Question about R.A.M. Computers IX PACIUP4240 15'' LCD TV / DVD / PC CIU Combo (2.4 GHz and 256MB RAM ) (PACIUP4240L) PC Desktop
Graphics i have a pacco ix 260 it wasnt working when i found it , i replaced the power supply when it wouldnt stay on for more than 2 seconds and that fixed the problem but while i had it apart i broke the video card and that video card was original used no pci slot , can i get a new video card to go into a pci slot n still just use the vga or video out connections on the mother board because i wont be able to use the 1 on the new graphics card itl be inside the computer .
Where did you buy the power supply?
Posted on Jul 10, 2008
Graphic card output connections cannot be shared on two different cards. You will need to install the PCI card then find a way of connecting your screen cable to it depending on type of PC case and motherboard orientation.
Posted on Feb 18, 2008
Ix pacco 2.4
I don't think so. If you need to reset it just open your system and see the CMOS clear jumper just beside the HDD port there should be three pin just change the jumper If jumper is seted into 1-2 then you put it 2-3 now system start by default It will go into CMOS then go to advance setup set the boot prority as first boot device HDD0 and pree F10 to save it.
Aug 18, 2012 | R.A.M. Computers IX PACIUP4240 15'' LCD TV...
The tv is 2 years old. it would turn off after turning on by itself. this happened for 2 days. it would stay on afetr you turned it on a couple times. then the next day wouldnt turn on at all
Had the same issue with my Vizio Plasma VP322HDTV10A. At power up it would turn on and off a number of times before it would stay on. In thinking it might be the power cord, I pulled it out and replaced it with a spare I had and it would not power up what so ever. I opened up the case and traced the the internal power coord to it's source and this lead to the main power supply board. I found three capacitors on this board with buldges on them (which the tops of the capacitors should be flat). I found a web side (SHOPJIMMY.COM) which had the parts I needed to repair the TV myself. the following is how much it cost to replace the needed parts
LG EAY42539401 Power Supply
sj-EAY42539401
$ 67.16
Vizio VP322HDTV10A Cable Kit
$ 29.36
LOC: DA
Subtotal
$ 96.52
Also Included Photos of the board with the failed capacitors
Nov 28, 2010 | Vizio VW32L 32 in. LCD HDTV
The red light in front was blinking.the repair man said it was the power board.We replaced it , now the red light blinks 6 times then quits. There is no picture but when on you can here the sound.
A 6 blink SOS shutdown, you would want to be looking at the SC, SU and the SD boards. One of those boards is causing the malfunction. Possibly, but unlikly(I have to mention it for just in case reasons) the PDP panel could have blown those boards.
Just out of curiosity, what was the original problem that made you call the first repair guy?
Dec 19, 2009 | Panasonic Viera TH-42PX80U Plasma TV
For my mac g4 first generation, i bought a Ati radeon 7000 PCI. the goal was to stop using my original graphics card and use the ATI radeon 7000 for my main and only screen but when i start up with my...
hello...the way is try to open the Bios Settings then disable the on board video then set primary AGP/PCIE slot Video Card to run then try again to install the video card driver but 1st you need uninstall the old driver..thanks and Good Luck..have a nice day..^_^
May 12, 2009 | IXMicro ix3D Dual Monitor (8 MB) Graphic...
IX Micro IX3D twin turbo Graphics Card for PCI on my mac under osx tiger, my second screen stays grey
If you are running windows, (which I presume) try rightclicking on dektop, select properties, then settings (or the vista equivalent of that), select the second display, and check the "extend desktop to this display" box.
I hope this helps,
Yannick
Power Suply Replacement
Any good computer supply company should handle power supplies. The important thing is to get one rated for the same power. (300W, 350W, 400W, etc.) You can always go higher, but not lower.
Oct 18, 2008 | Computers & Internet
Pacco group ix my ciu p4 2.66ghz 15" tft
try ebay I find a lot of hard to get parts some new some used there
hello i got the same problem like u,but the thing is i call some1 2 check my p.c and he took my power supply and never give back 2 me,can u let me know that serial # or any info about the power supply....thanks or if u bought 1 4 u...........
Jul 10, 2008 | R.A.M. Computers IX PACIUP4240 15'' LCD TV...
R.A.M. Computers IX PACIUP4240 15'' LCD TV / DVD / PC CIU Combo (2.4 GHz and 256MB RAM ) (PACIUP4240L) PC Desktop Logo
115 people viewed this question
Top R.A.M. Computers Computers & Internet Experts
Laxman Bisht
Laxman Bisht
castletech
castletech
Are you a R.A.M. Computers Computer and Internet Expert? Answer questions, earn points and help others
