Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Can't connect 2 computers
I had Sprint and they both worked. I switched to Roadrunner and I can't get both to work. If I connect the cable to the cable modem and then connect the ethernet cable to the Belkin router and then from there to my computers, I thought they should work. One does but the main computer says little or no connectivity.
  • nighttrain Feb 21, 2008
    i switch on both my computors one goes straight to the internetif i switch on my other comp it switches the other one off and vice versa
    Scholar:
  • 89 Answers
Switch the ethernet cables. See if it makes a difference in cables. One might have a break or weak area. That is where I would start.
Posted on Feb 17, 2008
Ok.....my internet is up and running......and im useing the SB5101 Model...but when i switch it back to my SBG900....it gets stuck on the roadrunner (internet provider) web page.....it works fine with the...
Turn the cable-modem off.
Unplug the AC poewr to the cable-modem.
Turn the router off.
Unplug the AC power.
Reconnect the AC power to both the cable-modem and the router.
Turn the router on -- this off/on sequence should "reset" the cable-modem and the router.
If the router still does not work, replace it.
If the cable-modem does not work, get RoadRunner to replace it, if they want to keep you as a paying customer.
Jun 26, 2011 | Arris SURFboard SBG900 Wireless Router...
Connectivity spotty. Sometimes it works and
I would AGREE with the tech and move on here is why,
1. If you tried another cable
2. if you tried a direct connection
3. if you tried a hard reset and firmware
Your pretty much done at this point. there is not much to think about here a router is a little circuit board with a micro-processor and a switch all it does it route data and there very delicate to age,dusty homes,eletricty spikes-outages and what have you. Its not wroth any time of fix and what I call a throw away device.
Thanks and please do leave positive feedback and ratings.
May 29, 2010 | D-Link AirPlus DI-524 Wireless Router
Setup with roadrunner
Connect Router - Desktop
Open RSP By typing 192.168.2.1
On the Left side under Internet WAN Click Connection
Type
Leave the password blank and click Submit
The Connection Type Should Be Dynamic
Click Next
There should not be any Host name & Click apply
On the left Side Click MAC Address Under Internet WAN
Click Clone And Click Apply Changes
It Should Work
Dec 27, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
I loose internet everytime the phone rings
Absolutely. Wireless LAN is on 2.4GHZ. You will want to get a phone at a different frequency.
Apr 05, 2009 | Belkin Computers & Internet
Linksys wireless was fine on my lan line now cable it is not?
Lets see if this works out for ya.
1. In your browser go to http://192.168.1.1
2. The user will be "admin" and the password field leave it blank
3. Go to the Setup Tab
4. On WAN Connection Type make sure it is set to "Obtain an IP Automatically"
5. Go to the DHCP tab and make sure it is enabled
6. Unplug the Roadrunner modem and the Linksys Router.
7. Wait around 15-30 seconds
8. Plug the Roadrunner modem in and wait until all the lights except the ethernet/computer connection are on.
9. When they are all on plug the Linksys router power back in
10. Wait around 30 seconds and see if your getting a connection
Otherwise get back to me. Good luck.
Jan 30, 2009 | Linksys Wireless-G Broadband Router
Changing from DSL to Road Runner Turbo
I'm sorry to say but you cannot bypass the modem capability of the DSL Westell Modem/router because that is really made to function as a DSL modem and a router at the same time, so the best way to make everything work here since you change from DSL to Cable internet just need to get a wireless router like a Linksys WRT54G that can make everything work again like before.....
Nov 05, 2008 | Westell Wirespeed VersaLink...
Dynex wireless modem
Your expert Geokohler helped me fixed the problem and soved it for me. I sent an evaluation giving him a "fixit" rating.
Jul 21, 2008 | Dynex DX-E401 Router
Help!! I'm having difficulty setting up my wireless connection to my ibook!
Last time I checked Roadrunner required you to have them set up the router. However, you should have an existing router from Roadrunner all set up. If you connect your other router which has the wireless capabilities to that then you will be able to use your wireless. Otherwise you will need to call Roadrunner and have them do some configuration on your device.
May 29, 2008 | IBM Computers & Internet
Can i connect a 2wire 2701hg-b with roadrunner cable internet ? I had the 2wire dsl with at&t but recently disconnected the service
It is possible but it may not work as a router (2 wire 270). The 2wired router only has a phone port and ethernet/usb for computer connection. So if you will connect the roadrunner modem to the 2wired, you can connect it to the ethernet port of the 2wire, but the 2 wire will not function as a router any more. It will work just like a wireless bridge. This one setup that you can.
May 02, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
My Roadrunner Modem works fine when connected to an individual computer. When connected through my netgear modem I cannot get an internet connection on any computer wired directly to the router
does the modem worked fine with ANY computer connected directly to it, or just ONE computer connected to it?
did you have to install a connection program on one of your computers when you first installed the modem?
do you have an account name and password from your internet service provider, which is required to connect?
Mar 24, 2008 | NetGear WGR614 Router
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
35 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
