and connection just no sound
OLDSMOBILE ALERO 2000 speakers - Sonic Electronix
www.sonicelectronix.com/oldsmobile-alero-2000-car-speakers.html
OLDSMOBILE ALERO 2000 speakers - find speakers that fit your ... sound. This size is capable of delivering exceptional mid-bass that can't be found in smaller ...
2001 Oldsmobile Alero Car Radio Stereo Audio Wiring ...
www.modifiedlife.com/2001-oldsmobile-alero-car-radio-stereo-audio-wi...
Easy Plug and Play Wiring Adapter. ... 2001 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram ... If you can't find your car audio wire diagram, car stereo wire diagram or car radio ... Right Rear Speaker Positive Wire (+): Dark Blue ... olds alero and I have replace the stock stereo and have found that the sound out put ...
Request a Oldsmobile Car Radio Stereo Wiring Diagram
Jan 21, 2016 | Oldsmobile Cars & Trucks
Unlock theftlock radio 2008 grand prix
You need radio code to unlock it. The only place is a GM dealer they will give you the unlock code after they retrieve the factory code
hope it help
Feb 20, 2014 | 2008 Pontiac Grand Prix
I have a pontiac 2004 van i need to unlock the radio
Your '04 is too new to unlock on your own.
There are 2 types of GM Theftlock, Theftlock I and Theftlock II. The Theftlock I is found in pre 2000 vehicles, and Theftlock II is in the later models.
Theftlock I - Uses a volatile user settable code that is input through the key pad on the front of the Radio. If the power is lost (dead battery etc.) the code is gone and must be re-entered for the radio to work. But with the correct procedure the owner can unlock it.
Theftlock II - Uses an EPROM (erasable/programmable read only memory) or a PROM (the difference is you can not alter the prom once it is programmed).
In either case the code is burned in and holds even when the power is lost. With Theftlock II the radio is married to the vehicle by way of the VIN. When the vehicle is started the computer compares the number in the radio with the VIN in the body control module. If they match, the radio works, if not the radio displays LOC and you are finished, there is no easy way around it. The radio will not work until you make a trip to the dealer.
The dealer will use a TECH 2 scanner to change the VIN stored in the radio. The radio does not need to be removed (for the serial number or any other nonsense). The technician just plugs into the computer and resets the VIN in the radio.
Thank you for using fixya, you can try removing the fuse to your radio for 5 min and reconnect it. This will reset the radio back to default and re-read the Vin number to the PCM to match with the radio. At most time this will get your radio working again and all you have to do is to re program the pre-set and clock.
Aug 06, 2010 | 2004 Pontiac Montana
Unlock radio need code to lock radio mufflerman08@yahoo.com
Your '02 is too new to unlock on your own.
Thank you for using Fixya and you may want to try pulling the fuse to your radio for 2 min and then reinstalling it. This may reset your radio and have the ECM recognize the radio matching VIN number to the Trailbalzer.
Jul 15, 2010 | 2002 Chevrolet TrailBlazer
I need a radio code to unlock gm part 10356164
Your '05 is too new to unlock on your own.
Thank you for using fixya and keep us posted.
Jul 10, 2010 | 2005 GMC Yukon
Need unlock code for my 99 oldsmobile radio s# 532544 and how to do it.
THE DEALERSHIP HAS TO FIX.THEY HAVE TO LOOK UP CODE TO UNLOCK RADIO.
Dec 01, 2009 | 1999 Oldsmobile Alero
Theftlock radio code
you have to get this from the dealer no other way
May 22, 2009 | 1999 Oldsmobile Alero
Can find the atuomaket train mission stick on a 99 olds alero
On a service parts identification label on the spare tire cover, look for a 3 digit code that starts with M, I.E. MD9 or some such, that will narrow down which transmission you have.
Dec 19, 2008 | 1999 Oldsmobile Alero
Car Audio & Video Logo
429 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
