Question about White Sewing 1730 Mechanical Sewing Machine
Bobbin threading When I sew the bobbin thread clumps and stops the needle. After pulling out the bobbin several times to cut the clump off, now I am unable to pick up the bobbin thread. The bobbin does not do anything with the thread so it moves to a space to get picked up by the threaded needle.
  • 6 more comments
  • prismk Jan 05, 2009
    I have the same problem and have already gone through most of the items listed. I have pulled my machine apart, cleaned it, re-threaded it a billion times, and adjusted all tensions and pressure settings. Nothing helped and I am at the same point where I cannot even get the bobbin thread to grab and be pulled through by the top thread. If I take it in to a repair shop, is the problem fixable?
    Note: I am using a White 2200, not 1730.
  • carriemaesew May 11, 2010
    How does one 'Balance the bobbin'? Do you mean to just empty & refill it? That didn't help.
    Can the timing be fixed at home? I think the needle is not down at the right time for the hook thing that goes around the bobbin case to grab its thread. So, I can't get the bobbin thread to come up through the hole in the plate.
  • Anonymous Mar 12, 2014
    won!t pick up bobbin thread
  • Anonymous Mar 16, 2014
    having problems loading bobbin and getting thread to pick up
  • Anonymous Mar 17, 2014
    I can't get my bobbin thread to pick up
  • Anonymous Mar 18, 2014
    the shaft on my pfaff 1475, is moving left to right,. it's not tight.. and the needle won't pick up the bobbin thread. I can't find anywhere how to tighten the shaft to stay in the center. please help Barbra
  • Anonymous Mar 23, 2014
    will not pick up thread from the bobbin
  • Anonymous Mar 30, 2014
    cannot pull bobbin thread up
  • White Sewing Master
  • 1,388 Answers
You may have put the timing out, however, try this before you despair too much......
Ensure the presser foot is firm enough for the fabric you are using and that it will not just pull through easily by hand with the foot and feeddogs together (as the needle ascends), or things will not proceed, and you will be stitching in the same spot.
Generally a setting of 3 seems to work for general purposes, but if you are using very light or very heavy fabric, a sample is always a good idea before you start in earnest....also match the needle to the work for best results.
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
bobbin threading - 4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 24, 2008
    New Friend:
I want to know how to open bottom part because shuttle driver is not moving at all. so shuttle race is not working. i just want to know how is bottom part is open. Kenmore model # 15208
Posted on Feb 12, 2013
How to fix bobbin thread on computered memorycraft 9000 sewing machine ?
1)Check that your bobbin does not have a nick in it where the thread can catch and won't feed smoothly.2) make sure the upper and bobbin threads are the same.3) pull out the bobbin case and chect to see if there is a clump of lint.4) make sure the feed dogs are moving the fabric through smoothly,some fabrics can get caught on the dogs and make the bottom thread get loopy.5) check your needle,if it's bent or has a bad tip,it can mess up the stitch.
Aug 15, 2014 | Janome Memory Craft 9000 Computerized...
Needle bar
clumping is caused by operator error and tension problems. First make sure you are grasping the threads when you start to sew. Then tighten the upper tension.
Aug 10, 2012 | Singer 3116 Simple
Bobbin thread jams
try changing the needle--flat side goes to the back of the machine
check the thread take up lever & see if the thread is still on it
it's also possible that the machine is out of time & needs to serviced
Feb 19, 2012 | Husqvarna Huskystar 207 Sewing Machine
I have a Brother BC 2100 sewing machine. I have had this machine for approx 2 months. Recently, when I am sewing, usually when sewing slowly, stopping and restarting, the reel of thread jumps and loosens...
Ensure that the needle is installed correctly. If the needle moves down in the needle socket (only a little bit) it causes these clumps. Loosen the needle securing screw - push the needle up as far as it will go and tighten the screw again. Try again.
May 23, 2017 | Brother SE-270D Computerized Sewing...
Lower bobbin thread tangling
You need to adjust the tention on you thread bobbin and on the needle....also, check to see if the needle is touching the plate or the foot.
I have had this problems too. Most of the time it is just a simple adjustment and cleaning.
Good Luck
Aug 02, 2009 | Sewing Machines
The needle will not pick up thread from the bobbin
Remove bobbin and be sure the bobbin thread is correctly placed into the machine. Put fabric, place feed dogs up, pressure lever down, hold the thread from the needle and stitch one stitch. This will have the needle go down and pull up the thread. You will never have a clump of thread under your fabric!
Jul 19, 2009 | Singer Tiny Tailor TT700
Thread keeps wrapping around bobbin
frustrating huh?  it happens!  even to us that have been sewing for 50+ years, but the solution is very simple.  Top thread tension is the culprit.  pull the spool all the way off and rethread the top, follow the threading path precisely and make sure the thread goes down into the tension discs.
one more thing - when that happens often times the piece has to be removed from the machine by cutting those annoying loops on the bottom.  if this is the case, make sure you have removed all the thread clippings from in and around the bobbin case.  sometimes one little piece of thread will make you want to use swear words.
good luck and happy stitching.
Jan 17, 2009 | Husqvarna Viking 1
White Sewing 1730 Mechanical Sewing Machine Logo
397 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
