Compaq 5017 I just bought an HP elite M9040N. I am trying to use an old compaq 5017 monitor (that I know works) and it will not work. Any ideas?
    Genius:
  • 3,587 Answers
Hmmm..using Vista by chance? some of the older monitor drivers are NOT included with the Vista driver sets. And, looks like it's only xp compliant.
http://members.driverguide.com/driver/detail.php?driverid=85684
got backup for that HP?
Posted on Feb 17, 2008
Bought HP Compaq monitor with desktop pc and hooked the monitor with old computer and message dispalys input not support on the screen
This means that the Operation System is not equipped with the appropriate drivers for displaying any images on the monitor. You will need to find either a different monitor, or upgrade the video card for the computer.
Please let me know if you need further assistance.
carsandcomps
Aug 12, 2011 | Compaq Computers & Internet
EVERY TIME I TURN MY MONITOR ON IT SAYS "GOING TO SLEEP" AND THEN THEN SCREEN GOES BLACK! BUT MY COMPUTER IS STILL RUNING. I THOUGHT IF I COULD GET A MANUAL I COULD TROUBLE SHOOT IT AND FIX IT. BUT WHEN...
its a very very old monitor,so old in fact , you PC then had no sleep modes. so its inside the monitor, this old
so push the menu key on front of monitor and turn off
sleep/powersaver. ,
no the manual is only, you do know fixya is not HP right?
nor are we COMPAQ
did you leave off works in front if the 1501, HP made types with just that 4 digits.
Compaq 1501
https://www.manualslib.com/manual/30085/Compaq-Tft-1501.html
L1501 and TFT-1501
read the service tag on the monitor and see the real full name
then post that for 10x better answers even the book.
Nov 06, 2017 | HP Compaq 1501 15" LCD Monitor
My monitor has kicked into sleep mode and won't "wake up".
Unplug all the Cables from Compaq Presario 5103 CL and leave the Keyboard, mouse and monitor cable pluged in.
Now make sure the power cable of the monitor should be pluged in and the power cable of the tower should be pluged in.
Now to check if the montor is fine just unplug the video cable only which will show no input signal on the screen. If it shows this signal the monitor is fine. Plug back in the video cable.
If the monitor is going to sleep mode it might be possible that the old computer ( Compaq Presario 5103 CL ) is in stand by mode. hit any key on the keyboard and it should come back .
If it is not in the stand by mode then do one thing. Check the same monitor with the new computer. If it is working. Perfect ..!
Do one thing now ..!
Unplug all the cables from your old system and then press the power button for 30 sec and let it go. Now plug the keyboard, mouse and the monitor try again.
If it works Perfect. If not ..!
Then you need to open the tower and check on the processor FAN is it running..? If its not running you will not get the display as the fan is responsible for the display on the screen. Otherwise...!
Check the Tower possibly the Tower is not getting the power.
Try these steps and let me know If it works
May 04, 2010 | Compaq Presario 5000 PC Desktop
I have a compaq presario s3040se desktop the monitor quit
Try turning on the monitor before the Compaq system box, if Win is doing what it should, it will 'find' a 'new device' and reinstall the drivers for it. It may not look right but you can change the resolution after it boots up.
Apr 22, 2010 | HP Compaq Presario S3040SE (DF222AR#ABA)...
Just says going to sleep
I will assume that you have already try this monitor with other PC nad also try new VGA cable but still getting the same result. Then the problem will be inside the monitor which you will have to open it up and inspect the inside for failed components. Most common failure in the monitors are capacitors in the power supply section, see some pictures here as a guide to what to look for: http://s807.photobucket.com/home/budm/allalbums
Mar 31, 2010 | Compaq FP 5017 15" Flat Panel LCD Monitor
Someone gave me this monitor but without a manual. How do I make the speakers work and what are the three buttons on the front for?
One can usually identify the purpose of front panel buttons just by trying to use them. However, you may need to download a driver specific to this piece of hardware in order to make it fully functional. Here's a link.
http://www.nodevice.com/driver/5017/get31112.html
As for the speakers not working, there are several possible explanations for this. For example, installing the driver may bring them online. More likely though you need to make sure there's an audio cable connected to the back of the monitor and plugged into the appropriate audio port on the back of your computer. Good luck.
Feb 16, 2010 | Compaq FP 5017 15" Flat Panel LCD Monitor
Won't turn on... keeps "going to sleep"
Try another monitor on the computer, if it works properly then you know that the original monitor is the issue.
If the 2nd monitor gives you the same issue then you know its a problem with the computer. At that point, unseat and reseat the memory. Try another power supply. If the monitor still shows sleep mode then the motherboard in the computer is bad.
Dec 17, 2009 | Compaq FP 5017 15" Flat Panel LCD Monitor
Compaq JBL Platinum Series Speakers not working on Windows Vista
change the audio and sound device setting in the control panel. try to change the speaker setup
Oct 05, 2009 | HP JBL Platinum Computer Speakers
No speaker hook up on new moniter
If your old monitor was a Compaq, it had slots for the speakers to hang on and provided the power for the speakers. The speakers still got their input from a cable that plugged into the computer sound output jack. If those speakers are the style Compaq supplied when I worked at a Compaq service shop, they originally came with metal stands that fit into slots on the back so you could stand them up on their own, and a 12-volt power adapter so you could use them without the monitor. If you don't have those pieces, you can buy a suitable power adapter (12 volts DC at 1 amp) at Radio Shack but the speaker stands are hard to find. You could try eBay, or just make a holder of some kind. (A friend of mine used those little wooden stands you can buy to display plates to hold her speakers when she got a new monitor. They worked out pretty well.)
Or you can replace the speakers. A new set would have everything you need. But those Compaq speakers sounded pretty good, so if they're still working you might want to keep them.
Dec 22, 2008 | HP Compaq Computer Speakers
Computers & Internet Logo
76 people viewed this question
Alun Cox
David Payne
David Payne
