Question about Sony Handycam DCR-TRV740 Digital Camcorder
Video camera displaying Error code C:31:23
My video camera is displaying and error code C:31:23. This error code isn't listed in the service manual. It won't let me play tapes or record them. Hello, I have the C:31:23 fault code on my Sony Handycam DCR-TRV740 Digital-8 Digital and giving it a good whack does not help. I have tried removing the battery, reset button and changing tapes and nothing. Can you give me any other advice? Also, can you clear up the rumor about Sony making a free repair for the 31:23 fault until Sept 2008? Thank You. Mike
  • Katiedoo Feb 26, 2008
    I'm having the same problem, tried all the same things.
  • Anonymous Aug 03, 2008
I have been fighting the same problem. I just now picked up the camera and a small rubber roller fell out of the tape door area. I was not sure where it came from but looking closer there are 4 small rods sticking up on the right side inside the area where the tape is located. It looked like this was where the roller went so I placed it on the center rod and replaced the tape. This solved the problem and I am now able to view and recored as before. There most likely is a part that has either fell or broken off or is loose inside the tape area.
Posted on Aug 03, 2008
THe most common beeps that you will encounter 95% of the time in repairing PC's are:
1 beep - computer ok
continous beeps / long beeps - memory error
continous short beeps - bios boot block/corrupted bios
1 long beep followed by 3 short beeps - video card error
or this might help
you can check out this list
1 short - Computer ok
2 short - RAM failure
3 short - Parity RAM failure
4 short - System timer failure
5 short - Motherboard failure
6 short - Keyboard controller error
7 short - CPU failure
8 short - Video RAM failure
9 short - ROM BIOS error
10 short - CMOS read/write error
11 short - Cache RAM error
1 short, 3 long - Memory failure
1 short, 8 long - Video adapter failure
Check board/chipset makers website for more infomation.
1 long - Memory error
1 long, 2 short - Video error
1 long, 3 short - Video failure
Continuous beeps - Memory or video failure
note that AWARD relies on motherboard manufacturers to develop their own beep codes - the above are only their own internal codes. You will need to refer to your own manual for an explanation of precise codes.
Standard IBM beep codes.
No beep - Power supply or motherboard failure
1 short - System is ok
2 short - POST error (code displayed on screen)
Repeating short - Motherboard failure
1 long, 1 short - Motherboard failure
1 long, 2 short - Video display adapter failure
1 long, 3 short - Video display adapter error
3 long - Keyboard error
Pheonix beep codes
1-1-3 CMOS memory failure
1-1-4 BIOS failure
1-2-1 System timer error
1-2-2 Motherboard error
1-2-3 Motherboard error
1-3-1 Motherboard error
1-4-1 Motherboard error
1-4-2 Memory error
2-x-x Memory failure (any number of other beeps)
3-1-x Chipset error (any number of other beeps)
3-2-4 Keyboard controller error
3-3-4 Video adapter failure
4-2-4 Expansion card failure
4-3-4 Time of day clock failure
4-4-1 Serial port error
4-4-2 Parallel port error
4-4-3 Math co-processor error
pls rate as fixya if it helps. thanks
Jul 04, 2008 | Acer Aspire 5100 Notebook
Video camera problems - Sony Video Camera problem
Error code 94:01 is an internal memory error. If you still get the error after reformatting the card or trying a different one, it's an electronic issue usually used by component failure and requires replacement of a circuit board within the camera.
Jul 12, 2014 | Cameras
How to boot dell inspiron one 2020 when it only beeps
the number of beeps will tell you what the problem is the beeps are an error code here are the code list for your computer
Beep Code Description No Beeps No Power, Loose Card, or Short. 1 Short Beep Normal POST, computer is ok. 2 Short Beep POST error, review screen for error code. Continuous Beep No Power, Loose Card, or Short. Repeating Short Beep No Power, Loose Card, or Short. One Long and one Short Beep Motherboard issue. One Long and Two Short Beeps Video (Mono/CGA Display Circuitry) issue. One Long and Three Short Beeps. Video (EGA) Display Circuitry. Three Long Beeps Keyboard or Keyboard card error. One Beep, Blank or Incorrect Display Video Display Circuitry.
May 25, 2014 | Dell Inspiron One 2020 All-in-One Desktop
Wat do;s Err-80 meen
Looked up on and this is what I found.
FAQ: What does the error code 'Exx'?
FAQ ID: 44574
Last Modified: 22-Jan-09
When an error occurs the camera will display an error code like "Exx", where "x" represent numbers.
See the list items at the bottom of this page when it shows following error codes.
"E18" error of the target unit / lens barrel
"E30" and "E50" error of the CF or SD card
When an error code "Exx" different from those already mentioned, the camera off and then turn to try to capture or play back images.
If this error persists or an error code appears often, there was a malfunction of the camera.
Note the error code and contact the retailer where you purchased the camera or the nearest service center for Canon.
I hope this helps
Jan 24, 2012 | Canon EOS-D30 35mm SLR Camera
C:31:40 error code displayed on power up
Error code 31:40 indicates a problem in the cameras tape transport system. This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly, a defective clutch in the take-up spool or a faulty rotary mode switch. This will require disassembling the camera to repair and can be done fairly inexpensively. However, it's not really a user serviceable problem and should be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on .
Sep 11, 2011 | Sony Handycam DCR-TRV110 Camcorder
Service 900 error message
900 Error Code service check
1 Printer POR
Turn the printer off and on several times. If Error Code 900 continues
to display, go to step 2.
2 System board
Make sure the system board is properly seated in connector J7 on
the interconnect board.
Turn the machine off and on several times, waiting a few minutes
between power on and power off.
If Error Code 900 continues to display, go to step 3.
3 Factory defaults
Restore factory defaults. See “Restore EP Factory Defaults” on
page 3-18. This resets the non-critical areas of the user NVRAM. If
Error Code 900 continues to display, go to step 4.
4 Sub error codes
With Error Code 900 displayed, press Select and Return. Record the
complete list of Sub Error Codes on the display. Check the “Base
printer sub error codes” on page 2-6. If none of the Sub Error
Codes are listed, then call your next level of support.
From page 2-41 of IBM's service Guide
Feb 15, 2010 | IBM Infoprint 1352 Laser Printer
Error 8007045a: cannot create video capture filter. I get this error when i have installed the google video and chat. i have an INTEX IT-305WC night vision camera. when i go to devices in the camera exe...
I have windows xp and my web cam is pc camera 120 when I opened webcam nothing is displayed on the cam. It is displaying black screen. When I selected google camera adopter it is displaying 8007045a error. How can I solve my problem.
May 15, 2009 | Computers & Internet
Is there an easy fix to Panasonic AG-DVC7 camcorder error F05, cylinder lock?
when you press the reset button, the first thing the camera does is a self-test of the mechanism. "cylinder lock" is displayed when the video rec/playback head drum (cylinder) motor does not operate or operates intermittently. this is usually caused by a poor connection on the small cable that connects the head drum assembly with the main control circuitry inside the camera. disassembly of the camera is necessary to clean and re-seat this cable, along with the cable that carries the video information to the head drum. I have repaired several of these cameras with this problem. it's not difficult, but an inexperienced repair person can do more damage than help if they're not careful.
Dec 10, 2007 | Panasonic Proline AG-DVC7 Mini DV Digital...
Believe it or not, giving it a bash got it to work. Not too hard, just a few sharp smacks on the side.
It's something in the cassette carrier mechanism.
Nov 30, 2006 | Sony Handycam DCR-TRV140E Digital...
Sony Handycam DCR-TRV740 Digital Camcorder Logo
981 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
