Question about Samsung DVD-R135
RE: Problem with SAMSUNG DVD-R135
This product worked fine for about 9 months. It will still play commerical DVDs but wil not read any DVD-R, even the ones in which I have previously recorded with the device. I contacted Samsung to see if they had a firmware update.....but of course they had no suggestions. Any suggestions? Thanks
  • 2 more comments
  • JC1318 Feb 17, 2008
    Thanks, I was able to take it apart and get to the laser.....cleaned it...and seems to be working a lot better. I will use Imation DVD-R from now on. I was sure it was a much bigger problem, so I didnt even think of cleaning the lens. Thanks for the help! -JC1318
  • Anonymous Mar 31, 2008
    I can't get the machine to read any disc, simply want to watch a DVD movie and every one I try comes back with " The disc cannot be played, Please chaeck the disc."
  • rickgr Feb 08, 2009
    I was having the same problem (wouldn't read any DVDs), but the suggestion of turning the power off, waiting, turning the power back on worked for me. At least for now. Thanks a million!
  • ecodave50 Mar 24, 2009
    For awhile the player would reject the disk. After several attempts it would finally play. Now it rejects each time regardless of the number of trys.
    A "throw away" unit??
Cleaning the lens fixed it for me. Take the cover off and look under the plastic guard. You'll see the lens at the center of a platform that moves back and forth.
Posted on Aug 26, 2008
I have tried several brands of dvd-r's. Less than a handful work. I cleaned the lens which did not solve the problem, however, I stumbled upon a fix (sort of). I normally (as we all do) put in the dvd-r when the power is on and get the dreaded "the disc cannot be played" and then the machine spits out the disc. After cleaning, I had left the disc in and unplugged the machine just to look around in there some more, when I plugged it back in and powered on it worked!?!? So I tried it several more times... (1) put disc in, (2) turn power off BEFORE it can give you the error, (3) wait for spindown then power on. All those Frisbees work when I do this. All those discs I thought were coasters work using this method, go figure. Any thoughts?
Posted on Apr 29, 2008
  • zinko Apr 29, 2008
    sorry for double posting, please delete my guest duplicate, thx
    Also, how can I edited my post once it is posted?
I have tried several brands of dvd-r's. Less than a handful work. I cleaned the lens which did not solve the problem, however, I stumbled upon a fix (sort of). I normally (as we all do) put in the dvd-r when the power is on and get the dreaded "the disc cannot be played" and then the machine spits out the disc. After cleaning, I had left the disc in and unplugged the machine just to look around in there some more, when I plugged it back in and powered on it worked!?!? So I tried it several more times... (1) put disc in, (2) turn power off BEFORE it can give you the error, (3) wait for spindown then power on. All those discs I thought were coasters work using this method, go figure. Any thoughts?
zinko
    Problem Solver:
  • 11 Answers
If I understand correctly It would play DVD-R just fine & then it was no longer able to read them. If this is the case, are you using the same brand of DVD-R discs? Some read better than others Try using Imation they seem to read in alomost anything. If you still have problems I would suggest opening the unit & cleaning the lens with a cotton swab lightly soaked with rubbing alcohol. Especially if it has been used in an enviroment wich is dusty or the unit has been smoked around. If it worked correctly in the first place I would assume a firmware update would not fix the problem. It is harder for the drive to read a burned disc than a pressed disc so that is why I recomend cleaning the lens. It has always worked for me.
If it still will not work then I would say that the laser pickup is failling, If thats the case in time it will no longer read retail DVD's
Posted on Feb 17, 2008
Wont play newer dvds
hello,
the problem might be that the dvd doesn't play newer region, or the disc is not compatible with the dvd player.
Jan 07, 2010 | Samsung DVD-R135
Samsung DVD-R130 will not load dvds, but will play CDs
Hey,
have you tried a lens cleaner? the lens may have gone bad and would need to be replaced. Do you have warranty on the player?
Sep 02, 2008 | Samsung DVD-R130 DVD Recorder
SAMSUNG SH853M PLAYS MUSIC CD BUT WONT PLAY ANY
Lens problem is yours is failing the reader has to change
Nov 04, 2009 | Samsung DVD-R135
It won't play some dvd's
sometimes some dvds have tiny scratches that we dont see and if that is case no dvd player will play them I bought a new Bolt dvd and discovered the dvd loose inside and it had tiny scratches where it had moved around inside the box
Oct 01, 2009 | Samsung DVD-R135
Pre-recorded dvds used before now will not load?
Since there are no firmware updates for this device, the lens is either dirty or defective. Unfortunately, the reviews for this product aren't very good. http://reviews.cnet.com/dvd-recorders/samsung-dvd-r135/4505-9141_7-31778396.html
Hope this answers your question. Best of luck.
Greg
May 28, 2009 | Samsung DVD-R135
My lg GSA-H55N dvd writer is not playing Cds but plays Dvds fine
your DVD ROM lens has became weak.
and it cannot be repaired.
But if you manage to open the DVD ROM clean the dust in it & it will start working again but be careful remember that no power should be attached to ROM.
or you can buy a lens cleaner from market and try that.
pls rate my solution
thankyou
Feb 13, 2009 | LG GSA-H55N DVD-RAM Burner
Region problem and disc not reading
For your region problem:
1. Be sure there is no any disc inside the device.
2. Power on your player
3. Press <Menu> on remote
4. Using your remote control enter the code below, note that you must know what Region your player is CURRENTLY set to in order to know which code is appropriate:
for Region 1 use 2, 9, 3, 3, 4
for Region 2 use 3, 8, 7, 6, 7
for Region 3 use 5, 6, 7, 3, 2
for Region 4 use 7, 6, 8, 8, 4
for Region 5 use 5, 3, 8, 1, 4
for Region 6 use 2, 4, 4, 6, 2
5. A code should be displayed on the screen indicating the current Region setting of your unit.
4. Press the 9 (or 0) button on your remote control for Region free, or 1 for Region 1, 2 for Region 2 and so on...
5. Double press the <Menu> button on your remote
6. Enjoy :)
For vcd problem...Make sure that the Cd is written in a format which is compatible with the format with your dvd player. If you have a dvd player that can play formats like, avi, wma, etc. check that your cd writer is set on high quality mode and that the writing speed isn't set too fast. hope i was able to help^^
Jan 03, 2009 | Samsung DVD-R135
Try and find the latest drivers for your drive.
Hope this helps! :)
Nov 23, 2008 | LG GSA-H55N DVD-RAM Burner
Cannot read disc
Had the same type of problem; I called Magnavox on this one. These DVD players aren't "guaranteed" to be able to read discs that were "burned"/homemade. They're only "guaranteed" to play commerically produced DVDs. If you're trying to play something that you made it probably isn't going to work.
Jul 31, 2008 | Philips Magnavox MPD845
I have a Samsung DVD-R 120. It will not read/play, as it comes up with "the disc cannot be read or played, please check disc" on the screen. Even brand new straight out of the package. Which can be played...
Exactly the same problem with mine. I even went shopping today after months of buying dvds that wouldn't play, to buy a new player. I then had a silly revelation. I pressed open and with a tight grip on a cotton bud I swept all that I could reach within the recorder. Can you believe it but it worked. Now I have my multiregion back and it has so far played all of the PAL 2 and PAL 4 dvds that I have bought since the PSO came on months ago. I don't what the problem was or if this is relative to your problem but I wanted to let you know....
Jun 06, 2008 | Samsung DVDR120 DVD Recorder
Samsung DVD-R135 Logo
990 people viewed this question
Henry  Thomas
Henry Thomas
