Question about Canon BubbleJet i550 InkJet Printer
Canon i550 i have a canon i550 and have lost the start up disk ..i have just got a new pc and can not print from it? how do i get my pc to print from it?
  • Anonymous Mar 17, 2008
    the 'old' driver disk is not compatible with my new 'vista' system. How do I get a upgrade disk that is compatible?
  • tero2 Mar 23, 2008
    i can fine the disk for me canon bubblejet i550 injet printer and am trying to install it please help me
    Problem Solver:
  • 8 Answers
Download the driver from Canon website, look at support page.
What operating system are you using ?
Posted on Feb 18, 2008
I lost my Manuel and when I try to print something
Here is a download page for your manual:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=331&modelid=8046
as for the settings........
Go to0 the start menu, select "printers and devices"
select your printer, select printer preferences,
and change the setting from the menus.
There ya go!..........Please remember to RATE ME. Thank You.
Mar 08, 2010 | Canon BubbleJet i550 InkJet Printer
Canon i550 yelow light on: "operator error" . Have tried to resume and delete printing tasks and restarted printer
Had the same problem with my I550. Was going to buy a new printer (I4000) since I could get one for about $30 more than the price of a new print head. I like canon printers with the individual ink tanks and have had no problems with the I550 for about three years.
Decided to try moving the paper thickness lever back an forth a number of times since some of the error messages indicated it could not determine the setting of the paper thickness lever. I don't know how the printer determines this switch setting but I thought if some contacts are slightly oxidized that movement might break up some of the oxidation. After operating the lever about a dozen times the printer started working. Hope this will help.
Oct 12, 2009 | Canon BubbleJet i550 InkJet Printer
My i550 Canon Printer will not print colour, black only. Colour cart. are full. Computer checked out OK. Driver is OK. All 3 colours stopped printing at the same timeannabellamt
My i550 Canon Printer will not print colour, black only. Colour cart. are full. Computer checked out OK. Driver is OK. All 3 colours stopped printing at the same time. linda gal16
Jul 06, 2009 | Canon BubbleJet i550 InkJet Printer
Canon i550 printer stoipped printing
My cannon printer no longer responds to any commands. I get 4 yellow blinking lights and then 1 green blinker.
Oct 09, 2008 | Canon BubbleJet i550 InkJet Printer
Canon i550 will not print
Have you checked the settings in the Manual?
If it's missing you can download from
http://software.canon-europe.com/software/0023008.asp?model=
Aug 30, 2008 | Canon BubbleJet i550 InkJet Printer
Canon i550 cannot print
Try the below procedures maybe the error of your printer is the waste ink counter.
Canon i550, i560, i850, i950, i960 (May work with i860, i865)
1. Start with the printer OFF
2. Hold down RESUME and then hold down POWER
3. release RESUME
4. press RESUME twice, then release POWER
5. Let green light blink until printer is done moving print head.
6. Select functions below with RESUME press POWER to execute:
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Apr 10, 2008 | Canon BubbleJet i550 InkJet Printer
Canon i550 doesn't print correctly
---Is the incrustation of the heads or the ducts such that I need to throw the i550 away
This one...
I had 3 Canon i550 and i560 printer, unfortunately if you use non original inks and leave the print head with no ink cartridge for some hours the ink can dry inside the print head = dead.
I have try several methods of cleaning print head and waste a lot of time on this, finally here some suggestions:
- use pure alchool (at least 90 °) to clean the print head, you can also use clear water but after you had to rinse with alchool because alchool removes the left water that can cause shortcircuit when you power on the print head.
- the electrical connections of the print head (brown ribbon with integrated circuit path) are very fragile if you decide to unmount the print head removing the 2 phlilips screws you must be VERY careful
- for black ,one safe trick is to remove the round (8 mm) glued upper metal sheet filter on the upper part of the print head where the ink cartridge sets. Once removed you can use a syringe needle filled with alchool to remove the dry ink and spray alchool into the small duct hole to remove all the bad dry ink. Be patien it will take some time. You can also leave the syringe filled wyth alchool and without the syringe piston for a night inside the duct hole.
Take a look to the service manual also for other inspirations:
http://rapidshare.com/files/91114670/Canon_i550_i850_i950_Service_Manual.pdf.html
Nov 11, 2007 | Canon BubbleJet i550 InkJet Printer
Canon BubbleJet i550 InkJet Printer Logo
124 people viewed this question
old marine
old marine
