Question about Sony Cyber-shot DSC-W55 Digital Camera
Slot for memory card
I cant find the the slot for memory crd adaptor in my PC. pls help me.
  • 667 Answers
I assume you are speaking of the USB port to plug the memory card reader into. Some systems have those ports on the front of the machine while others are on the back with the rest of the ports
Posted on Feb 17, 2008
MicroSD Memory Card slot
Just a thought - the microSD memory card is sometimes supplied with an adaptor. The microSD card is slid into the adaptor, which is a dummy standard sized SD card, so it can be used in a usb card reader with a PC or a laptop...
Feb 28, 2018 | Delkin Wingman HD Waterproof Action Camera
Cannot transfer videos from pc directly to external memory, samsung star
To transfer pictures (via a memory card) to a PC requires a microSD Memory Card, Memory Card Adaptor & Memory Card Reader. The microSD memory card MUST first be formatted, by the phone, in order for the phone to create the destination folders. Please note that the minimum size limit for the microSD memory card is 32MB.
This phone will support the use of a microSDHC 16GB capacity memory card. However, for optimal performance Samsung recommends using a card no larger than 2GB.
To learn how to format the microSD memory card, using the phone,The plug-in microSD memory card and its contents can be easily damaged by scratches or bending. Use caution when inserting or removing the card and keep all memory cards out of reach of children.
Warning: Formatting a memory card will permanently delete all current content.
To format a microSD memory card follow the steps below:
  1. Insert a microSD memory card into the memory card slot, located under the battery cover
  2. From the standby screen, press Menu
  3. Press Settings
  4. Scroll down then press Memory Management
  5. Press Memory Card Details
  6. Press Format
  7. Press Yes to confirm formatting the microSD Memory Card
Caution!: Do not repeatedly format a Memory Card as this shortens it's service lifeWARNING: Formatting the microSD Memory Card will permanently erase all data
To transfer pictures (via a memory card), from the phone, to a PC follow the steps below:
  1. Insert the formatted microSD memory card into the memory card slot, located under the battery cover
    1. When correctly inserted, the memory card icon microsd2.gif is displayed
      1. From the standby screen, press Menu
      2. Press My Stuff
      3. Press Pictures or Videos to view the contents
      4. Press Manage
      5. Press either Move or Copy
      6. Press each image to check their box or press All to check All boxes
      7. Press either Move or Copy
      8. Press Memory Card
      9. Press either Pictures or Videos
      10. Press Paste Here to Move or Copy the Photo(s)/Video(s) to the microSD memory card
      11. Remove the microSD memory card from the memory card slot
      12. Insert the microSD memory card into the memory card adaptor
      13. Insert the memory card adaptor into the memory card reader
      14. Insert the memory card reader into the USB slot on the PC
      15. Navigate to the desired Photo/Video destination location, using Windows Explorer, then paste the Photo(s)/Video(s) into the destination on the PC
Regards.
Jun 18, 2011 | Samsung Star GT-S5233 Cell Phone
I have no manual my problem is I have a First Generaiton Ps3 and would like to transfer my Ps2 memory card and cant figure it out. pleae help thank you Nichole
Prerequisites There is no PS2 memory card slot in the PS3 so will need a Memory Card Adaptor. Sony made an official adapter but there are also a number of cheaper alternatives. Buy one online:
Steps
  1. Plug your PS2 memory card into the adaptor
  2. Plug the adaptor into a free USB port on your PS3
  3. Go to the "Game" menu in the XMB and choose "Memory Card Utility (PS/PS2)"
  4. If the adaptor is working you should see an item called "Memory Card (PS2)". Below the title should be the size of the card and how much is in use-in my case "1334 KB / 7998 KB"
  5. Press the controller's Triange button to get the Memory Card options. Select "Copy"
  6. Select "Yes" to confirm the copy from memory card to the hard drive
  7. Enter a name for the new Internal Memory Card that will be created on the hard drive, or leave the default name. I named mine "Original PS2 saves". Select "OK"
  8. The data will be copied. If the amount of saved data is too large, the system will automatically create multiple internal memory cards
  9. You may be informed that the new internal card has been assigned to a "slot". These slots are an emulation of the physical memory card slots in the PS2, so similarly you may only have two internal/virtual cards "plugged in" (assigned) at a time. The internal memory card must be assigned to slot 1 or 2 to be available when you run PS2 games
  10. The new internal memory card should now be showing in the XMB, under Game > Memory Card Utility
  11. Selecting the card will allow you to browse the game saves that were copied across!
Jan 04, 2011 | Video Game Consoles & Games
Have an HP L7680 all-in-one Just received a Panasonic Limuix camera and cannot read the SDHC memory cards in the SD slot - Printer posts an error
No, it's not possible, it'll never read SDHC in the SD slot. SD slot will only read SD, Mini SD (with adaptor) and Micro SD (with Adaptor). If there's no SDHC card slot, then it doesn't support SDHC Card. The lists of supported memory card are listed below:
CompactFlash™ Type I and II,
Secure Digital/MultiMediaCard/Secure MultiMediaCard (SD),
xD-Picture Card,
Sony Memory Stick®,
MagicGate Memory Stick,
Memory Stick Duo,
Memory Stick Pro
I hope this clears your doubt.
Note: SDHC and SD are different Memory Card types.
Good luck.
Thanks for using FixYa.
Sep 21, 2010 | HP Officejet Pro L7680 All-In-One Printer
How do I put an SD memory card in a hp Paviliion ze2000 notebook? I cant' find the memory card slot anywhere!
Actually your laptop doesn't have SD memory card slot but there is another way you can use that SD memory Card in your Laptop.
You have to get SD Card Adaptor.
Click here to see how it looks like and also you can buy it at the website.
Please let me know if you have any further questions or concerns.
Thanks.
May 03, 2010 | HP Pavilion ze2000 Notebook
MEMORY CARD SLOT FOR N70 CAN'T READ / CANT TRACE MY MEMORY CARD
your card may need to be formatted for use in the phone. The phone supports FAT32 file system go to Menu - Tools/Setting - MemoryCard - Options - Format Mem Card and click YES
WARNING: Back up you card on your computer first because formatting you will lose your contents
Jun 19, 2009 | Nokia N70 Cellular Phone
Instruction manual misplaced. Want to insert Memory Card from digital camera and don't know how? H E L P a very non-techie!! Laptop is Acer Aspire 5315. Ta.
what type of memory card u want to insert the memory card slot is on the left side of the laptop beneath expess card slots next to usb ports on the left side , pls check that it supports the card u are trying to use for reading it, it only supports XD/SD/MS PRO DUO/ and not mini sd or trans flash or mmc or some other types the slot is clearly marked with icons of the card types it supports just press this like one inch slot which contains a dummy card to fill the space just push and this dummy card will come out from the slot then insert the supported card type into the slot and the windows will recognize it in my computers as a removable drive icon , pls let me know if i can help u more on this
and pls rate me fixya if i have fixed ur problem
regards
zohail
Mar 02, 2009 | Acer Aspire 5315 Notebook
DS lite card reader
Why don't you buy a R4 or Acekard, something that can go into the Slot-1 of the DS?
Aug 10, 2008 | Nintendo DS Lite Console
Wireless crd
Hi alioops, unless you're using a laptop with the FS7600, normally you can't use or install the netgear wireless pc card (WG511;PCMCIA Card) to a regular desktop computer. If however, you're using a laptop, then you have to find a narrow rectangular slot normally at the side of the laptop with flip or hinge cover. Merely pushing in the Netgear Wirteless PC Card into the said slot would physically install it. Of course, it has to fit snugly and perfectly in order to work. Further you may have to install the drivers that are in a CD that comes with the card. Hopes this works for you. Pls post again how things turn up. Kind regards.
May 26, 2007 | HP Compaq FS7600 17" CRT Monitor
Sony Cyber-shot  DSC-W55 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
