Question about Canon IXUS V2 Digital Camera
Dropped my camera canon sd450
I dropped my camera canon sd450 and the lense wont go back in. its like stuck. while i was taking a picture i accidentally dropped it and it fell down hitting the lense can i fix it?
  • Canon Master
  • 4,738 Answers
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 17, 2008
So my lense on my canon camera was open when I dropped it and not it wont close Everything else works like I can see my pictures and all but I cant take pictures because it says lense error restart camera...
I'm afraid no words can solve this problem. If the lens is stuck in one position, or some gears are broke, the only thing that helps is a repair. But before you bring in the camera, contact a Canon certified repair centre and ask what it will cost to repair a camera after you dropped it. The repair could easy cost more than a new camera with better specs, so consider buying a new one too.
Apr 22, 2014 | Cameras
Self shooting for canon power shot SD450
You mean SELF TIMER?
Big dial on the back>press it down until you can see "Clock" sign on LCD>press release button
Mar 25, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
Canon A620, I can review pictures taken, func set and menu, but I can't see what the lense sees.
Are you able to take pictures with the shutter button, and do the pictures come out OK? If so then it's likely that you accidentally pressed the DISP button on the back of your camera. Press it once more to turn your display back on.
But if the pictures are also coming out black like the display, then the problem is more serious, and is likely a stuck shutter (this cannot be repaired by the average person). This would require professional repair. Call 1-800-OK-CANON to arrange repair.
Mar 21, 2009 | Canon Cameras
Lense of camera is stuck out
Defective Lens Block
Needs to be replaced.
Jan 12, 2009 | Canon PowerShot SD870 IS Digital Camera
Lense on Cannon sureshot
Not really, zoom lenses are pretty fragile and will permanently be damaged when they get a shock. Most probably the guide rails/pins are damaged inside, and it will need luck and patience to glue them in place (and most of the times glue isn't strong enough to keep them together).
Better sell it for parts on ebay and get yourself a new one (most of the times broken fetch half price of used ones). People need different parts (i.e., the mount, motors, aperture assembly), and it is environmentally great to recycle goods for reuse by other repairers...
K.
Sep 15, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Help me !!!!
Contact the makers customer support.
The likely cost of repair however will be near the cost of simply replacing the camera.
Get your friend to donate you the cost
Jul 27, 2008 | Canon PowerShot SD1000 Digital Camera
Canon sd450 - spilled a little lemonade on the camera
maybe the lemonade was sticky and the shutter can't open? otherwise the circuitry could have been fried if you turned it on before it dried inside.
Nov 09, 2007 | Canon Powershot SD450 / IXUS 55 Digital...
My Canon Powershot SD400 won't turn on and lense won't go back in
Unfortunately the lens assemblies in these compact digital cameras are quite delicate. The drop probably knocked the barrels of the lens out of alignment preventing it from moving. You can try to GENTLY twist the lens back and forth, you may be able to click it back into alignment allowing it to function normally. If the gentle manipulation fails to fix the problem you will need to get the camera serviced by a professional. There are quality repair services on the web who will work on your camera. David Millier Advance Camera Repair
Mar 05, 2007 | Canon PowerShot A520 Digital Camera
Canon IXUS V2 Digital Camera Logo
298 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
