Question about Mitsubishi WS-55807 TV
Mitsubishi hd1080 hi i was inquiring because my tv doesn't get a picture but if i press settings on the remote i can see the picture i do get sound but nothing on the controll panel works only trough the remote please help?
I'm trying to conect a monitor to my tv by DVI cable
Posted on Nov 08, 2008
  • 45 Answers
Is it a PIP model? If it is, some capacitor fluid might have leaked onto the PIP board. It looks oily. Replace them. Replace them EXACTLY, because someone learned (The hard way) that if you don't, they will explode.
Posted on Aug 19, 2008
I can't disconnect the parent v chip now it is automatically blocking stations
Posted on Mar 24, 2008
My mitsubishi medallion hd 1080 doesn't show content from component cable
Some of the older Mitsubishi with HD 1080 have only one component input for HD---it is marked on rear as DTV----also a model number may allow me to give another suggestion--Some of these sets (ws, wt, vs models) will on occasion lock out or disable the input/s.
Depending on model number most also have 3 hidden menus---one is the option menu----it allows with the Mitsubishi remote via a 4 digit number (by model number) to enter there and do a hard reset of the set----sets every setting back to factory original---seen it "cure" all kinds of odd problems from missing rear inputs, no sound, odd video issues---you name it.
Get me the model number and I will see if can find the code for yours--you can also try hooking first direct a 1080 blue ray or Dvd if you want to see if the input is active or not first.
Apr 14, 2012 | Televison & Video
Mitsubishi hd1080 locked tv will not go on can i reset without a remote
A reset is only possible with an original remote----reset will not cure set not coming on---a model number would tell me more.
Feb 19, 2012 | Mitsubishi Televison & Video
I have a mitsubishi big screen hd1080 model 50111 how do i unlock the v chip to look at all movies, was given to me by a friend. what is the magic pass code.
On your remote press menu then 1 then 2 then 3. Go initialize option and press enter. Your TV will reset to brand new out of box conditions.
Apr 11, 2011 | Mitsubishi Televison & Video
I have an mitsubishi medallion hd1080 big screen tv model# ws-55819 getting code 1,2. (hold the menu and input)
Try to unplug set and try it again as if the set was unplugged and then the self check done it will be 1,2 which means NO ERROR detected.
Let me know also what the set does?
SD TECH
Feb 17, 2010 | Mitsubishi WS-55819 55" Rear Projection...
Why can't I receive in HD? i have the hd1080
Your set will only convert to 480p. There is no way a conventional crt based tv will get 1080p. The proper connections will be using the RGB component inputs on the jack panel ( red,grn,blue ) then the white and red for audio. The picture will be a lot better than standard cable but not as good as HD. ( 720p )
Dec 21, 2009 | Mitsubishi WS-55613 55" Rear Projection...
True HD1080
You can use the DVI connection, or the digital HD rca connections on the back. You can also get a dvi to hdmi converter plug.
Dec 09, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Lost manual to rca universal remote, lost programing to operate remote
RCA Universal remote codes for the Mitsubishi TVs are...006,011,014,019,022,027,041,056,061,068.
First, turn on TV
Press and hold code search button on remote
Press and release the TV button
Enter the three digit code you want
Release code search
Push channel up, if device responds, that code worked.. If not, repeat steps 1-5 with each code until you find the one that works. This information can be downloaded from http://www.thompsontv.com/rcarc.html
If you want a hard copy with codes for all TVs.
Aug 29, 2008 | RCA Universal Remote Control
Locked TV
Good day, Katie0113; I hope you solved this concern by now but if not here is the fix: To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds. I hope this helped, good luck, big IRISH.
May 19, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi HD1080 60in TV
First do a self test diagnosis. you can search Mits tv or read my solutions.
Mar 10, 2008 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi diamond hd1080
It sounds like you will have to replace the convergence IC's in this TV set. Not a really hard repair to do but you will need to know how to solder and work on solid state printed circuit boards. Good Luck
Jun 29, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-55807 TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
