190G Monitor fix or new one needed?
Hi, My 190G phillips monitor has power but no image on the screen anymore. Is this something that could be fixed? blown fuss or something, or will i be up for a new monitor. Its not that old.
    Scholar:
  • 198 Answers
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
    Problem Solver:
  • 5 Answers
Good Luck!
Posted on Feb 17, 2008
Hi I have two HP 2009v monitors that have previously been working fine, all of a sudden, after turning the base unit on windows Xp shows the, monitor lights are on but the screens show blank, do you know...
I had this issue with my HP monitor too. Turn on pc and look at the monitors with light shining on them - you'll probably see the images, which indicates they illumination portion of the monitor board burned = much cheaper to replace!! You did not mention if they are L.E.D., but I'm almost willing to bet they are - and over 3 years old too, huh? Sorry for the bad news - hope this helped!!
May 08, 2014 | Computers & Internet
My e40 monitor screen soon crashes after power on and horizontal lines appear after screen size stretches vertically. please help
Your monitor is over heating. this usually means that a component inside if failing. CRT monitors are not worth fixing anymore, I'd suggest buying a new monitor.
Mar 05, 2011 | ViewSonic E40 Monitor
HP F1703 Screen goes black within seconds of startup
That is either the backlight or its power supply.
This is a bit tricky as you can get it fixed under warrenty but they will likely ask you to send back the entire computer not just the monitor. It is also something that you could fix or several shops could but the repair cost really isn't much less than a new monitor. You are not stuck using an HP monitor so anything will work and you can get quite a lot bigger or better for about $120 and up. Repair cost is going to be $80-$100 so as you can see for just a few dollars more you have a new warrentied monitor.
Apr 27, 2010 | HP Pavilion F1703 17" LCD Monitor
Scren with no image, power light on
I think....
Your PC is overdriving the monitor and it is protecting itself from harm. Something changed.
Start in SAFE mode (press F8 wile booting) and SAFE mode to see if it works ok in DOS while booting and then in Windows DEFAULT setting. Then Reboot and readjust to something sensible (1280*1600, 32bit, 60Hz)
My guess is that MSoft pushed a patch or SP to your box and IT replaced the dll your monitor was using.
Goto mfg and DL and reinstall the correct drivers again
Good Luck!
Let me know if this fixes it
Mar 27, 2009 | Computers & Internet
I have a compaq hp hardrive trying to install a sylvania 19" Flat screen there is power to the screen but no picture. whta do i need to do to get it running
The first thing to do is to make sure all cables are plugged in tight, all of the power cables and the cable to the pc. This seems to be too simple but it fixes the problem most of the time.
If the monitor still doesn't come on you have to determine which component is not working.
To determine if the monitor works then plug it into a computer that is known to work. If the monitor comes on then it works. again very simple but thorough. If the monitor does not work then you have a bad monitor.
To determine if there is a problem with the computer then plug in a monitor in that you know works. If you still do not get an image on the screen then the component in the PC is broken. If you get an image then something is wrong with your new monitor.
Jan 13, 2009 | Microsoft Windows XP Professional for PC
Please help me:(((( 190g
Oh... poor 4cs,
Sorry to tell you, but you've got unlucky! Your Phillips 190g backlight inverter got fried due to over heating. Need to replaced a new inverter. Good lucks!
Oct 02, 2008 | Computers & Internet
HELLO
you have a problem with blown (bad) capacitors on the pwer board google blow capacitor image and you will find them inside the flat panel soldering will be required.
Jul 03, 2008 | Dell E153FP 15" LCD Monitor
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
22-inch Wide screen X2Gen LCD Monitor
Monitor Help CH000241, No display on the monitor. CH000242, Distorted or skewed image on monitor. CH000243, Monitor has a tint of one color.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Gateway FPD2275W LCD Monitor
Unable to have 1280x768 full screen with DVI cable
Use the menu button on the monitor itself to adjust for the screen size in DVI mode.
On your SVGA adapter, go to your display properties (right click on desktop) click ADVANCED and change the refresh rate to fix the first problem mentioned.
Oct 15, 2007 | ViewSonic VG2030wm LCD Monitor
Computers & Internet Logo
553 people viewed this question
David Payne
David Payne
