Apple iPhone Smartphone
Problem for Apple iPhone Smartphone
Enabling Edge on Unlocked iPhone
By VegasDiamond on Feb 17, 2008
Alright,so I succesfully unlocked my iPhone and am currently using my T-Mobile SIM card in it. I can do everything but use the internet. I do have the little E at the top of the screen indicating that I have access to EDGE,but it's not lettin' me actually go online. I have no trouble goin' online with the same SIM in my Blackberry. Can someone PLEASE HELP ME
Comments:
Feb 19, 2008
- I tried doin' what you suggested. And still no luck :-( Any other suggestions? I have the 1.1.3 version,by the way,if that makes any difference. Thank you so much for trying :-) I really appreciate it
Feb 23, 2008
- Yes it is unlocked and jailbroken, I recently downloaded something from the istaller and it fixed the problem. Thank you soooooooooo much for your help.
Clarification Request
Posted by mcvf on May 23, 2008
IS EDGE ONLY FOR THE USA-I LIVE IN ARGENTINA CAN I USE IT ?
Same Problem
May 26, 2009
-   i have airtel sim (india) and gprs working in p1i sony erricson. when i put the sim in iphone it says you are not subscribed to edge. how to solve this? -   vasudev_Lp
May 21, 2009
-   I have the same issue as well as listed above related to the phone being unlocked and jailbroken running 2.2 firmware but unable to access online. i can via wifi not just hitting safari please help-   deltalyric
May 10, 2009
-   I cant access Edge on my IPhone.....I can access the internet via WiFi but not through Safari.
HelP??-   kwhyly
Apr 30, 2009
-   I have a unlocked i phone and I'm using t-mobile service. it saying that i'm not subscribed to edge? -   dmppics
Apr 08, 2009
-   I have an ATT iphone unlocked and want to use Rogers in BC. How can I activate EDGE?-   ppicci
Best Solution
posted on Feb 28, 2009
Very Helpful)
jamers2004
Rank: Guru
Rating: 86%, 167 votes
On an unlocked iphone for the T-mobile carrier you need to add the full internet package to use the internet.
The apn is internet2.voicestream.com or internet3.voicestream.com if you have VPN internet.
Wap.voicestream.com may work, but it is not for sure, and might not give you the full internet. Only wap pages which are different than html.
To add this you go to settings>general settings>network>cellular data network or edge and then put the apn in the apn field. Make sure data roaming is turned on, and 3g is turned off.
Do not put in a user name and password, and go back to the main screen. Make sure your wifi is turned all the way off, not just disconnected.
Try to browse. If this fails you may need to reset the network settings. To do this, go to settings>general settings>reset>reset network settings. DO NOT reset anything else or it may re-lock your phone. Then when the phone resets go back and input the apn again, and turn off wifi.
Happy browsing!
Comments:
Feb 28, 2009
- "try this for the APN for t-mobile
i have t-mobile and just got these settings directly from tier 4 support
hope it works, it did on mine"
There is no tier 4 at t-mobile.
Was this helpful?
Yes
No
7 people thought this was helpful
Solution #2
posted on Sep 10, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
type in wap.voicestream.com for Tmobile users and EDGE will work
henry
Solution #3
posted on Apr 27, 2008
Very Helpful)
amar65gupta
Rank: Apprentice
Rating: 96%, 16 votes
Hi there Vegas Diamond (and others who are facing the same problems). I had posted the same query (amar65gupta) an hour ago. Then my curiousity got the better of me and I started exploring the "Edge" problem. And i fiund the solution (atleast it works in my case).
Please go to the EDGE settings page (Settings>General>Network>EDGE settings). It asks for the following information:
APN:
Username:
Password:
My service provider does not require Username and Password and I had to only key in the APN (in my case it is: airtelgprs.com. My service provider, in India, is Airtel).
After one has filled in the required information then switch off the iphone, remove the SIM and then reinsert the SIM and put the phone on. Try it. it might work on your phones as well. it does now on mine. And I am enjoying my iPhone to its full. When the EDGE is activated the "E' on the top left hand corner will 'glow' blue while it is white/grey when the EDGE is not activated.
Hey guys. let me know if it worked on your iphones or not.
p.s: Is it normal that iTunes can be accessed only through Wi-Fi!! Wonder why not through EDGE also)
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Jul 10, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i also have a unlocked iphone...iwireless is my carrier...how can i get edge to work!!!!!!!??
Solution #5
posted on Jul 04, 2008
Helpful)
raz02558
Rank: Apprentice
Rating: 90%, 3 votes
im in india and using idea as my service provider for phone service. i have the edge "E" but unable to connect to the internet. if someone might be able to help me please do so it will be appreciated. thank you.
Was this helpful?
Yes
No
Solution #6
posted on Oct 19, 2008
Helpful)
cableguy31us
Rank: Apprentice
Rating: 88%, 4 votes
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #7
posted on Apr 08, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
for t-mobile go to settings-general-edge and use wap.voicestream.com in the ADP setting. it worked for me. no user or password is required.
Solution #8
Somewhat Helpful)
nala1991
Rank: Apprentice
Rating: 70%, 3 votes
go 2 installer and in stall a program called (ANYSIM) this wil lwt u use any sim 4 any network!
Was this helpful?
Yes
No
Solution #9
posted on Apr 05, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Go in edge settings
APN: internet.com
use: wapuser1
password: wap
peace out :)
Solution #10
posted on Feb 17, 2008
Somewhat Helpful)
silentspoon
Rank: Guru  Apple Expert
Rating: 89%, 160 votes
Not letting you access youtube, or not letting you go online via safari? The youtube issue is a separate issue, but if you really can't get online because the edge network is unavailable, I would try installing the "Boss Prefs" app located in "Installer.app". Once you install Boss Prefs, click on it, and toggle the "Edge" service on and off. Once it comes back on, it might ask you to select your network, ATT, TM, etc.
Comments:
Feb 19, 2008
- You may want to backup your data and do a full restore back to 1.1.3 again. Then, download the latest version of ZiPhone from ziphone.org - it was version 2.4 as of this writing, but he has been updating the program nearly every day.
There is a lot of useful info on his blog (same website above). Read through the latest few posts before running ZiPhone. His utility will get you jailbroken and unlocked again, and should get your edge service working again. I think the restore and re-jb is the best option at this point.
Feb 22, 2008
- Is your 1.1.3 phone jailbroken\unlocked? Have you tried a full restore in iTunes since the problem started?
Was this helpful?
Yes
No
Solution #11
posted on May 25, 2009
Very Helpful)
andysbitch
Rank: Apprentice
Rating: 100%, 1 votes
OKAY!! If you want to use edge on your unlocked i phone do this: first off, go to settings. Turn OFF wifi (when at home simply turn it back on). Then go back to settings, go to general, hit cellular data network, hit APN. Enter into the APN slot (dont worry about user name and password). Type in internet2.voicestream.com . If you cant find APN (i did this), you most likely downloaded a Cydia app that switched things around. If so, restore. If you want 2.2 software, go to http://www.demonoid.com/files/details/1739645/?show_files=&page=1
follow his instructions explicitly.
Go back to your home screen. Thats it. When wifi is off, you will now run off of the edge network. I personaly subscribe to the smartphone plan so i have unlimited usage and downloads.
Was this helpful?
Yes
No
Solution #12
posted on Mar 27, 2009
Helpful)
srobertson26
Rank: Apprentice
Rating: 88%, 2 votes
if its a 3g, turn off 3g, then under cellular data put in APN internet2.voicestream.com then turn data roaming on, and also turn WI-FI off. it should work
Was this helpful?
Yes
No
Solution #13
posted on Aug 07, 2009
Not Rated)
jemaal
Rank: Master
Rating: 77%, 47 votes
FIND YOUR SOLUTION FROM APLLE.
HERE IS YOUR SOLUTION
www.apple.com/iphone/prob237ji32/solution
Thanks
Was this helpful?
Yes
No
Solution #14
Not Rated)
enopog
Rank: Master
Rating: 76%, 23 votes
Problem with AppleiPhone? Most of the iPhone problem is Unlocking problem.
If you want to unlock youriPhone now you mustClick Here.
If you have any other problem with your iPhone you can try the site byClick Here. May the site can help you.
Was this helpful?
Yes
No
Solution #15
posted on Jul 10, 2009
Not Rated)
monsta_0406
Rank: Apprentice
Rating: 0%, 0 votes
i unlock and jailbreak my 1g iphone and now the edge doesnt work. i have at&t though. can someone please help
Was this helpful?
Yes
No
Solution #16
posted on Aug 23, 2008
Not Rated)
ibrahims
Rank: Apprentice
Rating: 0%, 0 votes
thanks a ton amar. ur suggestion worked for me. my edge services are activated
Was this helpful?
Yes
No
Solution #17
posted on Jul 13, 2008
Not Rated)
jess_in
Rank: Apprentice
Rating: 0%, 0 votes
My iphone shows a grey lock in the uppermost bar. Does that mean some features are still locked? I cannot connect to internet.
Was this helpful?
Yes
No
Solution #18
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thanks whooooo
wap.voicestream.com in ADN worked for me
t-mobile- user
Popular Solutions for Apple iPhone Smartphone
Questions and Unsolved Problems for Apple iPhone Smartphone
Do you recommend Apple iPhone Smartphone?
Answer
Answer
The touchscreen on my iphone is frozen I;ve restored it it held the two buttons down at once nothing... (More)
Answer
my iphone was unlocked and iwas updating it when it got stuck so i had to restore it to factory... (More)
Answer
my Iphone 3g doesnt turn on.. I only get the apple when powering up and then a black screen.. I... (More)
Answer
my att tilt smart phone is not allowing e-mail to be sent for the past 4 days but gets e-mail just... (More)
Answer
ok...I've read everything about verizon email on ipod touch...finally got my incoming mail set..but... (More)
34 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Apr 02, 2009
how do u subscribe to edge on your iphone?
Comment by ivancolon20, posted on Mar 26, 2009
i have the iphone unlocked to tmobile and i cannot get the EDGE to work.
Comment by padronesadri, posted on Jan 30, 2009
i cant get online
Comment by Guest, posted on Dec 03, 2008
how can u get edge on my t moble phone
Comment by izasnoopy2, posted on Sep 22, 2008
i have the iphone unlocked to tmobile and i cannot get the EDGE to work. i saw that someone had found something on installer. what app is it?
Comment by hollydolly41, posted on Aug 19, 2008
i have my iphone unlocked and i have myorange sim in. i can get on my wireless if im in the house but it says im not subscribed to EDGE???? anyone know how i can fix it??
Comment by helio588, posted on Aug 06, 2008
can't get internet
Comment by Guest, posted on Jul 20, 2008
I have the same problem
Comment by hannah30086, posted on Jul 03, 2008
i can't get edge to enable on my phone
Comment by Guest, posted on Jun 20, 2008
My iPhone is unlcked and jailbroken, but I cant use Edge,m and I'm currently paying for a sidekick unlimited plan
Comment by TDizzel01, posted on Jun 14, 2008
Using unlock Iphone (Ziphone) with t-mobile sim card an im unable to access the internet. It say's im not unsubscribe edge, and i cant download any installers to fix the problem
Comment by Guest, posted on Jun 14, 2008
using unlock iphone (ziphone) with t-mobile sim card and im unable to access the internet. it say's im not subscribe to edge. and i cant download any installers to fix the problem
Comment by green hornet, posted on Jun 14, 2008
I have an unlocked iphone with a tmobile sim card and the internet won't work. What do I need to do?
Comment by Guest, posted on Jun 13, 2008
my iphone is unlocked and jailbroken but has trouble connecting to servers and downloading
Comment by mcvf, posted on May 23, 2008
MY I PHONE HAS BEEN UPGRADED TO 1114.BUT ILIVE IN ARGENTINA AND USE A MOVISTAR SIM .EDGE ONLY FOR THE USA?
Comment by Guest, posted on May 16, 2008
I have an unlocked iphone but i cannot access the internet because it is asking me to connect edge
Comment by ruttercaleb, posted on May 15, 2008
i recently unlocked the iphone and am using tmobile but i cant get edge to work.
Comment by Guest, posted on May 10, 2008
i can't get on the internet there is an E showing on the top of the screen but i twill not let me connect
Comment by Guest, posted on May 07, 2008
i can't get on the web im on a t-mobile sim ne help would be great thanks
Comment by amar65gupta, posted on Apr 27, 2008
Same problem as this user. No edge even though I can see the "E" on the top left corner. Pls help!!!...........AG
Comment by Guest, posted on Apr 24, 2008
Alright,so I succesfully unlocked my iPhone and am currently using my T-MobileSIM card in it. I can do everything but use the internet. I do have the little E at the top of the screen indicating that I have access to EDGE,but it's not lettin' me actually go online. I have no trouble goin' online with the same SIM in my Blackberry. Can someone PLEASE HELP ME!
Comment by bad saint, posted on Apr 20, 2008
 I have the 1.1.3 version iPhone unlock and am currently using my T-Mobile SIM card in it. I can do everything but use the internet. I do have the little E at the top of the screen indicating that I have access to EDGE,but it's not lettin' me actually go online.PLEASE HELP ME
Comment by Guest, posted on Apr 20, 2008
 I unlocked my iPhone version 1.1.3 currently using my T-Mobile . I can do everything but use the internet. I do have the little E at the top of the screen indicating that I have access to EDGE,but it's not lettin' me actually go online.  HELP ME
Comment by Pipolota, posted on Mar 31, 2008
I have an iphone that displays the edge "E" in the screen, but won't let me access the network. It displays an error message about PDP authentication. The edge network settings also don't save. I have to keep putting them in.
Please help.
Comment by Guest, posted on Mar 30, 2008
i dont seem to have edge at all
Comment by mdlab, posted on Mar 27, 2008
i have the same "cannot connect to edge " problem. anyone have a definite fix?
Comment by bigchrisny, posted on Mar 16, 2008
Hey guys i have jailbroken my ipod and now im using it with tmobile but i cant get the internet working. I keep getting the error message saying that i am not an edge subscriber. So i canot browse the net or anything . What can i do to enable edge on my iphone.
Comment by piti777, posted on Feb 25, 2008
I have the same problem with my T-Mobile Card, can´t find a window to fix it, like I can do with a eplus card - please tell, how do u fix the edge on your unlock ipone???? Thanks in advance.
Comment by DAKOOLEST, posted on Feb 24, 2008
how do u fix the edge on unlock ipone
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PDAs Experts
Top Computer & Laptop Repairmen
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
