Question about Sewing Machines
Baby lock quest, blq2 bobbin problem
Have a baby lock quest blq2 and I was doing just fine and when I hit the reverse the needle got stuck, and thread jammed. Cleaned up the area and now the needle hits metal and doesn't even pull up the bobbin . Turned the machine off and on, unplugged it, redid the bobbin and it still gets stuck
  • 2 more comments
  • supergoof2 Aug 10, 2008
    Having the same issue. Unfortunately, the dealer went out of buisness after 105 years and I an stuck.
  • Anonymous Feb 20, 2009
    I had the same problem. Turns out the holder of the bobbin case and bobbin was slipping out of position. This is caused by a tiny little metal piece that keeps the item from moving. If threads get caught you can pull it out of place and it will eventually break off... I need to get a new part for this and am on the internet trying to find it...so I can get someone else to put it in for me. I was able to get it working for the meantime by pushing up the metal piece..however it clearly is damaged and will not be able to handle the pressure of the jobs ahead...
    I have been unable to find the part I need online for this. If anyone has any luck let me know. It is the part that hold the bobbin case in place. It has a tiny metal hook that hold it in place. It was bent down on mine and the needles kept hitting the metal..bending...etc. I bent it back up but there is clearly a crack in it. I just emailed babylock to see if they can help me also... A parts list would be helpful but I have nto been able to find that either. anniesp2001@yahoo.com
  • anniesp Feb 20, 2009
Concerning the Babylock Quest when using the reverse option I seem to be reading a few somplaits what is the best way to reverse without causing and adverse problems?
thanks
sewingcindy
Posted on Jun 13, 2010
    Problem Solver:
  • 15 Answers
Is the needle bent?
Posted on Feb 20, 2008
This is the part you may need if you are having a problem with the bobbin case slipping out of position...Baby Lock support got back to me:
Dear A***, Thank you for contacting us. The part number needed is R1A0534000...a CERTIFIED technician will need to replace this part, due to an adjustment that is needed. For your convenience I have listed the Baby Lock retailers in your area:*****  Should you have questions or need further assistance, please feel free to contact us. We do appreciate your use and support of our products. Sincerely, Cindy Baby Lock USAc.corley@tacony.com 800-313-4110 (8:30-5:00 CST)
Hope this helps...you will need a service center to order the part and install it.... sorry..no quick fix but hope this helps. I have not had the repair done yet..so I have no idea if it works.
Posted on Feb 21, 2009
It sounds like your timing is off now so the needle will continue to hit the bobbin as it turns. It needs to be adjusted so it doesn't do this.
Posted on Mar 12, 2008
Baby lock BLQ2 needle hits on bobin
repair shop time the timing is off
Nov 01, 2017 | Baby Lock Sewing Machines
WHY??!! *Check if thread is entangled. Check if needle is bent. So far as I can tell everything is fine, used new bobbin, new needle, still getting error. How do I know if the motor has become locked
Time to take it in and have the repair tech service & clean upper tension assembly. When you clip/ change threads be sure not to pull the thread back out of tension assembly. Snip thread at spool, raise foot to release tension and then pull the short thread out from the needle. The Automatic tension is very delicate and pulling thread out backwards can cause thread/lint build up and problems like your having. Sal the Sewing Gal
Oct 30, 2015 | Baby Lock Ellure
WHAT DO I DO TO GET MY BABY LOCK ELLURE ESL TO PICK UP THE BOBBIN THREAD?
You have your bobbin inserted into the machine spinning in the wrong direction. take the bobbin out and flip it over and wind around needle plate guide and cut. Look at the little pictogram on the plastic part of the machines throat plate. It shows which direction the thread should spin off the spool when you drop the top loading bobbin into the bobbin case.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Aug 30, 2014 | Baby Lock Ellure
Baby lock quest
The top thread is looping right? This particular machine loves a well oiled hook system, and it needs to be vacuumed out regularly. Compressed air is not good on this machine, actually it is not good on any machine if the covers are on. So check for thread trapped inside the hook system by flooding with oil and oscillating the machine back and forth for a few minutes.
Two other possibles: something is snagging the top thread like thread trapped inside the hook system or a little burr on the stitch plate. Moving faster means the fabric tractors harder, so any burrs will be mre noticeable.
Dec 03, 2013 | Baby Lock Imagine
Bobbin thread shows on embroidery machine
Did you remember to put down the presser foot?
Nov 13, 2012 | Baby Lock Sewing Machines
I have a ellure baby lock sewing machine. It will sew fine for a while and then the bobbin tread gets tangled up and breaks the needle thread. What should I do?
first change the needle
rethread the machine top & bobbin
use every thread guide
clean under the needle plate & in the bobbin area for lint
make sure the bobbin is not warped or damaged
make sure the bobbin is not to full
make sure the bobbin is inserted correctly & turned correctly in the
bobbin case
make sure there are not any burrs on the needle plate
make sure there are not any burrs on the bobbin case
Jul 09, 2012 | Baby Lock Ellure
Threads stuck under needle plate
take a tiny screw driver & gently unscrew the screws in the needle plate ,, make sure not to damage the screws & clean out the thread & any lint in that area & also the bobbin area
because if the screws are the slightest bit damaged then when you sew & the fabric moves over them the burrs on the screws will pull the threads in the fabric & can damage the fabric
Mar 06, 2012 | Baby Lock Evolve
Not picking up the Bobbin thread
Sounds like you have to take off the throat plate and clean out threads under it.  Sometime they ball up and prevent the needle from going down and catching the bobbin thread. You can't see themuntil you take off the plate.  Follow the directions.  It is easy.
Dec 28, 2008 | Baby Lock Ellure
I cleaned the machine good with canned air, oiled it. I took out the bobbin case and cleaned it good also. I then noticed the tension screw on the bobbin case was loose, tightened it and the problem was fixed.
Nov 14, 2008 | Baby Lock Esante
Sewing Machines Logo
905 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
