Question about Toshiba Tecra 9100 Notebook
CD-RW/DVD-ROM can not read and CD or DVD
I have Toshiba Tecra 9100 netebook. Its CD/DVD ROM can not read CD recently. I tried my CD and DVD. It doesn't work even the original recovery CDs. The CD can rotate inside the DC driver. The reading led indicator show that it is working but the files in CD can not show up.
Is this CD/DVD ROM damaged? Any suggestion? thank you very much.
    Genius:
  • 3,587 Answers
Yes..it's most likely kaput. I have a tecra, and I'm on my second CD/DVD replacement. They are easy to find and replace(one screw underneath, and just slide em out)..
Posted on Feb 17, 2008
Is it possible that a cdrw/dvd of Toshiba Tecra M1 be replaced with a dvdrw?
Yes, it is possible to replace CD, DVD with DVD+RW on Tecra M1. Generally, it is possible to upgrade optical drive on almost all the laptops.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 27, 2011 | Toshiba Tecra M1 Notebook
Hello! i have a laptop,Toshiba Tecra T9100.The Cd-rom is not working and i whant to reinstall the windows from usb boot-able. in BIOS i cant find nothing like this...to boot from USB! HELP!!!!!!
press f8 as you on the laptop and you will get the " select boot device " menu. here you can select the usb drive.( keep the drive connected before you on)
PLS REPLY OR COMMENT. THANKS
May 16, 2011 | Toshiba Tecra 9100 Laptops
CD DVD ROM doesnt read dvds when i insert the disk the light turns on i can hear the dvd turning but later on it stops. turn and stop again. then it doesnt read the dvd anymore
how long have you been using this CD ROM? I suspect the laser (lens) of the CD ROM. I think the laser (lens) is weak that's why it cannot read data/files on DVD.
To confirm if actually its a laser problem, insert an Audio CD into the CD ROM and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the CD ROM cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new CD ROM.
Good luck...........
Mar 18, 2011 | Toshiba 100GB Laptop for Satellite 2400,...
DVD/CD-RW-Device does not read any CD'Rs.
The drive must have "died".
If the computer is still under warranty, contact Toshiba, and get it repaired.
If the warranty has expired, take the computer to a qualified technician, who will remove the dead unit, install a new drive, and reassemble the computer.
Cost will be about $60 for "one-hour-labour", plus the cost of the new drive.
Apr 10, 2010 | Toshiba Tecra 9100 Notebook
Cant read cd/dvd
The problem will be in a lens of the driver of your computer.
Try to clean by any lens cleaner cd and check it
If then also it is not working means contact service person and submit for repair
Mar 04, 2010 | Toshiba (SD-R2412) for Satellite A10, A15,...
Toshiba SD R2312 CD-RW/DVD-ROM
I have the same problem like you.one of the expert shared to me that my burner has faulted. I thing your problem is worse than mine cause I can still read cd rom vcd/ DVD files and movies. Just finfd new one that will give you quality output.
Aug 27, 2008 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
DVD-RW, DVD/CD-RW drive
J-rad72,
Yes, Sorry for the bad news, that drive has gone bad and has to be replaced. It has to do something with the drive board causing the issue.
PAeasop.
Apr 20, 2008 | Toshiba Tecra M1 Notebook
Toshiba A30 - DVD-ROM CDRW
Wow, That's a weird malfunction. Only TDK??? What about other media types? Did you try a diffrent burning software?
May 12, 2006 | Toshiba (SD-R2412) for Satellite A10, A15,...
Toshiba Tecra 9100 Notebook Logo
201 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
