Question about JVC LT-37X776 37 in. LCD HDTV
Trying to connect playstation 3 to my tv having no success
The playstation 3 was working fine up to about 3 weeks ago no we cannot get it to work on our jvc did we accidently change the settings have tried playstation on other tv works fine
  • 3 more comments
  • stanbo40 Jul 30, 2008
    ps3 works fine on samsung le32r but not on samsung le40f which is full hd 1080p, have changed from custom to auto in resolution settings still getting no signal error message on 40" tv any suggestions!!
  • Anonymous Nov 07, 2008
    well, I'm just borrowing a PS3 from a friend of mine.. Connecting it to my TV but no connection made.. I used the same PS3 some hours ago so I know it's working... I dont have any sort of HDMI **** or such.. only regular TV! This should not be a problem! =P I wanna play! =P
  • gfsam Dec 13, 2008
    is there any special magic to connecting the hdmi cable from the ps3 unit and matching the color coded plug. I have done this but does not communicate
  • Anonymous Mar 22, 2009
    We took our ps3 to a friends house played for hrs unhooked it all went home plugged all back in and it wont connect to my tv it turns on makes all of its normal noises but doesnt seem to connect to the tv can anyone please help.
  • psnykn May 11, 2010
    Ok what do you do if your t.v. is just a blank screen i hear my ps3 starting but it dont know what to do
For real try this:
Turn off the tv as well as the ps3 (to where the red ps3 light is on); Then just hold down the power button in the front for like 15 seconds or so, at least until you hear a beep. Then turn the Tv back on, and hopefully once you get the tv back on the correct hdmi input, you'll see that little message offering you to switch to optimum settings.
Hope it works. Did for me.
Posted on Dec 25, 2009
  • goodril Aug 28, 2011
    UUUUUUUUUUUUUUUUUUUUUUU ROCK!!!!!!!!!!!!! You da biich! Sitting here in hurricane Irene trying to set up ps3 before we loose power! THANK YOU!!!!! We're having fun now!
    Linda, Amy & Joe
    Bound Brook, NJ
Plug everything out. including tv. then power back on and hold the ps3 power button till you here three beeps. its gonna power down again. then press the power button till you here two beeps. that should do it.
Posted on Feb 14, 2010
What is the diffrence between the 2 tvs? are you hooking them up using the same connections? if the ps3 is working on one tv then you know it works so its not the ps3 maybe your inputs on the tv have gone bad I would suggest switching inputs to test it out and be sure that on the ps3 you have the right output settings turned on if you have hdmi turned on you will see nothing on your tv, if you are using hdmi and you have component turned on same thing will happen the ps3 should auto connect depending what you are using.
Posted on Mar 07, 2008
Samsung LE46F86DBX/XEU
I have all the 3 HDMI setup, ones on an xbox360 the others on PS3 the others on a Yamaha DVD-S1700 it seems that their is no auto connect when any of these are turned on "like the scart does" I have to go through the source sellect one at a time is this right or have i not set up something?
also a remote control coad is needed so i can swhich on my sony AV STR-DB780 by TV remote like i do with the dvd many thanks hope you can help-Nigel
Posted on Aug 26, 2008
HELP PLEASE , I HAD MY PS3 SETUP VIA HDMI CABLE BUT WANT TO SETUO USING THE AV OPTION BUT THE PS 3 GOES THROUGH THE MOTIONS OF STARTING BUT NO PICTURE AT ALL ON MY TV SCREEN( i HAVE NOT GOT A TV NOW WITH A HDMI CONNECTION ) I'M PRESUMING IT IS STILL SETUP FOR HDMI BUT HOW CAN I CHANGE IT WITH NOTHING ON THE SCREEN , PLEASE HELP HAVE JUST BEEN BOUGHT CALL OF DUTY AND CANNOT PLAY IT !!!!!!
Posted on Dec 27, 2009
Just bought a ps3 two weeks ago. Played games just fine and everything worked well. We watched a movie last night. Turned off the system and went to bed. The next morning we tried turning it on but it...
This may be a simple fix. Do you still have the original cable that came with it for the video OUT? Plug this back into your playstation and TV while leaving the HDMI cable connected.
check now both HDMI channels and AV/Composite options on your source selection this should give you the display,
Now what we need to do is setup your HDMI output again.
From the menu bar,
  • Go to settings
  • Display Settings
  • Video output settings
  • choose HDMI
if you have the choice to choose OK choose it. If your screen goes blank go through your HDMI channels again and if the Playstation screen is there then select OK,
Then you can remove the composite cable again
Jan 14, 2011 | Video Game Consoles & Games
1 week ago i set my playstation to work on hdmi and now wen i put it on regular it wont work
You have to reset your video settings turn off your ps3 and hold the power button until it beeps twice.
That will reset your settings and it should work fine.
Jan 04, 2011 | Sony Playstation 3 (PS3) Console
Sanyo DP46840 purchased less than 1 week ago from Walmart. Worked fine for first couple of days, now HDMI connections don't work. monster cable works on other lcd tv and all video sources. rest TV...
Hi gregschirk,
I bought the same model and I am experiencing a similar problem. My HDMI components worked fine before. Now both my cable box and DVD player will not be recognized as HDMI systems. It thinks they are DVI to HDMI connections. Good picture but no sound. Would like to know if there is a fix for this.
Thanks Gilbo72
Nov 27, 2010 | Sanyo Televison & Video
No connection to television just got back a week ago from warranty service ,worked fine all week turns on and off with controller
Have you tried resetting the video display back to standard definition. Hold the power button down for 5 seconds and see if that helps.
Aug 03, 2010 | Sony Playstation 3 (PS3) Console
PS3 won't show up on tv
first make sure all componet cables match up in color in back of the tv turn on ps3 and try using the remote to change the componet selection of the port your using
May 14, 2009 | Sony Playstation 3 (PS3) Console
PS3 randomly mutes my TV, Mostly on DVDs
it sounds there is a lose connection inside the ps3 somewhere not sure though hope this is any help to you.
Feb 07, 2009 | Sony Playstation 3 (PS3) Console
Ps3
Go to tool box and delete cookies and offline file content.
Oct 18, 2007 | Sony Playstation 3 (PS3) Console
PS3 not working thru HDMI cable
Same happened to my ps3 one week from new , took it back the the shop and got a refund.
Oct 06, 2007 | Sony Playstation 3 (PS3) Console
JVC LT-37X776 37 in. LCD HDTV Logo
5,326 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
