Question about Xerox WorkCentre XD120F Laser Printer
XEROX Workcenter XD120F
We just got this printer/copier and it has to spots to load paper in the bottom but for some reason it will not load from those spots ... it will work if you manually feed the paper in from the side but it won't work if you just try to copy and it do it on its own.. any suggestions?
    President:
  • 2,072 Answers
There are connectors that must be plugged in to the board to make them operate. Does the machine recognize that the trays are present? If it does see that the trays are there, I would suspect that with the age of the machine, both sets of feed rolls are either very dirty or in need of replacment. Most likely the rollers are just slipping on the paper when trying to feed. Clean them first with some soapy like cleaner, such as Fantastic, or just rubbing alcohol.
I really suspect bad or dirty rollers.
Posted on Feb 17, 2008
Loud clicking from the manual paper feed? very loud..? xerox workcentere pro 16fx
When printing from the computer, Clicking starts from the printer before printing starts.
Aug 11, 2010 | Xerox WorkCentre XD120F Laser Printer
I have the Xerox XD120f. Cannot pull paper from either drawer.
The rollers are either dirty , or most likely worn out and need to be replaced. They are not hard to replace, but humidity is not the problem, the condtion of the rollers is the problem. Try cleaning them with something like fantastic or formula 109, then clean again with alcohol.
They become slick and will not feed paper. You can google a business called The Parts Drop, they carry about everything for Xerox copiers.
Feb 15, 2010 | Xerox WorkCentre XD120F Laser Printer
Xerox XD120F copy machine not pulling paper through to make a copy. Might grab paper and then jamb.
If the paper is not pulling out of the tray, you should replace the feed rollers. They are easy to replace.
If it is pulling the paper about 2/3 of the way through the machine, you would most likely have a broken fuser heat roll gear, again cheap and easy to replace.
Feb 15, 2010 | Xerox WorkCentre XD120f Copier
I need to print standard size 10 envelopes. Where/How do I load them? WorkCentre7335
Some setup will be necessary both on the WorkCenter and in your software. I will describe these steps and leave you with a link to Xerox to check as a reference:
On the WorkCenter 7335
1) In the Bypass tray, load the std. 10 envelopes width-wise with the side to be printed down, flaps tucked in and with flaps entering the printer first. Slide the guide to just touch the edges.
2) Touch <Change Settings> on the WC 7335 screen
3) Select "Envelope" from the "Paper Type" list
4) Select "No. 10 Env" from the "Paper Size" list
5) Select "Save"
6) Select "Confirm"
In your software:
As you did not specify your software, it is important to note that whatever application you are using, the following settings must agree with the steps above:
1) Feed method = Face down, Clockwise rotation
2) Feed from = Bypass
These options may be chosen in different ways depending on your software program.
You may review these setup steps for Word here:
Xerox WC 7335 Print Size 10 Envelope
Jan 25, 2010 | Xerox WorkCentre M118 Laser Printer
Xerox PE 120i workcenter. Error says
you need to remove your paper tray.take your toner carriage out ,yurn the mc and assess
Nov 29, 2009 | Xerox PE120i Laser Printer
Won't copy
You have either dirty or worn out feed tires. Try taking a cleaner like fantastic, formula 409 etc and clean them well.
If you need , google a business called " the parts drop". Give them a call and talk to Britt or Joe. They will have those at a fair price.
I don't work there, but have not found a better Xerox parts dealer anywhere.
Jan 13, 2009 | Xerox WorkCentre XD120F Laser Printer
Xerox workcentre xd120f laser b/w printer
You can download the manual on the following link. How to clear the flashing "P" is on page 14. http://download.support.xerox.com/pub/docs/XD155df/userdocs/any-os/en/newxd.pdf
Aug 04, 2007 | Xerox WorkCentre XD120F Laser Printer
Drivers to windows vista no are in plans to devenlopment in xerox
Drivers for this printer can be found HERE: --> http://www.support.xerox.com/go/SOHO.asp?Xtype=download&prodID=XD120f&Xlang=en_US&Xcntry=USA ...or HERE: --> http://drivers.softpedia.com/get/PRINTER/XEROX/XEROX-Printer-WorkCentre-XD120f-501230001.shtml
Aug 03, 2007 | Xerox WorkCentre XD120F Laser Printer
Xerox workcenter XD120f
The small scanner glass (not the full size glass) has some dirt on it. Use a lint-free cloth (not paper) with alcohol or Windex and clean the glass. This should help.
Nov 14, 2006 | Xerox WorkCentre XD120f Copier
Xerox WorkCentre XD120F Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
