Question about Samsung HLR5067WX 50" Rear Projection HDTV
Large black bar to the left of screen
My Samsung HLR5067W has a black bar that runs from top to bottom on the left side of the screen. Replaced the light tunnel and now the black bar is larger than before. Any ideas?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
When replacing the light tunnel, the new one must be installed exactly as the old one came out. This can only be done by marking the screws and backing them our exactly 3 or 4 revolutions and then tightening the new one the exact same revolutions. When looking into the old tunnel you should have been able to see the mirror that came unglued to ensure that was the problem. The problem now can be corrected by loosening the screws on the dmd bd and manually adusting the dmd position in association of how it hits the dlp chip.
Posted on Feb 21, 2008
How do I download a manual for Samsung T105G?
To download a manual type in your browser manual for Samsung t105g, you should be able to prprig it. To space on your tracfone you press on the right side of big square bar in the middle and press to the left side to back space. Hope this helps!
Sep 15, 2014 | Samsung Tracfone Sgh T105g Cell Phone...
I have a black 6in wide bar on left side of the screen and a 2in bar on the right side that run from top to bottom. Only on certain channels and comercials.
Its not the set if only on certain channels, it cannot be. Got a box or something connected for signal?
It also should not do it if a DVD etc connected to a rear input is used.
Dec 23, 2012 | Hitachi Televison & Video
Black bar on the top and bottom during watching the tv
Hello
If you are watching television and you see black lines on the left and right sides of the screen, check to see if you are watching an HD broadcast or a standard definition broadcast. You can do this by bringing up the TV guide menu on your remote. If the show is in HD, it should take up the full screen. However, if it is not HD, bars will be present on the left and right of the screen. That is because standard definition programing is in 4x3, which will not take up the entire screen.
If the picture you are watching not only has black bars on the sides, but on the tops and bottoms of the screen as well, your "Zoom" mode has somehow gotten off-kilter. Press the "Zoom" button on the remote until the image appears correct. If this does not work, power down the television, wait a few moments, and power the TV back on. The image should be correct now.
If the image on the screen looks stretched or squished, this is because your HD cable receiver is not set up properly for your widescreen television. Press the "Menu" button on the receiver
May 06, 2011 | Samsung 50 in. Plasma TV
Samsung HLR5067W: Screen goes black - Audio Remains. Several months back my 5 years old HLR5067W started displaying the following behavior: - Launches OK - After running for a while (anywhere between...
When was last time you replaced Lamp? Ballast Board is what powers the lamp on.
Lamp Fan, if it is defective it will shut lamp off to protect it, if it is Not cooling the Lamp.
Mats has Lamps for $99.00 1-800-628-1118
Encompass Parts Distribution has 10 Ballast Boards in Stock for $68.96 they also list Service Manual Free for this Model# 1-800-638-3328
Nov 03, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
Dark vertical bar on right side of display
Please let me know if you find a fix. and what the problem was. Eddie.
May 28, 2009 | Samsung DLP HL-P5663W 56" TV
Black bar running from top to bottom in the screen.
There are horizontal and vertical relays in plazmas that go out over time and cause this to happen , You can get an estimate from a local tv repair service in some cases they can give it to you over the phone. Good luck.
Dec 30, 2008 | Samsung PS42S5H 42 in. HD-Ready Plasma...
DLP HL-R5067W
Your model has a maximum resolution of 720p. What you might want to do is make sure that both your cable/sat box and game stations are outputting at no more than 720 resolution. It's easy to assume that all HDTVs may accept a higher signal, and while they might, some of the scene changes or handshakes may make that operation cause the symptoms you describe.
Feb 08, 2008 | Samsung DLP HL-P5663W 56" TV
Large black line top to bottom
The plasma display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Oct 26, 2007 | Samsung HP-R4262 42 in. Plasma Television
Samsung HLR5067WX 50" Rear Projection HDTV Logo
187 people viewed this question
Henry  Thomas
Henry Thomas
