Question about Mitsubishi WS-65809 65" Rear Projection Television
Need a "Mitsubishi HD-1080 HDTV Receiver" to convert my TV to HD
I purchased this TV used and I want to buy the "Mitsubishi HD-1080 HDTV Receiver" to convert it to HD but I can't find one. Does anyone know where I can find one?
  • 6 more comments
  • Randy Grueneberg Jul 29, 2008
    Does anyone have a Receiver like there talking about to sell?? Thanks Randy
  • SkimmerTech
    SkimmerTech Dec 03, 2008
    'The BigKids' - Do you still those receivers left for the Mitsu WS - i am interest in purchasing one....thx jjk
  • WILDWIL Dec 04, 2008
    I ALSO NEED THE 1080 RECEIVER. HOW CAN I GET ONE?
    I ALSO NEED A RECEIVER. HOW CAN I GET ONE?
  • adamj40 Dec 12, 2008
    im also looking a receiver. will any atsc tuner work with this tv?
  • Johna670 Jan 26, 2009
  • djme1l2e Mar 28, 2009
    JMC56,
    I have a Mistsubishi WS73903 that I am trying to get hd on but it only has the rgbhv connections. I tried hooking up regular component rgb from my hd satellite and dvd player but get no picture. Do you know if this model tv has some sort of setting that I need to change to make it work? Also, what about hooking my tv up to my laptop to get the signal, I have an hdmi output which doesn't help since the tv doesnt have that input but it also has a vga output, I have seen adapter cables from vga to the bnx- rgbvh that is on the set, will it work to hook up the computer? I have an hd tuner in the laptop that I can watch tv on so I thought maybe this wold help. Also, do you know if there is an hdmi to bnx-rgb adapter and would that work? Sorry for all the questions, just frustrated that I have this supposedly hd tv that I cant hook up to anything hd. Thanks for the help!
  • Anonymous Mar 17, 2014
    I need to program my tv mitsubishi 1080
You con't need to buy anything other than a HD satellite or cable box. A television can either handle HD or not.  The high definition sets are monitors that are capable of handing an input of up to 1080i.
Quick and dirty. Look in the back for blue, green, red cable input sockets. There should be matching cable outs. from your cable or satellite box. get a set of  component video cables, plug them in. Determine the audio type, where RCA jacks, Toslink fiberoptic or a component cable sock. In the latter you use a cable much like a yellow video. You can get away with using a yellow video cable if need be. Now, below more specifics if needed.
No, you don't want to by the add-on from Mitsubishi.  I am assuming you have a 16-9 wide format box
If you have a squarish box, i.e. 4:3 ratio. forget it. I don't know if any wree made for HD, but unlikely.  If you'd given me the model number could be a little more definitive. If you have a manual, it will tell you whether you can go HDTV.
Take a look in the rear of the set and look at  the connection holes. You should have at least one set of inputs, marked in some way with the Red, Green and Blue just on the inside of the cable hole. Those are tomponent cables pops that allow you to do high definition television. These cables are video only.; Sound is a second separate question.
There are usually some other assorted things back there, including off air tele.and maybe another kind of connecter.. Some of these might be useful if you have games etc. that attach directly to the set. In any event, those component cables say that you can  do HDTV. (NB:
The Direct TV  HD box should have component cable outputs. You can do this directly from the DiTV box to the set. You would also need a separate Audio Cable(s). Your set should have either a toslink fiberoptic hookup and/or a component audio cable. There's no inherent advantage between those two. If you have an old video cable (yellow) than you can substitute that.
You should now have HDTV and high quality sound through the set. You will probably have to set up the inputs and other stuff with the.remote. It's pretty logical. If you have used input x for bringing in the video, just match it up.and your on your way.
If you are going to confuse things by trying to connect another piece of gear, e.g. dvd box, you would go to inputs two. If you have the second set of component input, then hook an HD player to it. In this setup, you adjust the sound on the set according to how it works. I assume the DTV audiio can be controlled directly just as a cable box.  -- Here's what's going on. For several years Mitsubishi built higher end televisions without tuners or slots for cable (or satellite). But they were HD capable (as I said, not all). At the time, there was no HD that mattered and not even much of a standard for it. Some wanted 729p, others wanted 1080i The advantage for 720p over 1080i was supposedly the improved movement capture. 720p isn't dead, but it's not a problem.
You will need to set the menu on the television (using the remote) so that it says 1080i. It does not do 1080p, the newer high standard. It only has two other settings of consequence, 480i and 480p. Put it on 1080i and leave it alone. The 480i and the 480P will be on auto pilot if you have an older DVD players. If there is a high definition signal at fewer than 1080, it will be upconverted to 1080i..
The set will handle any signal you send it like that. You probably have an HDMI  out from your dtv or cable box. The set does not have HDMI (unless on a later model). The DTV box should have both of them. That's a simpler wiring setup that allows 1080P. On the offchance you have a box HDMI only, you'll need a converter cable.
The setup gets a little more  complicated if you're using a receiver as a switcher, i.e. all inputs go there with only one output to the set. when ou do that you're in an area outside this question.
  is this all there is to it. But It goes only slightly more difficult if you're hooking up the   .
You don't need the box for the television set.
Posted on Jan 22, 2009
  • jwalker3965
    jwalker3965 May 14, 2012
    jmc56 does not know what he is talking about. The old Mitsubishi HD TV came out before the industry standardized on an HDTV interface cable. You can get the converter box directly from Mitsubishi.
I have a HD-1080 Receiver. gbothesr@verizon.net
Posted on Apr 24, 2010
  • 22 Answers
I've got a Mitsubishi HD1080 receiver (this requires the 15 pin D connector for control from the TV, and has 5 BNC connectors (red, green, blue, H, and V). If this is what you need, let me know. I've got no use for it, I'm sure we can come to a agreeable price
Posted on Mar 31, 2009
Cable company is what I went with. You'll need a cox cable anyways if you want to record television.
Posted on Mar 15, 2008
    New Friend:
I have a few of them, brand new. Contact me. Guarantee cheapest
Posted on Nov 22, 2014
  • 1 more comment
  • Dennis ONeal
    Dennis ONeal Jan 04, 2015
    i need one
  • Phil Bilskey
    Phil Bilskey Jan 07, 2015
    i need one also
  • Anonymous Nov 08, 2015
    If you have any more. I need one
I have one. $20? hit me up.
Posted on Nov 13, 2014
If you are still looking for this i have 5 of them left , brand new, hit me up and can list them for you on ebay.
Posted on Jun 04, 2008
Does anyone have another one of those receivers? I just got a Mitsubishi WS-73903 and I am in need of one so i can get high def.
Posted on Nov 18, 2009
Mitsubishi ws-55805 HDTV Control to HDMI
there is a converter box , where you can connect everything and convert in to hdmi output , you can buy this boxes on the internet or at the redioshack
Feb 12, 2012 | Mitsubishi WS-55315 55" Rear Projection...
I have a Mitsubishi 55" 1080 HD TV with a blurry
info16939,
You need to go to my tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which should solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 15, 2010 | Mitsubishi WS-65313 65" Rear Projection...
I bought a used mitsubishi ws 55513 and when i turn the tv on is says 480i stretch. How do i use the 1080?
U don't get to chose modes.480,720 and 1080 it chose by the tv show itself.Want more 1080 must have HD package from cable or satalite compannies.
Jan 26, 2010 | Mitsubishi WS-55513 55" Rear Projection...
BLUE RAY 1080 (p) PLAYERS INHANCE VISUAL HD ON 1080 (i) tV
try to see if u have hdmi slots and check the highest resolution it can go.there is a higher resolution called hdcp,with not div x but dvi-d where resolution can go up to 20000
Feb 06, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Connecting TV to cable service for HDTV
normally you need a converter box for hd because normal stations are broadcasted in hd.....its not common enough for them to do it...and you probably have to buy a package with your cable company for the hd channels. another thing...is your tv hd ready?
Sep 30, 2008 | Mitsubishi WS-48313 48" Rear Projection...
Need a Receiver! can you Help?
I HAVE THE AME TV AND I DID NOT HAVE TO GET A HDTV RECEIVER BUT NOW I GOT GREEN SHOADOWS IN TV WHAT COULD THIS BE?
Jul 29, 2008 | Mitsubishi WS-55859 55" Rear Projection...
1080 VS 480
Trash can it and buy a new T.V.
Jan 06, 2008 | Mitsubishi VS-50111 50" Rear Projection...
Upgraded DirectTV satelite TO HD
direct tv hd receiver is hdmi or rgb which is a different signal than the rgbhv input on the back of older mitsubishi tv . You can buy a converter that converts the format for about 90 dollars online. It converts rgb or component to vga/rgbhv
Oct 24, 2007 | Mitsubishi WS-55805 55" Rear Projection...
HD setup, 480 to 1080 not working.
I had this same problem, got my HD installed yesterday w/ Direct TV, have had this TV since '02. The fact that is wasn't working, and Google, led me to your post in search of answers. I even went to a local retailer that sells the Mitsubishi TV's and they were as helpful as if I had gone to a drug store seeking the answer. So, between browsing other posts, and then going to the manual (who'd of thunk) I got my, and your, answer. You need to do the following, nothing magic: 1)Connect the component video output of the Direct TV HD Receiver to the DTV inputs on your TV. The COMP 1/2 inputs are NOT 1080 compatible, only the DTV input. As another poster said, you must use component video cables, not the old red/yellow/white cables. you can lose too much signal quality w/ the old R/Y/W cables and your TV still won't recognize the 1080. 2)Set your receiver to a HD Channel, which are in the 70's. 3)Use the format selection on your remote and select until you get the 1080i Standard (or whatever your preference is) format. 4)Enjoy Bottom line is the COMP inputs are not HD. Page 64 of the manual (at least the one i downloaded from mitsubishi-tv.com) is what gave me the final piece of the picture. Good Luck!
Sep 20, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
5,047 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
