Question about Euro-Pro 534DX Mechanical Sewing Machine
Euro pro serger model 101-548
Help, want to do 3 thread ultra stretch mock safety stitch, however the manual says to use converter for upper looper thread, it also says to see instructions for converting upper looper to 3 thread serging, HOWEVER there is no instructions in my manual on how to do this, have read and reread the manual a cazillion times, please help!!
  • 3 more comments
  • fbks Aug 30, 2008
    Yes, the same problem. Where is the converter instructions? How do I set the converter when I have no idea what that means? Please help.
  • Anonymous Mar 14, 2014
    I am a beginner at serging. Bought a used serger. No DVD and the manual is unclear regarding threading the loopers. How many 'green' loops are there? I found 4 before threading the looper.
  • Anonymous Mar 20, 2014
    Lost instruction manual for threading. Help
  • Anonymous Mar 21, 2014
    I have the Kenmore ultra stitch 6 model #1340281 serial 52135709 if anyone has the instruction manual and how to maintenance it manual or where to get it thanks so much De
  • Anonymous Mar 28, 2014
    i dont have a book on how to thread
I believe they mean the "2 Thread Adapter" - tiny little piece you attach to the "upper looper" when using less than 4 threads (I could be wrong - but this is the only thing that could possibly make sense) You can find a picture of the "2 Thread Adapter" on pg. 6 - Accessories - its almost invisible in my manual, but its #8 in the accessories chart.
Posted on Dec 07, 2010
  • Euro-Pro Master
  • 1,388 Answers
3 thread overlocking (serging) is no different t 4 thread, except you remove one or other of the needle threads.
The stitch width is then controlled by two variables,
the manual width dial selector, and
your choice of either the right or left needle
Suggest yo play with width selector on a scrap of your project fabric to achieve the look you are after.
Posted on Feb 17, 2008
I need help in good tension for rolled hem in empisal 606D overlocker
Your owner's manual should have instructions for rolled hem settings. My Bernina manual has a the following settings:
Medium weight fabric
80/12 Universal needle
3 cones serger thread
Upper looper 3-5
Lower looper 7-9
Left needle (no thread)
Right needle 3-5
Stitch length 1-1.5
Cutting width 2-3
Differential feed N
Can use woolly thread in the upper looper, but the tension may need to be loosened since the woolly nylon thread will stretch.
Make It Handmade Threading Your Serger or Overlocker
Dec 19, 2015 | Sewing Machines
Bernina 335 serger won't sew/overlock. carefully rethreaded the serger but that hasn't helped.
The 335 has a two thread chain stitch (stitch type 401), and the overlock side (right needle side), is a three thread plain overlock. If you are describing the plain overlock as the problem, I would first suggest the following in re-threading:
1. Thread the upper looper
2. Thread the lower looper
3. Thread the needle last (important)
If the needle threaded, you cannot re-thread the lower looper without breaking the thread.
In order to thread the lower looper, the lower looper must pass by the needle thus picking up the needle thread. So, instead of threading the lower looper thread underneath the needle thread, the looper would be threaded on top and cannot sew without breaking the thread.
Make sure that the threads are bedded between the tension disks. Check this by stretching the thread fore and aft of the tension disks as well as visually noting that the threads are not accidentally threaded behind the disks. You can also loosen the tension disks when threading so as to allow the threads to bed deeply between the disks.
Please reply with your observations.
Sep 27, 2015 | Bernina Sewing Machines
Why won't my sl370 work?
Hello Mary.
By the question, it looks like the lower looper is making loops? If so, check that you are using the correct needles for your serger and that the needle or needles is/are inserted correctly:
- needles must be all the way up into the needle shaft
- needles must face with the flat side to the back and the groove to the front
- use at least needle size 12/80, not smaller
Check these few items, if the loops are still not forming:
- re-thread the serger from the start, keeping in mind to thread in the proper sequence (upper looper, lower looper, needles)
- make sure that the lower looper thread lays on top of the upper looper thread and is passed to the back of the serger and then under the presser foot when threading
- make sure that the thread are securely engaged IN the tension assembly
- make sure that the serger is set for 3-thread or 4-thread overlock (i.e. that the upper looper converter is not engaged)
- check all tension setting
- stitch length should be around 2.5 - 3.5
Let me know how it goes.
Happy serging!
May 02, 2015 | Sewing Machines
Brother 1034d serger skipping stitches. Stitches are loose even when adjusting the tension.
It appears that there are two issues: skipping stitches, and, loose stitches. Let's deal with them individually but first some general points to check.
1. Change both needles for completely fresh ones out of the package. Make sure that they are inserted all the way up, this is very important. The right needle should appear longer than the left one. Make sure also that you are using the correct needles for your serger.
2. Use a good quality thread with very little stretch, almost no fuzzies, and in pastel colour. Dark thread ages quicker, therefore has a shorter shelf live. A good quality sewing machine thread is also acceptable.
3. Make sure that the tension dials are clean and free of lint or other debris.
4. Re-thread the serger in this order, keeping the presser foot in the down position at all times
a) Upper looper. Ensure that the thread is securely embedded inside the tension discs. Place the thread tail under the presser foot to 11:00 o'clock and place the presser foot down again
b) Lower looper. This is the difficult one to thread but make sure that all the thread guides are properly threaded as well as the upper looper elbow. Check that the thread is lodged between the tension discs. Once the lower looper eye is threaded, place the thread in front and over the upper looper and then under the presser foot to 11:00 o'clock and place the presser foot down again.
c) Right Needle. Thread the right needle path, again ensuring that the thread is between the tension discs. Place the thread tail under the presser foot to 11:00 o'clock and lower the presser foot.
d) Left Needle. Proceed as with left needle.
e) Double check that all tension dials have their respective threads embedded between the discs by pulling firmly up on each thread above the tension dials.
f) Check that the stitch length is set to between 2.5 and 3.0, differential to normal, blade position to middle, blade is engaged, and upper looper converter not in use.
g) Set tensions to recommended setting for 4-thread overlock.
g) Make a test stitch out. How is it? Still having the same issue/s?
If yes, continue with the items listed below, otherwise have a great time serging.
Skipping Stitches:
1. Check that the looper tips are smooth. Burrs will cause problems.
2. Check that the needles match the type of fabric being sewn.
Loose Stitches:
1. Double check threading.
2. Debris caught between tension discs will also manifest itself in loose stitches. Take an 8" X 6" piece of medium weight clean and lint free cotton fabric, fold it in half length-wise and pass the fold only firmly between the tension discs from top to bottom (with the presser foot up and no thread in the tension dials).
Re-thread and test stitch. How is it now?
Sep 30, 2014 | Sewing Machines
I can't find my Bernina Serger 800 dl manual - how do I thread for a 2 thread rolled hem, and do I need a upper looper cover and that the heck is that anyway?? Thanks
From what I have read this manual is less than desirable. Neither is the one for the brand that I have.
You may have better guidance if you purchase and use Nancy Zieman's "Serge with Confidence". I have found it very helpful.
For the two thread rolled hem, the looper cover is used to "trick" the looper into "thinking" it is threaded.
On my serger (not a Bernina), this is referred to as a "subsidiary looper". It is a spring type mechanism that fits in a small hole at the top of the upper looper.
You use a rolled edge presser foot; right or left needle; stitch length @ normal or wider; stitch length @ 1mm for the left needle/0.5 for the right needle; differential feed @ normal; needle tension - tighten; lower looper tension - normal or looser; two thread looper cover - engaged.
Test and adjust the tension as needed before making the rolled hem on your garment.
I hope this helps.
Apr 18, 2010 | Bernina 1008
I require operating instructions as to what is requiered for flat bed stitching?
I can share the information for my BabyLock Imagine in hopes that it will help you.
There are options of 2 or three threads.
For the 2 thread the serger must have a 2-thread converter- aka, auxiliary looper or subsidiary looper.
This is a spring type mechanism that fits in a small hole at the top of the upper looper. It 'tricks' the upper looper into thinking it is threaded. It must be engaged by connecting to a small hole in the upper looper
Set up the serger for a 2 or 3 thread right or left needle.
Stitch width - wide if you are using the left needle and normal if for the right needle; length 1 - 3mm.
Needle tension loosened and looper tension normal.
Disengage the cutting blade..
Set the differential feed at normal.
Hope this will help.
Mar 19, 2010 | Janome Memory Craft Compulock
Trouble with my Huskylock 680D overlocker Tensions
You need to re-thread the serger.
Refer to the manual or open the front of the serger to see if the threading diagram is there.
With most sergers, you begin with raising the presser foot, then set the tensions to zero.
Begin the threading with the upper looper (curved looper), then the lower looper and the needles last.
Pull the thread under the presser foot and to the left side of the serger.
Set the tensions back to normal 4 - 5 usually.
Lower the presser foot and hold onto the threas tails as you stitch a chain. If the chain of the four threads is ok, you are ready to serge fabric.
Feb 21, 2010 | Husqvarna Sewing Machines
I don't have a manual for my Baby lock Pro line model # BL4-738 NS. It was given to me and I have threaded it accordingly to the diagram on the machine but it won't pick up the stitch.
You will have to order the manual from a Baby Lock dealer.
This model may have to be threaded in a certain order.
Try raising the presser foot and setting the tensions to zero.
Turn the handwheel so the upper looper (the curved one) is at it's highest position - there may be a mark on the side of the serger where you align the handwheel for this.
Thread the upper looper and then the lower looper and then the needles.
Pull the threads under the presser foot and toward the side of the serger.
Set the tensions back to 4 - 6, lower the presser foot.
Hold onto the thread tails and gently press the power pedal to begin a thread chain before serging fabric.
Feb 16, 2010 | Baby Lock Eclipse Serger
Instructions for threading Baby lock eclipse BLE1LX for 2 thread sergering
I have just learned this :)
Either needle thread may be engaged for 2-thread serging.
1. Open the front cover and cutting blade cover, cut the upper looper thread just above the threading guide ( this is plate that has two holes for the threads) Raise the presser foot and pull out the clipped thread from under the foot. Remove upper thread from the machine (or you can leave the cone thread on, it doesn't matter).
2. Rotate the handwheel to bring the upper looper to its lowest position.
3. Rotate the subsidiary looper up and to the left, then slip the end into the upper looper thread eye from backside.(this sounds complicated, yes? but it is very simple : the looper has a counter part that is spring-locked to move from left to right and right to left. This is the little claw-looking part of the looper that when in the postion to serg with four threads is to the right side of the looper. It looks like a scorpion's tale. If you can't figure which part it is, use your finger to probe the looper and you'll feel it give a little. This part needs to be moved to the left - it will not slide over, but swing up and over and down, like an arch. Then, where the thread comes out of the looper is where you want the little claw-like part to hook into.)
4. Close the covers. Decrease the needel tension - this depends on what the stitch length is. Stitch length: 2-3, stitch width: 3.0 = L needle n/a, R needle 1; upper looper n/a, lower looper 5
stitch length: 2-3, stitch width: 5.0 = L needle 0, R needle n/a, upper looper n/a, lower looper 3.5
Those are for a flatlock stitch - for a 2-thread rolled edge :
Stitch length: 0.5, stitch width: M = L needle n/a, R needle 4.5, upper looper n/a, lower looper 3.5
Stitch lenght: 1.0, stitch width: M = L needle n/a, R needle 4, upper lopper n/a, lower looper 3.0
If you have any questions, e-mail me at knowgodnofear@bex.net
Aug 10, 2008 | Baby Lock Eclipse Serger
Threading a husqvarna huskylock 1001L serger
Solution taken from "Handbook for Huskylock Sewing Machine Models 1001L/1000L/1000"
1. Raise the presser foot by using presser foot lever. When the presser foot is raised, the two thread tension discs in the thread tension control panel are released so that thread passes freely between them. Otherwise thread tension may not be correct.
Important! When threading the needle, always be sure to lift the presser foot lever, and also take care to thread in the proper order.
Threading order:
1. Upper looper thread (green)
2. Lower looper thread (blue)
3. Double chain stitch looper thread (purple) in case of 5 thread stitch or double chain stitch
4. Right needle thread (red)
5. Left needle thread or double chain needle thread (yellow)
Caution!
Because the left thread tension dial (yellow) is used for either the left needle or the double chain stitch needle, these needles will never be used at the same time.
Upper looper (green) sequence:
1. Thread holder (silver triangle openings attached to thread holder stand)
2. Thread guide (flat silver clips just behind thread tension disc)
3. Thread tension disc (circular knobs with numbers for tension setting)
4. Pull thread around upper looper guide and upper looper
5. Pull thread into hole of upper looper
Lower looper (blue)
Repeat 1, 2, 3.
4. Pull thread around guide (see color coded chart inside front serger cover).
Easy threading mechanism (for lower looper)
1. Pull out the lower looper threading lever
2. Thread the lower looper and position the thread on hook of the lower looper
threading lever.
3. Push the lower looper threading lever back to its basic position while
holding the end of the thread.
Caution:
When returning the lower looper threading lever, always make sure that the two
blue triangle marks (directional arrows) meet each other.
Left needle thread (yellow)
Important: Thread the needles after threading of lower looper and upper looper.
First raise the presser foot lever, and then thread the needle threads in order shown in color coded thread guide.
Jun 24, 2008 | Sewing Machines
Euro-Pro 534DX Mechanical Sewing Machine Logo
695 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Greg Cann
Greg Cann
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
