Question about Vizio GV42L 42 in. LCD Television
Vizio lcd screen on tv tells us it's 480psd, we bought this unit thinking it was a 1080 like it states on the box.
  • 31 Answers
This model supports the following formats: 1080i, 720p, 720i, 480p, 480i. Most likely it isn't the TV that is not allowing the 1080i resolution but rather your cabling or the inputs that you are using.
Be sure that that you have an HD signal coming into the TV. You may have to upgrade your cable subscription or if you already have the channels sometimes you have to tell your cable box to use 1080. The same goes for DVD players; they often default to only 480 to maximize compatibility.
The other area to check is your cabling. For the best results use HDMI or Component video.
If you have already checked both of these options let me know & I'll try to come up with some other options for you.
Posted on Feb 17, 2008
VIZIO Tv E422VA picture showing red or green color on dark areas of screen.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 29, 2015 | Vizio E422VA 42-inch Widescreen LCD TV -...
We just bought a Visio LCD TV 42 inch. The problem is with the volume going up and down on its own. We took it back and got another Visio and it's doing the same thing. Do you think the problem is...
Hello there, the probability of 2 Vizio LCD's having the same problem is quite abnormal. The problem is definitely from the cable box as LCD TV's are usually factory tested to ensure that such problems dont exist in the unit. Check the cable box and also check the cables with which the cable decoder is connected to the TV. This is where your problem is from.
Hope this support has been helpful?
Thank you for visiting FixYa.
Sep 06, 2011 | Vizio Televison & Video
I have a Vizio LCD HDTV 1080 120hz 37", ModelSV370XT. (Bought 1/10/10 at Costco) The tv fell to the ground resulting in scratches appearing in the picture screen. You can't feel scratched on the TV surface...
The statement was not complete in the forum , hence I presume the LCD was damaged while it fell to the ground.
The cost of replacing a new LCD to a new set must be reviewed unless you are able to get one swapped from an old one.
Oct 23, 2010 | Vizio SV422XVT 42 in. LCD HDTV
How do you set our vizio to 1080p it is currently set at 480p
You really don't think you set the TV for this, if the TV supports 1080p and the device was 1080 capabilities then the TV will recognize this. If you using a cable box make sure your using the HDMI port on the cable box. I have seen in the past cable companies just using the component ports.
Jan 03, 2010 | Vizio GV42L 42 in. LCD Television
We have cable T.V. should we run the cable though T.V. when we use s-video cables or use cable though vcr then T.V.
I would hope that you would use a HDMI cable to connect your cable box to your LCD TV - why not display the highest resolution to your screen that you can. HDMI will transmit the 1080P high def signal to your screen. These cables can be found at Wallmart and Target or even Best Buy. Don't need the most expensive and or a 6' length or short will work just fine.
Then use your S-Video cable to connect your VCR/DVD to your LCD TV - This is not a High Def signal - only 480i if that. The P means Progressive or 1080 lines from top to bottom. the I means Interlaced to which means 240 lines once for field one then 240 lines for field two.
You may want to think of a blue ray player to which upconverts your older DVD's to 4x3 High Def resolution.
Happy Thanksgiving and God Bless,
Blessings,
A/V Media Tech Guy
Nov 23, 2009 | Vizio L32 32 in. LCD HDTV
Vizio 42" lcd powers up with sound only - no picture
It sounds to me that the unit has a faulty inverter board which could be due to an overheated/bulged capacitor. I would send in a claim on it to the factory if it is still under warranty.
May 28, 2009 | Vizio VU42L 42 in. LCD TV
Can I set up tv remote to also control cable box?
Just bought a Vizio 22" 1080 p TV and need to set up a Verizon Fios remote for it. The codes for Vizio for the remote do not work. Can anyone help me with this.
Steve
Jan 14, 2009 | Panasonic TC-32LX85 LCD TV
Only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
Dec 30, 2008 | Vizio L32 32 in. LCD HDTV
Vizio GV42L 42 in. LCD Television Logo
117 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
