Question about HP PSC 2210 All-In-One InkJet Printer
Paper not clearing after printing
When a page is printed, the paper is not given that extra little "kick" at the end to deposit it on the exit tray. Instead it sort of sits just beyond the rollers and when the head returns to the right side to print the next page, the previously printed page is mangled. Could use some help.
The rollers might be worn out. If that is the case then it would be better to buy a new printer instead of getting that one fixed. It would be cheaper.
Posted on Feb 18, 2008
I have a Samsung scx 4623fw printner. When I print one page, the machine will send 2nd page following first page causing page 1 jam at exit 2 and p2 jam on exit 1. It happens every time. Can someone h
On the document that you are trying to print, go to the very last word, of the last page.. hold the shift key down & use your down arrow to highlight anything below, no matter how long it may be highlighting white space. Hit your back arrow once. Check the last word for punctuation & spelling, resale your document & try to print again.
A lot of times in the course of 'composing', extra carriage returns or tabs or spaces, are added to the bottom of the document. I have just explained how to clear the second page printing. It may also remove the erroneous codes that may have formed.
Rebooting a printer has the same good effect as rebooting your computing device. It clears up a lot of confusion that has stacked up since the last time you did it.
If you have printed labels with this same printer, you may have part of a label throwing off the paper path. Also make sure that the paper guides in your paper bin or manual feed area are close, but not touching or pinching the paper. This can cause paper to go off of its normal print path.
Good luck.
Toby.
Aug 31, 2015 | Office Equipment & Supplies
Tip
HP LaserJet LJ 4350 locks up when duplexing
Symptom: Your LaserJet 4350 prints just fine until you try to print a double-sided page. Then you see the page start to exit, pull back in, then stop. The Data light continues flashing green, and the display reads, "Processing..." There is no error indication, but the machine won't print the second side and continues to hold the half-printed paper in the duplexer. If you open the top cover and close it again, the printer will eject the page, then try to print the whole thing again, unless you're quick enough to cancel the job first.
Cause: The printer is expecting a different sized paper than what it's running. Often it's not the menu settings, but a little lever in the paper tray itself. Pull out the paper tray you're trying to print from and look for a little blue lever on top of its right-hand side. The lever is labeled "Standard/Custom." Flip it to Standard (parallel to the tray side) and your problem should go away.
on Mar 17, 2010 | HP LaserJet 4350dtn Printer
How to stop printing once it has started
For Brother Laser Machines. Start by pulling the paper tray out a little. This allows the page that is currently feeding through the system the chance to get through without jamming causing a whole slew of other problems.
Once the printer has stopped trying to feed the pages through coming up with an error saying paper out then you can look at deleting all the print jobs in the print queue on your computer. All but the one currently being printed should disappear when you delete them. The one that is left will be errored.
Then turn your printer off for 30 seconds closing the paper tray and try to delete that last job from the queue.
If it will not go then turn your printer back on and let the last couple of pages print out. these are pages that are stuck in the system. If the print job did disappear then just turn on your printer as normal and it should be clear of any jammed printing and you don't end up with Paper Jams in the printer to clear.
Sep 06, 2014 | Brother HL Office Equipment & Supplies
Ricoh AP3800C "Output tray full"
Check the little black piece of plastic that senses the printed page exiting the machine. Our sensor was stuck and I was getting the same message (an similar Ricoh product). When I gently reset the black piece to center, moving freely, printing worked again. I think the sensor got jammed up when we were trying to remove a bad paper misfeed.
Ricoh manuals very confusing on this error message. They refer to standard tray, tray one, etc. without being clear whether it's a paper feed tray or the so-called "standard OUTPUT tray." The output is not really a tray, it's just the depression where your sheet lands after printing. I wrenched on the paper feed trays and their settings for an hour before I figured out they meant OUTPUT.
Feb 27, 2009 | Ricoh Aficio AP3800C Laser Printer
Installed new 084K18470. Error e2-3 will not clear.
E2-3 is paper jam at tray 3 check paper path as paper exits this tray.
-Carl, please let me know if this helps.
Jan 21, 2009 | Xerox Phaser 4500/YDX Printer
Mp810 paper feed issue
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Dec 31, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Paper jam error after last page prints
Hi Natoli3,
This could be a mis-match of paper sizes. Example, computer could be sending an A4 page to the printer. The paper size in the could be set to Letter. Ensure the 4 paper sizes match, in the computer - the document and printer driver; in the printer (change in control panel) and paper tray (adjust the physical side and length).
S88
Oct 23, 2008 | HP LaserJet 4100 Printer
Printing
Dear jamin4volks;
As per this excerpt from the Oki B4350 User manual:
"FACE UP AND FACE DOWN PRINTING
For face down printing, make sure the rear paper exit tray is closed (the paper exits from the top of the printer). The paper exit bin on the top of the printer stacks printed pages face down, capacity 150 sheets of 20 lb. paper. Pages printed in reading order (page 1 first) will be sorted in reading order (last page on top, facing down).
For face up printing, make sure the face up rear paper exit tray is open and the paper guide is extended if required. In this condition, paper will exit via this path, regardless of driver settings. Paper is stacked in reverse order, capacity 50 sheets of 20 lb. paper.
Always use this tray and the manual feed tray for heavyweight stocks to reduce the possibility of paper jams."
This manual is available at http://my.okidata.com/mandown.nsf/(MOC-B4350)/BE70FCAF93D577E285256E89005052F9?OpenDocument
Hope this helps;
Frank
Apr 18, 2008 | OKI B4350 Laser Printer
Printer won't stop jamming
sounds like your printer wants to form it's own three piece band(kidding here).
sounds like you rollers are dirty or have something on one or both of them..like tires on a slippery road, these need to be clean and dry.
Mar 08, 2008 | Samsung CLP-600N Laser Printer
HP IIIp prints extra blank pages
HI there make sure that the paper tray guides are fully against the paper also try sending the job through the manual feed to see if you get the same problem. If you do not then it maybe that the paper cassette separation pad is worn and will need replacing. If your model has no rubber pad at the front of the cassette then you will have a metal hold over one corner of the paper make sure that when the paper lifts that the paper sits under the silver (Dog Ear) as this acts as a separator.
Hope this helps
Thanks J
Jan 28, 2008 | HP LaserJet IIIp Printer
HP PSC 2210 All-In-One InkJet Printer Logo
24 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
