Question about Car Audio & Video
How many amps
I need to know how many amps does this car deck need to operate from a power converter
    Brigadier General:
  • 6,966 Answers
A six (6) ampere capable power converter should do just fine for most current in-dash receivers. This would hold true only if the car stereo is not one of those that pushes high wattage in its audio output.
If I may add, converters have been known to introduce 60cycle hum into the audio, perhaps you might be better off with a regulated power supply.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 17, 2008
Replacing stock delco radio with aftermarket deck. need info!!!
If the aftermarket deck has a amp wire you will have to wire it into the lead that controls the amp relay. You will have to get the schematic for your electrical system to locate the 12 volt trigger wire for the relay that turns on the delco/bose amp. that way everytime you turn on the deck the amp will also turn on.
Aug 12, 2017 | 2000 Pontiac Grand Prix
Installing Kenwood KDC-MP345U into a travel trailer. Trailer is pre-wired for deck. Have Orange (hot) & White (ground) from trailer converter to deck. Hooked up yellow (battery) wire from harness to...
the power terminals from the trailer arent direct connected to the battery terminals.when you are plugged to the mains the battery is charging and disconnect [via a relay perhaps]the orange terminal from batt+.try to make anew connection from the trailers battery terminals with a new fuse separated from all trailers circuit'use 2-2.5 mm*cables and a 15amps fuse.connect the yellow and red to+batt and black to- batt.
Jun 05, 2010 | Kenwood Car Audio & Video
How to install Scosche - 2-Channel Adjustable Line-Out Converter
If it is an active converter and not passive, you should have three power wires, black goes to ground, yellow to battery, and red to the remote/amp (blue) wire off the deck. Then there should be four input wires. These connect to your speakers, white-white/black to left, grey-grey/black to right. Black line indicates ground, or (-). Then simply hook up the RCA jacks to your amp! Caution: the Scosche only accepts 80w of power, 40 per channel. Otherwise you rick blowing the converter, possibly the amp (usually a mosfet), and then possibly the subs, though not likely.
Mar 05, 2010 | 1999 Ford Explorer
I want to hook up subs and a amp in a 2008 saturn vue how do i do it
If you are planning on using the factory stereo you will need a line level converter. You basically connect two of your speaker channels to the line level converter. That in turn will give you a line level out (RCA cables) That line level out can be fed to a two channel amp which would be where your subs would hook up to. If you do this however you will lose two channels of mid range and highs ( your rear speakers ). Downfall to this approach is that some line level converters are susceptible to alternator noise.
If you have an aftermarket deck this will be much more simple. You simply run your RCA outputs from your deck to your external amplifier. Aftermarket decks typically have front rear and subwoofer outputs. That means you can drive a four channel amp for your front and rear and a two channel amp for your subwoofer. This is the recommended way to go.
For hookups I just suggest buying an amp kit that is comparable in power rating to your amp. If you buy a 500watt amp make sure your wiring kit can handle at least 500 watts.
Feb 12, 2010 | Jl Audio M5122.4 Diamond Audio 12" Car...
The radio on my 2003 Envoy quit working. The display on the radio says "need amp." A new amp was put in and the radio still does not work. What could be wrong?
Radio sends a 12V signal that switches on the amp which has it's own power suply but won't switch on till signaled from deck. Check to see if the amp is powering up.
Nov 12, 2009 | 2003 GMC Envoy
I just picked up a 12" type r in a box with a alpine m 350 how do I know what kind of type R I have without taking it out of the box?? and how do i hook it up to this amp??
Not to insult you in any way but u need to know how to wire into car's electrical system at the battery then to a fuse then to the amp and then output the signal from the deck to the amp.. finally to the subwoofer. you need to hook up 12V constant battery power , then remote from the deck ,ground wire from amp to chasis for power.. then wire to sub.
Sep 10, 2009 | Alpine SWR-1222D 12" Type-R Series...
I had to replace the WFCO power converter, as it had gone bad. The refrigerator would not work either, with the check light staying on all the time, even with a good battery and no AC powere connected. Now...
RVIA
Recreatio Vehicle Industry Assocition
http://www.rvpartwholesaler.com
Dometic 9108677537 A&E Carefree RV Awning Pull Strap
Dometic 3307834.006 A&E Carefree Window Awning Pull Strap 28"
WFCO 8955 55 amp converter. New w/ warranty! US Seller.
WFCO 9855 55 amp deck mount converter. New w/ warranty!
Aug 06, 2009 | Dometic RM2652 Refrigerator
Wiring
tblackwood ...if you have connected your remote turn on for your amp to the remote turn on on the deck(this is also the power aerial connection) ..on some decks this has power only when the radio is operating. as soon as you insert cd it shuts down the power to this supply(i dont know why some did this.it was a bad move ) ..you may have to find another power supply to turn the amp on (accessories supply on the ignition..)
Feb 11, 2008 | Kenwood KDC-MP335 CD Player
Need patch cords
Sorry, unit was built sharing power supply with amp, hence no power connector or standars rca sockets. Cost cutting exercise, so without the rest of the system you may have problems getting the unit to operate even if you could work out the connections to it. I know its not a cure but a "fixya" rating would help my profile in here. Thanks
Jan 14, 2008 | Audio Players & Recorders
Running amp in house
its very tricky to use a car amp in house, your going to need a power converter and deck for the house, plus car audio is not made for home, the sound is going to be off cause car audio plays a differ frequencys the home sterio.
Nov 12, 2007 | Kenwood KAC-X401M Car Audio Amplifier
Car Audio & Video Logo
48 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
